Are Drop bars just an illusion for most?
#351
Sunshine
Quoted: 10955 Post(s)
Liked 7,484 Times
Drop bars have only one more position than flat-bars with bar-ends, and that is the drops. And the drops can be very uncomfortable for a lot of people. Braking on the hoods, and in the drops both have their challenges. Using flat-bars, you can very easily get on the grips and have full braking using one or two fingers. I think that going up an incline with flat-bars is easier than drop-bars because when you use the bar ends you can really swing the bike back and forth while standing. I also think that bar-ends are an absolute must on flat/riser bars.
2- I cant imagine being able to swing a bike laterally back and forth more on flat bars than with drops. But regardless of if I could, the real question is- should I? Should I throw the bike back and forth while standing on a climb?
#352
Last weekend I did a ride with lots of gravel, including a couple steep gravel descents where the grade was about minus 18%. Can't imagine coming down that on the hoods. Just one of the many times I prefer to be in the drops.
This is a weird thread. Use what works for you. If that's drops, cool. If not, also cool.
#353
Quoted: 2952 Post(s)
Liked 3,106 Times
1) tops
2) ramps
3) hoods
4) deep into the hooks ("Belgian style")
5) returns
*6) IAB (experienced users only)
#354
Quoted: 980 Post(s)
Liked 776 Times
Anyone that cannot understand the usefulness of drop bars is a fool.
The only things more foolish are all the flat bar riders I see on the road all hunched over trying to get more aero when they hit a patch of wind or a stretch of downhill.
You knuckleheads all know who you are
Likes For pickettt:
#356
Quoted: 1324 Post(s)
Liked 927 Times
Bar-ends on a flat-bar are there to mimic that position of the hoods on a drop-bar. The hoods on a drop -bar came BEFORE bar-ends on a flat-bar or indeed even before flat-bars.
So bar-ends are a must on a flat-bar in order to mimic the same position that you can easily get on a drop-bar and with a drop -bar the brake levers are still within easy reach of fingers when riding on the hoods. Not so when riding on bar-ends on a flat-bar. People put bar-ends on flat-bars because they want an alternate hand position just like there is on a drop-bar.
You ca easily swing a bike back and forth under you when riding on the hoods plus the hoods are easier to grip when hands are sweaty.
Having full braking with one or two fingers on a flat-bar depends GREATLY on the type of brake and how well set up that brake is.
With a drop-bar you can get a very good aerodynamic tuck by riding with hands on either the hook or bottom of the bar. Very hard to do that on a flat-bar even with bar-ends.
Cheers
#357
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Dude, you broke the chain!
In other words, there's no disputing the usefulness of drop bars in competitive cycling. Commutess and many others were debating the usefulness of drop bars for non-competitive cyclists, i.e. the rest of us, the "others", the dullards who so brazenly dare to muddy up the purity of the temple that is Bike Forum. Which is the whole point of this thread, if I recall.
Likes For ThermionicScott:
#358
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
If the brake is out of touch in the drops, you need to adjust the brake lever reach. If you can't get them close enough for bottoming out the brake on the bars, you need to fix your cables/pads/wheel true so you're not running a huge pad/rim gap.
IMO, if going downhill in the drops (or hoods) folks would benefit from making sure they have the outer foot down and the inner foot up. Weight on the outer foot. Weight on the inner hand.
If you must brake more mid turn, apply it steadily. You'll drift outside, but that's better than grabbing a handful mid-turn. Look where you want to go next, not 10 feet in front.
Also, the drops may be a safer option for going over really rough road sections. You have your hand all the way around the drops, not so much on the hoods.
Just me talking. Carry on.
#360
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
The only thing bar ends and hoods have in common is that they face forwards (and a lot of bar ends don't even do that). The actual riding position of them is totally different. Bar ends on a flat bar are much farther apart, and much further back relative to where riding in the hoods puts your hands.
#361
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
It's a universal issue around BF that too many members - especially the small but influential I've-been-the-coolest-dude-that's-ever-hopped-onto-a-saddle-for-50-years crowd - have been allowed to let their god complex run rampant.
#362
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
I like drop bars because they make me more aero.
#363
Liked 2,568 Times
Careful, bud. I kept my post non-specific because everybody (hint, hint, that includes you) is prone to it.
#364
Quoted: 792 Post(s)
Liked 1,494 Times
Likes For sjanzeir:
#365
climber has-been
Quoted: 3427 Post(s)
Liked 3,563 Times
EDIT: Make that 5 positions, forgot to list the hoods.
Flat bars with bar ends? I count two positions, one with access to braking and shifting.
Last edited by terrymorse; 09-17-19 at 11:33 AM. Reason: added hoods to list of positions
#366
climber has-been
Liked 3,563 Times
I find the opposite: increased braking in a turn reduces the turn radius, and getting off the brakes in a turn increases the radius. Unless I adjust the steering (and lean angle) to compensate.
#367
Quoted: 18410 Post(s)
Liked 15,531 Times
#368
Quoted: 792 Post(s)
Liked 1,494 Times
#369
Liked 15,531 Times
#370
Quoted: 792 Post(s)
Liked 1,494 Times
#373
Liked 15,531 Times
#374
Quoted: 792 Post(s)
Liked 1,494 Times
#375
Liked 15,531 Times
Likes For indyfabz:
