Rear Campagnolo derailleur
Old 02-15-20, 03:53 PM
CTony
Quoted: 13 Post(s)
Need some information on replacement Jockey pulley and Idler pulley for Campagnolo N/R Derailleur.If There’s no replacements what can be used?
Thank You.
CTony is offline
Old 02-15-20, 04:05 PM
SurferRosa
SurferRosa's Avatar
Bikes: old school 531c & Campy
Quoted: 1072 Post(s)
Liked 750 Times in 462 Posts
Search ebay for "shimano ty05," which results in items like this:
https://www.ebay.com/itm/1-Pair-Shim...ss!98103!US!-1
SurferRosa is offline
Old 02-15-20, 04:19 PM
BFisher
BFisher's Avatar
Bikes: '61 Schwinn Klunker, '68 Hercules Klapprad, '73 Raleigh Super Course, '78 Motobecane Grand Jubile, '79 Motobecane Grand Sprint, '82 Colnago Super, '87 Ironman Expert, '89 Puch Mistral Leader, '92 Trek 930
Quoted: 301 Post(s)
Liked 434 Times in 260 Posts
What SurferRosa said. I use Shimano wheels just like those on my own Nuovo Record. No complaints.
Soma also sells a set, but they are like $35. Don't know if they can still be had, but the colored Bullseye Jockey wheels look really nice.
BFisher is offline
Likes For BFisher:
Old 02-15-20, 04:31 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 846 Post(s)
Liked 255 Times in 196 Posts
There are lots of 10t pulleys out there that might fit. The very best will be Suntour ball-bearing replacement pulleys, which conveniently came with reducer bushings for your derailer's 5mm diameter bolts.
Suntour, Simplex and Huret pulleys may turn up, but will usually have a 6mm mounting hole, making them more precious in the marketplace for those brands of derailer.
If the replacement pulleys are much narrower than .406" at the mounting hole, then you'll want to use a washer under each bolt's head, to keep the un-threaded portion of each bolt's shank from entering and damaging the threaded holes in the inner cage plate, and to prevent the bolts from possibly snagging the spokes.
I used aftermarket 10t alloy pulleys on this rear derailer. The pullies were narrower to better match my bike's modern 9s chain. Look closely and you might be able to see that there are washers under each bolt's head, to make up for the bolt's now excess length:
dddd is online now
Old 02-15-20, 04:50 PM
Wildwood
Veteran/Pacifist/Resister
Wildwood's Avatar
Quoted: 2319 Post(s)
Liked 782 Times in 485 Posts
Post in the trading thread.
Something good to trade may find a willing soul with too many Campy bits.
Wildwood is offline
Old 02-15-20, 07:11 PM
Mad Honk
Quoted: 413 Post(s)
Liked 292 Times in 224 Posts
I have been replacing the pulleys with the Chaser tech pulleys about $15 per pair but they are sealed bearing set that can be set to a 5mm bolt just ask them and they will send a correct fixture. Smiles, MH
Mad Honk is offline
