Best way to remove grips without compressed air or cutting them?
Bikes: 86 Nishiki Olympic Sport, 87 KHS Montana Team, 06 Dahon Mariner
Quoted: 17 Post(s)
Liked 5 Times
All,
So back when I had a compressor, getting handlebar grips off handlebars was a snap. But now I'd like to remove a set of grips without cutting them off, and I don't have a compressor any more.
What clever tips can the forums offer to get these grips off?
Thanks,
Warr
Thanks,
Warr
Quoted: 5766 Post(s)
Liked 2,538 Times
Now that you've taken the two best ways off the table, we're down to the dregs.
My favorite way to remove grips that can't be blown off is to open an adjustable wrench to span the bar, and push the grip off from the front.
FB
Chain-L site
FB
Chain-L site
Happy go lucky
Bikes: 2010 Nagasawa (Track), EAI Bareknuckle (Track), Custom Jonny Cycles (Track), 90's Eddy Merckx (Road), 2002 Colnago Tecnos, 200? Felt F60 (Road), 1992 Schwinn Paramount Series 3 (Road)
If you're not worried about scratching your bars, or have something softer (like a wooden skewer), get it under the grip while adding a little water. Rotate the grip slightly with your hand while working the device deeper in. Eventually it'll just plop off.
Quoted: 114 Post(s)
Liked 119 Times
I find alcohol works best. Try to lift a bit of the grip with a stick and pour in a little rubbing alcohol. It's best to tip the bar to let the alcohol flow into the grip & bar interface. Start twisting and the grips will slide right off. This is also how I install grips, too.
Likes For Philphine:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12736 Post(s)
Liked 7,647 Times
If I don't care about the bars much I'll just grab an old spoke from the junkbox and use that instead, saves a trip to the kitchen.
Quoted: 513 Post(s)
Liked 445 Times
Water or denatured alcohol from a cooking syringe. Doesn't make a mess or leave a residue on the inside of the grip.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
chopstick and fabreze.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Bikes: everywhere
Liked 7,647 Times
Windex works nicely also.
I gotta try the syringe method. I've a syringe for refilling printer cartridges that should work well.
Use your hand pump , maybe chuck up a ball inflation needle ,
in the schrader valve head.
cover the hole in the other grip end with your finger.
once that grip is off cover the bare end and the nearside grip should pump off..
Quoted: 1438 Post(s)
Liked 1,092 Times
I like to ease a small screwdriver under the grip and then use the thin plastic "straw" attachment to spray WD-40 under the grip. It's about the only thing I use WD-40 for in bike work.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
Alcohol, water (with or without soap) or anything non-oil based will work. I use a basting syringe and insert the needle through the grip to inject liquid...water usually...under the grip. A small screwdriver and a spray bottle works almost as well.
Stuart Black
Stuart Black
Likes For cyccommute:
There are many good ways of removing grips without air or cutting them off and many are given here. Using an oil based method isn't one of them. If you are going to use oils, just cut them off because they aren't going to be usable afterwards.
Right! DO NOT use oil! Oil and rubber aren't the best of buddies.
Water or alcohol, using a method of prying up one side of the grip (I use a screwdriver) then pour/spray in the water.
Work it until the water gets around the grip and slide off.
To install, I use hairspray (my wife's, so don't tell her). Hairspray will then dry, making the grip adhere to the bar but still easy to get off later.
Liked 4,201 Times
A pump spray bottle of Aquanet will last you roughly 50 years. I bought a bottle back in the 80's and I still have most of it left.
Stuart Black
Stuart Black
Buy yourself a bottle of Aquanet ($3) at the local drugstore and quit using your wife's expensive toiletries. Wives get testy when you do that!
Liked 4,201 Times
...at your own peril
Stuart Black
Stuart Black
I have used the WD40 and screwdriver method on 40 year old Raleigh grips with success. Just make sure you wash them off good to remove the residue WD40.
I used windex to put them back on and position them. Good as new and tight as ever.
Liked 4,201 Times
If you use Windex to take them off, there's no need to clean them before you put them back on. Why add an unnecessary step?
Stuart Black
Stuart Black
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
windex and a small tire lever do wonders, especially if you have a strong grip and a nice pair of work gloves to give the grip a nice firm set of twists in between applying the windex.
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
Cyccommute,
The extra step is no biggie. These grips were on for almost 40 years at the time. I did not want to damage them. I asked the same question some time ago and this is how I was told to do it.
It worked, no problem. Just make sure you use a small thin flatblade screw driver and take your time. No damage to the bar or grip. No special tools required. Came right off.
a long thin phillips screwdiver (those sold as 'precision' screwdrivers) dip it in a mix of water and washing up liquid, 'screw' it up the grip then put pressure on the grip with the other hand so that as you screw the driver it makes its way all around the grip, grip slides off without damage in about 20 seconds.
