Upgrade
Old 06-13-19, 12:20 PM
monstorr
Bikes: Cannondale CAADX, Gravity CXD
Quoted: 16 Post(s)
Liked 3 Times in 2 Posts
Upgrade
Hi Everyone, just had a quick question that would probably be answered very easily.
I would like to upgrade the bike to have a 2x instead of the current 3x on there. I aim to ride this bike for cyclocross so im guessing a 46/36t? The bike has 8 speed STI shifters and a 12-25t cassette in the back.
Are there any supporting mods I should do before/after changing the crank?
Thanks in advance for any tips!
-Richard
monstorr is offline
Old 06-13-19, 12:46 PM
caloso
caloso's Avatar
Quoted: 2247 Post(s)
Liked 951 Times in 496 Posts
I don't think there's much to do other than make sure your lower FD limit is set so you don't accidentally shift your chain off. You'll have useless click, but other than a totally slack cable, I don't think there's any issue.
caloso is offline
Old 06-13-19, 01:44 PM
KCT1986
Quoted: 26 Post(s)
Liked 3 Times in 3 Posts
Depending on what type of STI you have, you can decide which shift positions to use, small to middle or middle to large. Then use the FD limit screw to lock-out the unused position.
The differences between the position (S->M) vs. (M->L) are:
*Trim position availability, if you have and/or want them.
*Cable pull/tension, with Shimano STI the SM shift pull a little more cable than the ML shift. This is designed-in to take up any extra slack. This may help shifting speed and allow you to use a lower tension in the small ring.
KCT1986 is offline
Old 06-13-19, 04:26 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1111 Post(s)
Liked 495 Times in 361 Posts
A possible downside to locking out the M>L shift is that if you forget and force the shift you may jam the ratchet such that you cannot shift back down; you could even damage the mechanism.
Personally I would not consider going from 3x to 2x an upgrade but others might; I would miss those low range gears, and to get the same range out of 2 rings would necessarily spread out the remaining gears so the gaps would be bigger.
dsbrantjr is offline
Old 06-13-19, 05:54 PM
CyclingFool95
Bikes: 1987 Pinarello Montello, 1995 Litespeed Classic, 1996 Colnago Master Light, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record
Quoted: 118 Post(s)
Liked 72 Times in 50 Posts
I was very excited to build up my 8 speed bike with a triple (it's Campy Chorus). Didn't take me long to decide I hated it and switch to a compact crankset.
YOu might need to consider chain length depending on your new gear set.
CyclingFool95 is offline
Old 06-13-19, 06:09 PM
caloso
caloso's Avatar
He said he's using the bike for cyclocross so on anything you'd need an ultra-low gear, you're probably better off dismounting and running up anyway. There aren't a lot of mile-long grinders on CX courses, just short steep pitches where you want to carry speed and muscle over it, if possible. Dismount and shoulder if not.
caloso is offline
RockiesDad
Bicycle Mechanics
3
04-11-19 03:33 PM
danielrbaer
Bicycle Mechanics
3
11-15-13 01:18 PM
Greenfieldja
Bicycle Mechanics
19
05-06-13 06:46 PM
Peyote
Bicycle Mechanics
9
06-02-10 05:36 PM
