Adding fenders to a Cannondale R600
Quoted: 21 Post(s)
Liked 5 Times
I have an old 2001 Cannondale R600 that I use to commute and the rain is starting to come down and I realize I desperately need fenders. How easy are they to buy and install for such an old bike? Can you just get generic ones? I read that some racing bikes don't have mounts for fenders but I can't find any other information.
Any info is great thanks guys.
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
Generics are available, even for road bikes without mounting eyelets. Try Amazon.
The only potential "gotcha" would be tire clearance with the seat tube. On some bikes it's really tight. I'm sure a seat-mounted fender would suffice to keep your backside clean.
Quoted: 21 Post(s)
Liked 5 Times
So I bought these road fenders for my 25mm tires...
Only problem is that I have no hole for the front fender crown... installation says it there should be a hole but it appears it's already being used by the brake pad mount.
Am I out of luck with these?
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Pretty typical procedure for installing fenders on caliper-brake bikes for the last 40-50 years or so, only the shapes changed.
Quoted: 5223 Post(s)
Liked 3,579 Times
yay, fender season! take your time mounting them, it can be frustrating. don't rush it. you may need parts that didn't come with the fender. there're all kinds of miscellaneous extra parts for fenders. here's hoping your install ins't too painful!
this if from a cpl days ago, how's it going?
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Rear brake bridge clearance is also a problem on some Cannondales.
Quoted: 21 Post(s)
Liked 5 Times
I hope I can fit fenders on this bike I got utterly soaked the other day on my ride home from work I'm going to look at it again with my Dad sometime soon but I may just drop it at a shop and see if they can tell me definitively if I can mount them or not.
Liked 3,579 Times
if that mount is a slot you can just push up on the fender. if it's a single hole, & you push up on the fender & the hole don't line up, then you can drill a new hole on the fender mount tab, if there'es room. if the place for the new hole is too close to the hole that's there now, you can use a tool to make that hole a slot, allowing you to push the fender up. if you don't many tools & feel uncomfortable with this kind of work, then certainly visit your bike shop. they can either mount the fender for you or make other suggestions. more pics would help us understand what you are looking at. good luck!
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
With fenders and racks, you often have to be ready to modify (drill, grind, cut, bend) the metal mounting brackets to get them to fit cleanly. When trying to mount fenders on a road bike with limited tire clearance, the process can be a little more arduous. Especially the front fender where the unmodified mounting bracket will either push the fender down to far or reach up so far it interferes with the headset. Then there is the problem of tires clearance - you might be able to fit 26mm tires on your road bike, or you might be able to fit fenders, but probably not both. If road conditions allow, you might need to go to a 23mm tire, and modify the fender so that it takes as little space as necessary where it might interfere with the tire.
Options:
Clip-on fenders or mudguards or 'raceblade' style fenders will be easier to mount without interference, but will provide less protection from spray than 'full fenders'.
Options:
Liked 3,579 Times
right & I've read about road bikes using fenders like this to help deal with the tight clearance under the fork crown
https://www.amazon.com/SKS-Germany-1...39193023&psc=1
kg1
8
06-12-10 10:58 PM
