What caused this hole in tube?
Can you guys help me determine what caused this hole? The tube is the original from a Giant Talon mountain bike. Five days ago I changed from the original tires to Continental Contact Cruiser tires. After I changed the tire I went on a mile ride, then the next morning I went on a 10 mile ride. I noticed the flat today, 3 days later. This was my second flat in about a month and this one was on the front, last was rear. The tube had over 450 miles on it and all my riding has been on paved, neighborhood roads. I checked the tire and the rim and didn't see or feel anything that may have caused the hole.
Run your fingers around the inside of the rim, like where the spokes come through the rim and a bit to either side, all the way around. I'm not an expert, but that's what I would do.. Make sure there are no pointy things to puncture a tube.
Thank you. I should have been more descriptive. I did look and feel along the tire and rim, and didn't see our feel anything. I edited my original post to reflect that.
www.theheadbadge.com
Quoted: 2418 Post(s)
Liked 4,381 Times
You have me scratching my head. Please let me know if you find the cause. I guess it could be a defect in the tube, but it seems unlikely.
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
Looks like something with the rim from the location of the hole.
Likes For delbiker1:
I was thinking something rim related caused it as well but couldn't find anything. The rim strip was whatever came with the bike, sorry I don't have more details. I had the tire at the max psi it was rated for, 65.
Really Old Senior Member
I'd call it a fluke until you get a 2nd similar hole.
Likes For Bill Kapaun:
Use a fluffed up cotton ball. It will snag on very fine wires and junk that are impossible to see and hard to find except by getting poked by it. ON the road, you can use a cigarette filter, they're pretty common on the ground....
Likes For dscheidt:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Even of the rubber rim strip looks good, I'd run a couple of turns of electrician's tape around to make sure everything is covered.
Quoted: 6167 Post(s)
Liked 4,784 Times
Looks like a puncture, but cam angle being what it is, hard to say. And it is on the rim side, so if no spokes or bad rim tape/strip. The maybe a one-off thing you might never know.
Since you've had several soon after fixing flats are you sure you aren't just getting careless and letting the tube get pinched under the tire bead as you slip the last of it over the rim?
I get that way sometimes too when I think I am too good at changing tires for anything to go wrong. Murphy steps in and humbles me.
Quoted: 1572 Post(s)
Liked 643 Times
What kind of rims? What kind of rim strip?
Some types of rim strips can shift from side-to-side during the tire changing process. If that leaves the tiniest little arc of unprotected spoke hole exposed your tire pressure will force your inner tube against that metal edge and, over a period of time - usually not immediately, make a hole in your inner tube. It looks to me like that's what may have happened to you.
Unless I have tires that are real hard to fit, Velox is my preferred rim strip, preferably wide enough to fill the rim space all the way from flange-to-flange.
Quoted: 18349 Post(s)
Liked 4,501 Times
First, use the tube and valve stem to measure the distance along rim (each way), to determine probably fault area along the rim for closer inspection. Any signs of stretching or something on the tube?
Did you reuse the tube from the previous tire? What kind of tools did you use to remove and reinstall the tire? Screwdrivers? It is possible you pinched the rim during the installation. That usually creates a big hole, but possibly a small one too.
