For the love of English 3 speeds...
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
The tension bolt on the seat should be tightened in very small increments
and never with a wet/damp saddle.
I prefer buying used saddles for the fact that they're already
broken in and considerably cheaper......
I've also used leather dye to spiff them up a bit.
Likes For gster:
Quoted: 938 Post(s)
Liked 2,939 Times
Liked 443 Times
Quoted: 938 Post(s)
Liked 2,939 Times
I believe my usage was appropriate, referring to B66/67/Flyers. From the Brooks site: "The Flyer and its ladies model Flyer S are classically sprung saddles for long distance trekking..." They need their noses aimed even higher than non-sprung models.
Phyllo-buster
Liked 2,054 Times
Here's a couple of mine. Of course my short inseams require zero setback posts.
Likes For clubman:
Phyllo-buster
Liked 2,054 Times
Fify is an opportunity to prove one is clever. If it doesn't work, it's my problem.
Quoted: 938 Post(s)
Liked 2,939 Times
Yes indeed. I have C17s on two other bikes and some folks ask "doesn't it hurt to have your saddle pointing up?" I find that folks who are familiar with setting up leather saddles often don't realize how much more the sprung ones go. 'tis a sensitive subject! If you set one up with the classic slight upward tilt, just a few degrees, it feels like you're sliding off the front once you get on and ride.
Likes For ascherer:
Location: Southport, North Carolina, USA & Pevensey, East Sussex, UK
Bikes: 1)1992 Trek 970, 2)2010 Trek 6500, 3)1973 Colnago Super, 4)1955 Freddie Grubb Meteor. 5)1993 Airborne Ti-Hag Titanium. 6)1936 BSA 602DX Roadster. 7)1957 Philips P2 Sports. 8)1955 Dayton Roadmaster. 9)1948 Humber Clubman. 10) 1949 Sunbeam WA3 Wayfarer
Quoted: 157 Post(s)
Liked 85 Times
This bike has Sunbeam Centrepull Brakes, BSA took over Sunbeam in 1943, one can only assume the made use of Sunbeam components on their own models. My 1949 Sunbeam WA3 Wayfarer has these brakes. A word of warning regarding the brake cables, they have special nipples at brake end and are virtually irreplaceable, take extreme care with them.
Cuius summa inventa
Cuius summa inventa
Likes For PeterLYoung:
Williams Crankset
So I'm going to eventually build up my '54 Armstrong 531 road frame with a Williams chainset/crankset to drive my FW hub, which is built into a 700c wheel. Does anyone know what spindle length the English Club style bikes use? Then I can find the correct cup-and-cone bottom bracket and spindle for the Williams crank and chainline with my hub gear. This will be a long-term project to collect some period parts for a late winter build.
1954ish Armstrong Consort straight-gauge 531 frame and fork
Slightly less than 1” drive side. This bottom bracket came with the frame.
About 13/16 left side.
.86” thick
BB protrudes roughly 3/32. Almost to much frame clearance. This is only a 40 tooth ring.
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 359 Post(s)
Liked 465 Times
I believe the stem is as high as it goes safely. I wanted to keep as much of the original equipment as possible. My commute is about 4.5 miles each way and I found I was feeling cramped reaching for the bars and wanting to slide my butt back. The seatpost resolved both issues. Sprung Brooks saddles want their nose up to the point where it freaks out folks that haven’t ridden them. Seems counter intuitive but it’s remarkably comfortable, especially on rough city streets. Have you tired tightening the adjusting nut at the nose of the saddle?
Quoted: 938 Post(s)
Liked 2,939 Times
Thanks. I feel the same way. I don't want to remove the original stem, bar, or add an extender. I am going to try a layback seatpost. I haven't adjusted the nut because it is a 70 year old saddle and I am afraid of tearing the leather. rhm suggested finding some foam to stuff underneath between the leather and rails to shore up the seat surface. I was thinking of trying case foam from the hardware store, cut to fit.
Liked 443 Times
Custom BSA Path Racer for sale...
https://deadrats.co.uk/2020/01/16/fo...sa-path-racer/
Nice bike but a bit pricey.
On a side note the seller has used the word "Bespoke" in the description.
Bespoke does refer to something custom made but specifically refers to something that has "been spoken about previously"
i.e. ordering a custom made shirt or a hat for example.
Likes For gster:
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
I've not had any troubles with the small bits in the GB brake levers. On several occasions though I've cannibalized Weinmann levers for the clamps that fix the lever to the handlbars. I've also found it advantageous to mount the clamp on the bars first, and then offer the lever to it, rather than try to work the lever and clamp around the bends of the bars.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Cheap it says, or maybe even free
And it looks like a ladies' 23.
https://www.facebook.com/marketplace...6495416048901/
Liked 443 Times
Here's one for the detectives
A new listing on Kijiji, Toronto
A nice fender ornament
Looks to be British....
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
Looks like a Rudge
Get off my lawn!
Quoted: 93 Post(s)
Liked 98 Times
Liked 443 Times
Quoted: 359 Post(s)
Liked 465 Times
Phyllo-buster
Liked 2,054 Times
Liked 443 Times
My 1930 Hercules also has a hole in the front fender (no ornament).
I like those "7" seat posts as well.
Liked 443 Times
The proportions, the angles, the relationship between the frame and the wheels.
It's quite perfect in it's design and function.
Well done.
Being of Scottish descent, I like the frugality as well....
Quoted: 887 Post(s)
Liked 335 Times
Bikes: 30's Speedwell Club Racer, 40's Speedwell 'Z' racer, 50's Unknown Aussie with nice lugs, 50's Speedwell Roadster, 50's Repco Roadster, '63 Raleigh DL-1, 70's Raleigh Sprite, Puch Promenade with Nexus 8
Quoted: 149 Post(s)
Liked 30 Times
TCW hub stamped 1957. This is halfway through cleaning & I'm reassembling as I go. I had to stop at this point because I forgot to bring grease with me to where I'm doing this; and it was time to pack the bearings. I got this from a trashed ladies framed BSA, and was also able to harvest its steel wheeled cable guide and the shifter. The gear insides show no signs of wear which is nice, just a little wear on the bronze brake shoe. This will go on a mid-fifties Australian roadster with 28 3/8" wheels (642mm). I've heard the braking from these is fairly lame, but I'll have a decent front brake to do most of the stopping.
