Chamois allergy
Bikes: Trek 7.9
Chamois allergy
Hello, I am wondering if any road riders have an allergy to Chamois, the pad.
I have been riding for 6 years using Bontrager race shorts. Suddenly, according to my dermatologist I have an allergy to the material.
I have used Specialize shorts as well.
I have always used Chamois Butt'r to reduce friction even on short 10 mile rides.
Since this episode I tried Assos. No improvement.
Is there anyone else who has experienced something like this? Please say yes!
As a side note:
I am always out of my shorts ASAP, I take episomes baths and wash my shorts after each ride.
I have changed detergent from Tide to a natural product, cold water, hang dry.
Okay, you get the point.
I usually ride 60-to 120 mins and use a quick pack Chamois Butt'r when I feel the rawness.
I am 69 yrs old and in very good physical condition (mental is another matter- and this doesn't help).
So, that the post. Any serious (or hilarious) responses are welcome, I'm not proud or vain.
jlj
As a side note:
jlj
Bikes: 1998 Trek 8000SL, 2013 Madone 3.1, 2016 Trek Fuel EX8 27.5
Quoted: 12 Post(s)
Have you looked for padded shorts that the pad is made of another material?
Bikes: 15 Giant anyroad 1, 16 Trek farley 9.6, 15 Trek domane 5.2 c
Quoted: 49 Post(s)
I've had problems with certain ones seem to be related to colder weather I usually wear sport underwear if I think there might be a bad reaction. So your not alone I acually put a glove down my pants once because my junk was turning bright red.
Pads are usually synthetic and not subject to allergies. Are you sure you're not allergic to the chamois cream? I haven't used cream since the last time I used *real* chamois.
The thing that stands out in the OP for me is that he is riding relatively brief periods on the bike, but is suffering from chafe. Surely there is a bike fit issue in there. Maybe that should be checked. To me, there should be no need whatsoever to use any type of cream on the butt for such short rides.
seedsbelize probably has a good point. The OP should try riding in athletic compression shorts without a pad to see if that makes a difference.
I always thought Bontrager and Specialized were so inextricably linked that their products were one and the same and that might be why there is a similar reaction to both pairs of shorts. Also, it might be time to try something like adding borax to the washing mix, or at least some vinegar to the rinse cycle (without softener) to help kill of any bacteria that may be lingering because of the cold wash.
Bikes: 2005 Gazelle Golfo, 1935 Raleigh Sport, 1970 Robin Hood sport, 1974 Schwinn Continental, 1984 Ross MTB/porteur, 2013 Flying Piegon path racer, 2014 Gazelle Toer Populair T8
Quoted: 396 Post(s)
Liked 8 Times
I tend to sweat a lot down there, and tight fitting clothes makes it worse.
I've found loose, lightweight clothing that allows air to circulate without any additional pads to hold in heat, and using powder solves the issue.
Could be a latex allergy. They tend to increase over time.
Could also be a metal allergy as metal ions are showing up to fight microbes. I cannot wear silver myself, I get a rash.
Quoted: 175 Post(s)
Expired Member
Quoted: 3665 Post(s)
Liked 5,415 Times
You need to rule out the butter. Ride w/o or use Body Glide. Actually I prefer the Gold Bond similar product available in the Walmart pharmacy section.
Quoted: 1364 Post(s)
Liked 1,677 Times
A causal swimmer growing up I began swimming daily in my late 20s. After four years I developed an allergy, or sensitivity to chlorine that persists to this day. It affects me primarily on my sinuses, but sometimes causes a mild rash on my cheeks, chin and chest. I found antihistamines help, as did nasonex and other steroidal sprays. I also had a girlfriend who developed an allergy to a pet after 5 years.
Quoted: 5224 Post(s)
Liked 3,581 Times
do you really need all that lube? have you tried thinner lined trishorts? instead of the thicker conventional liner? I eventually migrated to & have remained with these. the price has come down
ZOOT Men's Performance Tri 9" Shorts $45.57
https://www.amazon.com/ZOOT-Performa...rts&th=1&psc=1
It has been a long time since the liner/pad was actually made of animal leather but I still treat them the same and wash the shorts in Woolite, which is a detergent associated with hand-washing delicate items. The idea is mainly soak the shorts and then... rinse thoroughly to get out all of the detergent.
Quoted: 663 Post(s)
Liked 496 Times
This may or may not be related. I've had rash resulting from the elastic in bike socks and from the lower leg area of bike shorts. I've not been able to find a specific cause and had to throw the offending items in the trash. The shorts were Voler. I was hoping to support a domestic company but when I inquired of the company for a possible cause I got no response. These days there are all sort of chemicals used in manufacturing and I seem to be allergic to one or more of them. I'm using Pearl Izumi now and have also used Castelli with no rash.
Quoted: 4806 Post(s)
Liked 3,927 Times
My first thought thought is to change things. Maybe one at a time do you can (perhaps) pinpoint the problem. First I would change the Chamois Butt'r to something else. I'd go with Bag Balm first. Highly unlikely that if the problem is in the butter that Bag Balm contains it also. (Bag Balm is also cheap and a good product to have around foe a number of applications.)
Stlll have problems? Go to another shorts manufacturer. I'd try Segoi. Quality stuff and being Canadian, they may well get their materials from a different supply chain.
This approach will have you spending the small dollars first. Bag Balm is less than $10. Shorts are $50-150. Doctor's visits cost (somebody) more.
Ben
Ben
Quoted: 185 Post(s)
Liked 36 Times
As a side note:
jlj
As a side note:
jlj
I've known wool to cause a hive type reaction once sweat soaked, if it was a dark colored fabric. If it was white/natural, no issue at all.
Bikes: Trek 7.9
Thank you for the response. In retrospect it was stated by the dr that it was a suspected cause, so there was a Rx for a steroid ointment I have been using. I have a follow up Wednesday with "HER", (I'm not embarrassed) we'll see what if anything changes. The Rx has seemed to help butt (pun?) 90 mins in yesterday and 60 on the fatt bike today on the trails was enough for me to saddle off.
I know this is a Road Bike Forum but as I am sure many ride mountain as well I will tell you that after todays ride I had 2 ticks on my socks. April, 17. Very unusual but so is a chamois rash.
Good riding to all and if there is a definitive solution I will post back.
jlj
jlj
Quoted: 2604 Post(s)
Liked 1,928 Times
+1
What are the odds three different brands of shorts all have the same outer surface of chamois? (Assuming they're not all outsourced from the same supplier, of course!) Since OP has, apparently recently, bought new shorts from two different suppliers, I think it's unlikely the foam has started leaking through all three brands.
Bikes: Trek 7.9
Rowen, brief period on the bike is all relative, I do understand that century and half century road riders consider 90 mins, a short period, but my 69 year old body works hard at that 60-120 mins and I thank God I can do it, both road and off road. Yes there are many factors, saddle, fit, shorts, I just posted what the Dr. spouted and thought, hmm, maybe there is another place to get the fix. All these suggestions are valid and I DO appreciate them.
The clock is ticking and I wanna keep peddling. Again thanks to all, and to all a good night. :-)
Quoted: 642 Post(s)
Liked 1,526 Times
If it is really an allergy then whether or not you're cycling shouldn't make a difference. Try wearing the shorts while you're just doing regular activities for the same amount of time and see if you develop the same symptoms.
Did the dermatologist run a panel of tests on you? I spent a period of time with my HMO dermatologist trying to deal with a hand rash. I finally got referred to someone else and he knew what it was. Also prescribed a steroid creme. Side effect of the creme is thinning of the skin at the application site.
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
Underwear.
Seriously, not everybody wear padded shorts, none of my MAMIL outfits have padding.
In Walmart there is a brand of underwear called Life. They have a couple of those that are made from a light microfiber material. I imagine it would insulate your apparently sensitive parts from the offending padding without adding bulk.
Despite what you doctor says, I doubt you really have an allergy to chamois.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
If your episome baths involve yeast or E. coli plasmids, that could be your issue. I have never heard of this sort of thing being theraputic though, but there are some weird health regimens promoted on the i-net. I'd recommend forgoing them in the future.
Doubt that you have an allergy though.
Quoted: 1109 Post(s)
Liked 1,200 Times
I know that we're supposed to use bike shorts without underwear - which I do. But in the past, I bought (and still have) some seamless synthetic briefs, probably from Performance. They worked fine. You might try that.
In spite of my expert advice, my wife always wears cotton underpants with her bike shorts and never complains about any problems. She's ridden as far as 50 miles in a day.
So, maybe just for the heck of it try wearing underwear.
Quoted: 278 Post(s)
Liked 71 Times
