Which dremel/rotary tool do you use?
Old 04-13-20, 09:29 AM
tkamd73
Bikes: 1984 Schwinn Supersport, 1988 Trek 400t, 1977 Trek TX900, 1983 Bianchi Champione del Mondo, 1986 Trek 400 Elance, 1978 Raleigh Supercourse, 1991 PDG Paramount OS, 1971 Schwinn Sports Tourer, 1985 Trek 670
Quoted: 313 Post(s)
Liked 259 Times in 162 Posts
Originally Posted by thinktubes View Post
While I use the cutting wheel for cables, I've found that it melts the plastic liner, so I need to immediately chase it with an awl, before the plastic cools.
Yup, it does tend to melt the plastic liner a bit, but still works better then any mechanical cutter I’ve tried.
Tim
tkamd73 is offline
Likes For tkamd73:
Old 04-13-20, 09:35 AM
crank_addict
Quoted: 1361 Post(s)
Liked 386 Times in 252 Posts
For home hobbyist and minimal duty use, a tool that doesn't take up space, a Dremel rotary is well worth it. They've been offering the portable jobbie for decades, regardless where made, do have pretty good reliability even on their cheapest units.
The Harbor Freight units might get you by but don't expected longevity and have really poor armature shafts and bearings. Discounts, for under $10 it might do for rarely using.
Last Christmas, Aldi foods had a nice kit with flex shaft, variable speed, assortment of arbors - wheels of all type. $20 or something near that. By far the best package for the money. Armature tolerance is on par with Dremel though not sure of longevity.
Though at the shop have commercial grade setups, and pneumatic with variable. Really a luxury. Needed for carbon fiber work.
Btw: Caveat using your electric tool working on carbon fiber.
crank_addict is offline
Old 04-13-20, 09:56 AM
squirtdad
squirtdad's Avatar
Quoted: 1258 Post(s)
Liked 487 Times in 358 Posts
old monkey ward (montgomery ward) with a cord. mostly cut off wheels (get the dremels shaft that allows easy on off of the wheels) not used much, but invaluable when needed (bikes and general use)
squirtdad is offline
Old 04-13-20, 03:09 PM
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 912 Post(s)
Liked 511 Times in 354 Posts
My corded Dremel of about 3 years has done a lot and never fails. I even used it to cut a stripped and stuck crank arm. Used about 2-3 cutting wheels but it did it.
2cam16 is offline
Old 04-13-20, 06:07 PM
canklecat
canklecat's Avatar
Quoted: 3928 Post(s)
Liked 1,677 Times in 1,082 Posts
For cutting cables/housings, the Jagwire cutter includes an awl in the end of one handle for rounding out a slightly ovalized cut. But it usually cuts housings cleanly enough it isn't a problem.
I do occasionally file the end of a cable housing after cutting, but I don't drag out the moto-tool for that. I just use a file. A little utility case drawer of small metal files and diamond hones takes up a fraction of the space of a moto-tool.
canklecat is offline
Old 04-13-20, 06:08 PM
Salamandrine
Quoted: 2310 Post(s)
Liked 555 Times in 399 Posts
There are currently two Dremels in my tool bin. I don't even know which ones I have. They are both variable speed and corded.
IMO they have pretty limited use for bike stuff. They definitely work pretty well for cutting stranded modern housing. That's the main thing. They can be pretty effective for polishing in tight spaces and complex parts. For instance I last used mine to polish up some Lyotard pedals. Generally though, it's faster and easier to polish aluminum bike parts by hand. (not counting a commercial type bench polisher with a big buff)
The main bit/accessory that is useful for bikes is the EZ Lock mandrel. Those work very well with the new style reinforced cutting wheels.The little micro EZ lock cotton buffs work great too. Occasionally you may find the sanding drums or the various grinding bits useful.
The older style cutting wheels and buffs were really not very good.
Salamandrine is offline
Old 04-13-20, 06:26 PM
mechanicmatt
Hoards Thumbshifters
mechanicmatt's Avatar
Bikes: '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '07 Stumpjumper
Quoted: 157 Post(s)
Liked 161 Times in 99 Posts
I have a Kawasaki version that was from Sam's or Costco like 10 years ago, used it a lot to remodel a house. Not much in way of use for bicycle. But it is handy for cutting small metal things at times. It's corded and variable speed which is nice but I don't know if it's a tool to spend lots of money on or not.
mechanicmatt is offline
Old 04-13-20, 06:59 PM
satbuilder
Bikes: 1969/70 Legnano Roma, 1971 Guerciotti, 1972 Cinelli SC, 1973 Bianchi Team, 173 Colnago Super, 1974 Marnati Corsa, 1974 ish Motobecane CT, 1971 Mercier 300, 1977/78 Colnago Mexico, 1982 Pinarello Italia,Tesch S-22, 1983 Peugeot Mixte
Quoted: 206 Post(s)
Liked 47 Times in 31 Posts
I have a couple different rotary tools which have served me well over the years for different applications.
Dremel 332 Moto Flex which has the built- in flex shaft and a foot pedal speed control.
Foredom Model S. Another flex shaft tool but heavier duty.
Wells Dental Engine. These have limited bit sizes, but if you look around you can find adapters and collets for the hand piece. If you watch the auction block you can find these reasonably priced. They are belt driven with a foot pedal speed control, but the hand piece is very comfortable.
satbuilder is offline
Old 04-14-20, 06:53 AM
JaccoW
Overdoing projects
JaccoW's Avatar
Bikes: Batavus Randonneur GL, Gazelle Orange Excellent, Gazelle Super Licht, Gazelle Grand Tourist, Koga-Miyata SilverAce, Koga-Miyata WorldTraveller
Quoted: 620 Post(s)
Liked 598 Times in 384 Posts
I have a dremel with all kinds of attachments that I bought a couple of years ago. I mostly use it for cutting cables and sawing off bolts in places that are hard/impossible to reach otherwise such as on the inside of fenders.
Last month I used it to cut a heavy duty lock off a neighbour's bike who lost the key to it.
JaccoW is offline
Old 04-14-20, 08:19 AM
Glennfordx4
Holy Spokes it's Batsman!
Glennfordx4's Avatar
Quoted: 84 Post(s)
Liked 40 Times in 28 Posts
I have two that I use, a vintage model 380 Ver speed that my Grandfather bought new either in the late 50's or early 60's, I have everything that it came with when new. I wish I could show you guys the things he has made with it but don't have any pics like a complete Chess set that looks store bought, a 10" Adjustable Wrench that looks and works like the real thing along with a copy of his Stanly Claw Hammer and the last thing he was working on was a Clock, all the gears and moving parts are made out of wood. I also use a older model 395 most of the time, I have tons of attachments for both that I have picked up used here and there plus tons of bits, grinding, cutoff, drilling, carving, polishing. I picked up the 395 in a huge Dremel case that holds both tools and most attachments from a thrift store for $15 yrs ago, I have the modern and vintage Stands for both units for use with the Flex cables. The one attachment I don't see often is the generated light kit that I use all the time when drilling with it. I use my Dremel tools for a ton of things but not a ton with bikes.
Glenn
Glennfordx4 is offline
Old 04-14-20, 08:25 AM
Glennfordx4
Quoted: 84 Post(s)
My Cousin got me the EZ Lock cutoff wheel kit for Xmas and it really works great.
Old 04-14-20, 01:21 PM
Last ride 76
1/2 as far in 2x the time
Last ride 76's Avatar
Bikes: Yes, Please.
Quoted: 498 Post(s)
Liked 278 Times in 219 Posts
Originally Posted by Doug Fattic View Post
How much money are you willing to spend and what are you wanting to do? I use a jeweler's saw and hand files, a battery powered Dremel as well as a much more powerful one with a power cord. And I also have a Foredom with a separate hand piece connected to a powerful motor with a rotary cord. The foot pedal controls its RPMs. If one can afford it that is the best tool. I use mine to cut blank lugs into shapes. So again the question comes back to you, what do you want to do with it?
I have never blamed my tools for poor execution.
I have the same, minus the corded dremel, plus a 6" bench grinder/polisher. I do want to invest in a broader selection of jeweler's files.
I have not used the Foredom, (bought 1/2 price at Lowes), as much as I expected. The battery Dremel combined with file work is surprisingly effective, if a bit slower. I find (like with wood) it's difficult to replace aluminum, once too much has been ground or cut away...)
I have found the stability of the bench grinder very helpful. I am sure I would use the Foredom more if I had a proper vise again. (Sounds like a plan).
I have never used the Dremel with a cutoff wheel for cables, doh!
Last ride 76 is offline
Likes For Last ride 76:
Old 04-14-20, 01:45 PM
Salamandrine
A little reminder: when cutting things with a Dremel and a cutting wheel, please use eye protection folks. The new wheels don't shatter when you look at them funny like the old ones did, but they still can shatter some times.
Old 04-14-20, 06:34 PM
merziac
merziac's Avatar
Quoted: 2087 Post(s)
Liked 1,134 Times in 786 Posts
HF air 1/8 in. Micro Die Grinder, more power, way more maneuverability, very controllable.
https://www.harborfreight.com/18-in-...kit-60244.html
merziac is offline
Old 04-14-20, 08:59 PM
Chombi1
Chombi1's Avatar
Quoted: 1153 Post(s)
Liked 172 Times in 132 Posts
For many years I used a Dremel model 380-5 with variable speed, that I inherited from my eldest brother, back in 1992 ish.....
It was a very basic tool, as far as rotary tools go these days, but it is rugged and never failed to do the job for me, with the few bits that came with it. Till about two years ago when it started to seem to have problems with its power chord where it goes into the tool and I was getting intermittent pulsing when I used the tool.
So it gave me enough excuse to upgrade to a new Dremel..... a top of the line model 4300 Dremel (Now a subsidiary of Bosch) with all sorts of bits and bobs and even an LED light attachment......
So there it is, in the big two tiered tool box I got specially tor it, to replace the chintzy blow mold case the 4300 came with.......
But then.......
Like many Dremel owners, I kinda got carried away and bought all sorts of Dremel accessories, like a mini drill press, a flex attachment, and even a Dremel ball vise.......
I did eventually get to use most of the accessories with the new Dremel rotary tool on some projects. They work pretty good as long as the projects don't get too heavy, but I'm now always looking for projects I can justify the things with.
I still have the old model 380-5 which sits at the bottom tier of the tool box (can be seen to the right of the third pic). Turns out that there was just a lot of debris caught in one of the electric motor brush holders that was not letting it contact the armature properly. Cleaned it up and it works perfectly again. It's been relegated to the more messy projects though, Like grinding off old glue from tubular rims. But the old Dremel feels like it would just keep going on and on forever. Frankly, I don't think my new, fancier 4300 would last as long as the old 380-5......
Forgot to note.... I also bought one of these to use when I'm using my Dremel....
I don't know how I managed to not blind myself all these years using my Dremel, despite having glasses. A lot of things from the tool like wire filaments from the rotary brush tips flying off (always felt them hitting my face) could have killed my eyes, but I guess I was just lucky. Decided that I cannot tempt my luck any longer, so I got the face shield late last year. Works really well!
Chombi1 is offline
Old 04-15-20, 07:09 AM
BFisher
Quoted: 422 Post(s)
Liked 832 Times in 422 Posts
This thread reminded me of a site I recently visited. Guy built himself a Dremel 3D pantograh.
https://woodgears.ca/pantograph/dremel.html
BFisher is offline
Old 04-15-20, 07:29 AM
Kabuki12
Kabuki12's Avatar
Bikes: 1973 Windsor Profesional,1976 Kabuki diamond formula with full Campy, 1977 Raleigh Competition GS , 1971 Stella original Campy equip. 1978 Raleigh Super Grand Prix, 1972 Italvega Gran Rally ,1972 Super Mondia Special,Medici Pro Strada,Colnago
Quoted: 307 Post(s)
Liked 434 Times in 291 Posts
One of the only times I used the Dremmel on my bikes was to grind the spokes that were protruding from the spoke ends on the rim before putting down the rim tape. The rear wheels that I have laced have this situation due to me using the same length spokes for both the drive side and non drive side. I used a ball shaped cutter that was in the kit. It worked great without any damage to the rim or spoke end. Just a steady hand and that comes from 45+ years of tool grinding! Joe
Kabuki12 is offline
Old 04-16-20, 07:38 AM
easyupbug
Quoted: 249 Post(s)
Liked 101 Times in 79 Posts
Just yesterday I again grabbed the cordless Dremel and recalled this thread. I have a Dremel handing near the bench with the flex shaft extension permanently mounted and a full Dremel kit in it's own tool box but even with the reduced power of the cordless I grab it more often than the others, just more convenient w/o a power cord and the tiny battery holds up well.
easyupbug is offline
Old 04-16-20, 09:49 AM
clubman
Youngman Grand
clubman's Avatar
Quoted: 1566 Post(s)
Liked 642 Times in 433 Posts
I've got this smallish rotary tool that reminds me of something made in the 60's. Full metal alu casing and light. One speed, seems to be around a 3 or 4 on a Dremel tool but not a lot of torque. The collet is over sized and takes threaded bit's while the top of the tool shaft looks like it would accept a flexible shaft.
It's also remarkably quiet. Wish I had some some accessories to fit but the collet is about 3/8". The lock ring is a friction fit.
clubman is offline
Likes For clubman:
Old 04-16-20, 09:55 AM
Velo Mule
Velo Mule's Avatar
Bikes: Trek 800 x 2, Schwinn Heavy Duti, Electra Cantilever, Schwinn Traveler, Schwinn Le Tour Luxe, Schwinn World, Schwinn Continental
Quoted: 325 Post(s)
Liked 239 Times in 181 Posts
So far, I haven't used the Dremel on a bike. But it does get plenty of use around the house and on other projects. For the cable housings, I cut them with a cable cutter and square them up on a bench grinder.
It would be the perfect tool for a wheel with all spoke that are too long. If it were only one or two replacement spokes, I'd use a file.
Oh, so to answer the question, I have a Dremel branded one that is multi speed and plugs into the wall outlet.
Velo Mule is online now
Old 04-16-20, 09:59 AM
Velo Mule
Velo Mule's Avatar
Quoted: 325 Post(s)
Thanks for posting this. That is an electric eraser. From back in the days when the designs were tuned out with pencil and velum. And companies hired Draftsmen.
A rubber eraser, typically the white colored one would go in the collet and sliding the collet ring toward the end would sinch the eraser in place.
Likes For Velo Mule:
Old 04-16-20, 10:04 AM
clubman
Youngman Grand
clubman's Avatar
Cool, thanks. Gonna start erasing things now.
clubman is offline
Likes For clubman:
Old 04-16-20, 08:26 PM
Chombi1
Chombi1's Avatar
I had something similar but with a plastic body.
Can't remember who made it (Maybe Steadtler?), but it was light grey.
It was a must-have when I was in college in the School of Architecture, which was just right at the very start of when CAD programs were being developed, so most of our drawings were still on vellum and mylar, drawn with technical ink pens or pencil. Went through miles of those long cylindrical, white eraser inserts from Steadtler that went into those electric erasers.
Coincidentally, I also had fun with it during slow days in school by attaching all sorts of self made grinding and drilling tips on it. Even remember using it as a fan by attaching a four bladed RC plane propeller on it!
Used the same electric eraser for the whole 5 years I was in college. I bet it's still somewhere deep in my junk in the garage somewhere and would still work if I plug it in.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
Chombi1 is offline
Old 04-17-20, 07:16 AM
branko_76
branko_76's Avatar
Bikes: ........................................ .....Holdsworth "Special"..... .......Falcon "Special".......... .....Raleigh "Super GP"...... ........................................
Quoted: 518 Post(s)
Liked 414 Times in 265 Posts
I have one hanging off the edge of my Mayline drafting table which now, instead of vellum, has a monitor, keyboard and mouse sitting on the Borco...
oh, no Dremel tool in my shop. Lots of files, emery cloth, hack-saw blades, snips and various manual cutters.
branko_76 is offline
Old 04-17-20, 05:37 PM
TiHabanero
Quoted: 1156 Post(s)
Liked 439 Times in 241 Posts
Had a corded Dremel that made it through two frame builds, then bearing puked on it. Replaced with a Rotozip upon recommendation from my brother. Although it is much larger in diameter than the Dremel, it is very well balanced and spins better than the Dremel did when it was new. Much better quality. I use it for cutting slots into stays and grinding down filler when I over fill a joint. So far it has done three frames without a problem. Have dropped it from the bench several times and that has had no effect on it. Good tool, and much better than the Dremel that it replaced.
TiHabanero is offline
