Replacement pads Modolo
Old 12-30-19, 02:18 PM
CTony
Quoted: 13 Post(s)
Came across a pair of Modolo Speedy brakes and handles would look good on my Faggin bike.Im in need of pads LBS donít to carry replacements.any help?Thank You
CTony is offline
Old 12-30-19, 02:51 PM
SurferRosa
SurferRosa's Avatar
Bikes: old school 531c & Campy
Quoted: 1079 Post(s)
Liked 753 Times in 465 Posts
If they still have the original holders, you can find kool-stops on ebay for $20ish.
I did this recently with my Speedys, and the bike stops on a dime.
I used a spray oil to ease the pads in/out, else it would've been pretty difficult.
SurferRosa is offline
Likes For SurferRosa:
Old 12-30-19, 03:06 PM
crank_addict
crank_addict's Avatar
Quoted: 1361 Post(s)
Liked 369 Times in 241 Posts
Kool Stop makes exact fit inserts. Black or salmon. I use both and highly recommend.
Chart below with Modolo part id (disregard the circled)
crank_addict is offline
Old 12-30-19, 03:09 PM
deux jambes
deux jambes's Avatar
Quoted: 477 Post(s)
Liked 273 Times in 154 Posts
Iíll be using kool-stop pads for a lovely pair of Modolo Professional brakes I have slated for my current project. The original sintered pads are in near perfect shape, but Iím confident that kool stops will be worlds better of an upgrade.
Kool-Stop Modolo Inserts
Iím running the Superbe style salmon pads on a pair of Gran Compes, and theyíre every bit as good as folks say they are. Picked them up from Kool Stopís Amazon store.
deux jambes is offline
Old 12-30-19, 03:51 PM
verktyg
verktyg
verktyg's Avatar
Quoted: 713 Post(s)
Liked 354 Times in 237 Posts
Sanding Brake Blocks
^^^^^ Kool-Stops for your Modolos.
Some of the standard Modolo composition pads work acceptably, especially after .5mm has been sanded off the faces. For some reason they don't all work the same???
I tried out a set of the Kool-Stops on the Speedy brakes on one of my bikes and there's a world of difference. $20 bucks well spent.
BTW, I sand a small amount of face material off of even new brake pads and especially old pads. Even new pads have a hard surface that takes quite a few miles to wear off.
I've found that 3M Medium Drywall Sanding Screen works well for this. I've been able to restore hard old brake blocks to usability by removing ~ 1mm off the surfaces to access the softer material below.
verktyg
Things aren't always what they seem... Don't believe everything you think!
Chas. ;-)
verktyg is offline
Likes For verktyg:
Old 12-30-19, 05:53 PM
xiaoman1
Slightly Mental
xiaoman1's Avatar
Bikes: A few too many
Quoted: 613 Post(s)
Liked 352 Times in 243 Posts
C.A.
Great information with images is always quite helpful...Thanks, Ben
P.S. do they make any for use with carbon fiber wheels that are replaceable?
xiaoman1 is offline
Old 12-31-19, 11:19 AM
randyjawa
randyjawa's Avatar
Bikes: 1958 Rabeneick 120D, 1968 Legnano Gran Premio, Rocky Mountain Cardiac, 196? Torpado Professional
Quoted: 812 Post(s)
Liked 335 Times in 234 Posts
@ verktyg That is great advice regarding pad, even new pad, preparation. As for Modolo pads... Pooey-Stinko!
randyjawa is offline
