Steve Bauer Bora
Quoted: 4719 Post(s)
Liked 3,034 Times
While I haven't heard of this particular model, the name is reasonable as the Steve Bauer road bicycles were typically named after winds. The colour scheme would place it circa 1988-1990. Personally, I'm a bit surprised to see an SL/Matrix combination. I thought it would have been higher grade given the presence of what appears to be a number peg. Also, by this point, I would have expected the newer Cromor label. It may be a Billato built frame, as they used that top tube, Italian tri-colour braze-on a lot.
Quoted: 608 Post(s)
Liked 352 Times
Bauer bikes were mostly middle of the road bikes but I have this vague recollection that the higher end frames were built by Gardin in Toronto. Hopefully you will find a more definitive answer.
Bikes: Rat Scapin, No name Italian, 89' Cannondale SR1000, 2014 Jamis Icon, Steve Bauer Bora, GT Timberline FS, 1992 Diamondback Master TG, 2003 Felt F15R, 1990 Trek 1100, 1994 Mongoose IBOC Comp SX
Hello,
I hate to resurrect an old thread but this is the only place on the entire internet with a mention of a Steve Bauer Bora. I believe I obtained this same bike the OP mentions as I remember seeing it listed on craigslist in Ohio while I lived there then owning it myself maybe a year after. The bike is a Matrix frame and fork and indeed has Gipiemme dropouts. It also strangely sports a number plate holder and has really tight clearance for the front tire and caliper. I've built the frame up three different times and would just love to know anymore information about it. Apparently I have to post 10 more times to post an image. Thanks so much!
Liked 3,034 Times
Hello,
Regarding the origin, it would be normal to consider Gardin as a possible source, given that both brands are Canadian, were in opertaion during this period, and the companies were within a couple hours drive of each other. However, Gardin typically used a different style of stay end treatment than that found on your Bora and for this reason I would discount them as the frame manufacturer.
Bora I just acquired, Cromo PG , made in Taiwan, Original stem and handle bar were pink. Shimano Exage 400 LX components,. 7 speed thumb shifter I think it's an '89. I also removed the original biopace triple crank....it was too nice to use for a winter bike. Strange they would make MTB and road bike with same name.
Liked 3,034 Times
Regardless, Shimano 400LX, if OEM, would place it no earlier than the 1990 model year and no later than the 1993 model year. I don't believe that I've seen any reference to Steve Bauer bicycles that post date 1991. Circa 1990-1991 was the time that a deal was struck to market the brand via the Canadian Tire store chain. The logo incorporating the maple leaf is consistent with the bicycles sold via Canadian Tire. Given its Taiwanese origin, there's a possibility that we may be able to identify the manufacturer and date from the serial number.
Date code on crank arm is NL (Dec 89) and pretty sure it's OEM, the bike was barely used when I got it, that incredible paintjob is pristine! lol
The serial number is difficult to read due to a weak stamping D00219801 not really sure if first character is a D
Quoted: 1370 Post(s)
Liked 1,743 Times
A few Steve Bauer bikes have come my way, over the years. None have been particularly impressive, in my opinion. That said, they appear to be well made and offer both pleasing aesthetics and ride quality. Sadly, I have never had a chance to ride one of the top models...
Liked 3,034 Times
It's a 1990 model. The serial number is a standard Taiwanese format and indicates February 1990. That's a good match for a December 1989 component date code. Most companies would have started building the 1990 bicycles around September 1989. Thxs for posting.
Bikes: 1981 Raleigh GP, 1985 Norco Bush Pilot, . . .
Quoted: 235 Post(s)
Liked 178 Times
I have seen another Bora model and its serial number. I would suggest that the serial number on your Bora starts with HD9002. The HD is a common prefix on Bauer models from Taiwan and the 9002 would be the year and month of frame manufacture: 1990 February.
Hello Marco99,
Have a look at the photo
Liked 3,034 Times
Serial number appears to be D00219801
This matches a commonly used Taiwanese format Mymmxxxxx, where:
M = manufacturer's identity code. In this case, "D" is unknown.
y =year, where "0" is 1990
mm = month, where "02" is February
xxxxx= sequential frame number during month, where "19801" is 19,801st frame of the month.
Consequently, your frame would should be the 19,801st frame manufactured in February 1990, making the bicycle a 1990 model. As previously noted, this fits nicely with a November 1989 component date code on the crankset.
Quoted: 235 Post(s)
Liked 178 Times
The Bora serial number is also unevenly stamped into the seat tube.
Edit: More information.
I found the reason for my confusion with the Bauer Bora serial number format.
Some Bauer road bikes from this period have the serial numbers stamped on the BB shell. These serial numbers begin with letters and have the first 2 digits for the year and the second two digits for the month.
twoducks
9
08-06-15 08:28 PM
Catnap
Classic & Vintage
8
05-22-13 02:28 PM
