saddle problems
saddle problems
saddle problems I've just bought a roger black spin bike put a gel cover on it but omg its so painful any tips outthere please
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,593 Times
Thread moved from Introductions forum to General Cycling Discussion forum.
Likes For Gconan:
I think I know nothing.
Quoted: 233 Post(s)
Liked 290 Times
No pain no gain.
It took this mortal about 4 months of daily seat time to get somewhat comfortable on my fluid trainer. And I had been riding bikes outside for many months before that. I guess you could say there really isn't a product that you can buy that will eliminate all discomfort without any built-up endurance. You might find a saddle that helps but it's probably still going to take some time to build up the endurance/muscles. Hard work will come with a payday the only unknown is what day that is and how much labor is required.
Bikes: Norco search xr
Quoted: 198 Post(s)
Liked 146 Times
Perhaps you could swap the uncomfortable one for a different shape? Perhaps where you purchased it they sell other seats? One shape does not fit all. Can this indoor trainer accept a regular bicycle seat? Or are you stuck with something from that manufacturer? I can certainly sympathize. On my 3rd ride on two of my bikes I was in so much pain I wasn't going to be able to ride anymore. I tried another seat and the godless pain went away immediately. I suggest to try another seat with a different shape.
Likes For Gconan:
there are so many "which saddle?" threads going, on the internet, they exceed the several thousand different saddles being made..
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Why can't someone in charge just tell us what saddle we must use?
Likes For Phil_gretz:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
you don’t need one until one day you do, and you have to save the best ones for the professionals so their supply doesn’t run out, Because we could have made enough and saved them, but we didn’t. Soon, using one or not becomes a way of signaling your virtue to your chosen tribe
Disco Infiltrator
Liked 2,105 Times
The saddle in the pictures does look a little bit strange, but I’m not sure if it’s just the color of the cover. Anyway, it’s just a regular bike saddle, so you can replace it with anything you like. If your seat height is well below the handlebars, try something wider. The above people are right that it stops hurting, but you don’t have to inflict the max pain on yourself until it stops.
The next saddle I buy is going to be a Fabric brand. Not because I have especially high hopes that it will be better than the last one, but because they sponsor a paralyzed rider who they continue to support since his injury, even setting him up with university and corporate R&D for his seat on his e bike and hand cycles, and I think that’s pretty cool.
Genesis 49:16-17
Genesis 49:16-17
Bikes: Trek Domane SLR 2019, Trek Trek Madone 5.1 (2011), Trek 1400 (1991)
Quoted: 47 Post(s)
Liked 74 Times
Gconan is correct, dump the gel cover. There are many aspects to getting a saddle position comfortable. Have you tried any adjustment to seat height, angle or forward/backward position? Do an internet search for "Sheldon Brown Saddles" to start your quest for bicycle seat nirvana. Getting a comfortable fits is a trial and error effort. Your handlebar reach and height may also be a factor.
Quoted: 195 Post(s)
Liked 207 Times
I never had any pain on leather saddle but you'd get some arguments on that so I won't go there.
The point is, different butts like different saddles. Terry makes some good comfortable saddles. Ideally I'd say try as many as you can but that's not so easy these days. Too soft is never good though. The compression spreads to soft tissue that isn't meant for support. Keeping just your sit bones cuddled is your goal. Lowering the handlebars takes weight off your butt and puts in on your hands which can create its own problems. That is more easily fixed however. Lastly some have suggested it takes a while for your body to get used to cycling. That's true but I don't think pain should be in the equation so make sure your fit is good, your saddle supports your sit bones and then, shut down at anything approaching pain for 5 min or so at least.😁
Likes For Cycle Tourist:
Quoted: 29 Post(s)
Liked 33 Times
First thing, measure your “sit-bones” so you get a proper width saddle. Realize that any bike that is fixed in place will likely get uncomfortable after awhile. You aren’t moving around as much or out of the saddle as much as when out on the road. Chamois cream might buy you some time before discomfort sets in. It is the nature of the beast.
Quoted: 1943 Post(s)
Liked 2,164 Times
I use a WTB Pure V on my mountain bikes. I liked it so much I am using one on my road bike.
I only brought this up since you will be riding off-road.
John
John
Likes For 70sSanO:
