Campagnolo rear derailleur adjustment?
Old 03-15-20, 07:04 PM
CTony
Quoted: 13 Post(s)
Hello Hope everyone is doing well.Need some help not Sure if I need to go to mechanic section or just stay in classic,Aways,1980 Faggin replaced 5sp freewheel 13t-26t to a 5sp 14t-28t rear derailleur is Campagnolo N/R.Won”t shift to 28t gear I changed gearing for Eroica.Thank you for your time and help.Be Save Peddle On
CTony is offline
Old 03-15-20, 07:19 PM
repechage
Quoted: 1383 Post(s)
Liked 352 Times in 278 Posts
OK- the late Super Record rear mechs, shifted to the 28 better.
Check Velobase.com for visual reference.
That out of the way, back out the adjusters, you probably have the short dropouts as its a 1980, I would consider removing the adjuster screws and springs temporarily and slide the wheel aft, essentially all the way.
It will help, but if not enough... then alternatives are:
Shorten the chain the minimum amount ( with a gloved hand) twist a link to simulate a shorter chain along the return run of chain between the chainring and the jockey cage.
Watch the cage rotate away from the cog. The test prior is to go to the big/big combo, interestingly I have a bike that to get into the 28 (as I do not intend to keep that and plan going to a bigger big ring)... Must be in the big ring to accept the 28T.
I do not advise setting up the bike so it gets in trouble in the big/big even though you would not use that, duplication and friction.
So, try that and report back.
If not we will go to phase II.
repechage is offline
Old 03-15-20, 07:20 PM
CycleryNorth81
Quoted: 291 Post(s)
Liked 142 Times in 84 Posts
You might have exceeded the maximum cog size for that derailleur.
CycleryNorth81 is online now
Likes For CycleryNorth81:
Old 03-15-20, 07:24 PM
repechage
Only if it a very early Super Record, and then we can get there. Pre Pat72, a problem.
Likes For repechage:
Old 03-15-20, 07:30 PM
CycleryNorth81
Quoted: 291 Post(s)
I believe OP is using a NR derailleur. Will the NR derailleur work?
Old 03-15-20, 07:47 PM
davester
davester's Avatar
Bikes: 1981 Ron Cooper, 1974 Cinelli Super Corsa, 2000 Gary Fisher Sugar 1, 1986 Miyata 710, 1983 Nishiki Cresta, 1982 Raleigh "International"
Quoted: 534 Post(s)
Liked 141 Times in 89 Posts
I have made NR derailleurs work on 28T rear clusters on numerous bikes. The trick is playing with the chain length and position of the wheel in the dropouts to ensure that the cage is rotated far enough forward so that the upper pulley of the derailleur is far enough below the 28T cog when in the next lowest gear. Chain length is absolutely critical to making this work. If you could post us a picture of the derailleur with the chain in this position we might be able to help.
davester is offline
Likes For davester:
Old 03-15-20, 08:37 PM
zukahn1
zukahn1's Avatar
Quoted: 402 Post(s)
Liked 118 Times in 92 Posts
+1 on chain length if you change gearing by several cogs you should change length buy 1 link per 1.5 cogs less or more on older Campy stuff. In This case I would recommend you change to a long cage Suntour DR and a new 114 link chain and all will be good
zukahn1 is offline
Old 03-15-20, 08:58 PM
desconhecido
Quoted: 393 Post(s)
Liked 117 Times in 92 Posts
I have three NR derailleurs working with 28t cogs. Patent 72, 74 and 80. As mentioned, it takes chain length fiddling and dropout position fiddling. Also, big front-big rear is strongly advised against on all three of mine. Shifting is actually pretty good with new 6/7/8 speed chains and good freewheels, with the Shimano Z012 14-28 it is particulary good. In setting up one of them, it seemed that the derailleur cage had a strong desire to introduce itself to the spokes (stand testing only). So I gave in and put a spoke guard on it and very carefully adjusted the derailleur stop. Seemed to be the worst when there was enough chain to handle the big-big cross chaining.
desconhecido is offline
Old 03-16-20, 08:00 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2173 Post(s)
Liked 542 Times in 373 Posts
+1 on checking chain length.Sometimes that's enough. Otherwise, position the wheel as far back in the dropouts as possible. You may need to remove the adjuster bolts (if any) to get the wheel far enough back. I've seen Nuovo Record derailleurs work with a 30T sprocket with the chain length right and the wheel far enough back.
JohnDThompson is offline
Old 03-16-20, 08:07 AM
repechage
There was a design change, the Pat 74 have just a bit more distance between the mount pivot and they upper parallogram links.
As mentioned, it can be done, just takes .... finesse.
The late Super Record had a different cage, a few I know have hot rodded their early Nuovo Record with the late cage to good effect.
Old 03-16-20, 08:51 AM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
Quoted: 1410 Post(s)
Liked 765 Times in 431 Posts
I have done this without much trouble on various Eroica bikes. It is perhaps worth noting that all had 49T or 50T big rings.
Peace!
non-fixie is offline
Old 03-16-20, 10:30 AM
satbuilder
Bikes: 1969/70 Legnano Roma, 1971 Guerciotti, 1972 Cinelli SC, 1973 Bianchi Team, 173 Colnago Super, 1974 Marnati Corsa, 1974 ish Motobecane CT, 1971 Mercier 300, 1977/78 Colnago Mexico, 1982 Pinarello Italia,Tesch S-22, 1983 Peugeot Mixte
Quoted: 197 Post(s)
Liked 41 Times in 26 Posts
I've had luck with a 28T cog on my Cinelli, by doing just what John said. I did have to remove the dropout adjusters. It didn't work with my Bianchi, frame geometry is different.
Kurt
satbuilder is offline
Old 03-16-20, 10:44 AM
repechage
That makes things Far easier.
Old 03-16-20, 03:50 PM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
In various ways.
Peace!
Old 03-16-20, 05:13 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 847 Post(s)
Liked 255 Times in 196 Posts
As mentioned by non-fixie and repechage, having a narrower front chainring spread like 49/42 allows one to use a wider-range freewheel using the NR rear derailer.
I prepared a 1961 Raphael Geminiani for a guy who did Eroica using a 14-32T 6s freewheel using a NR rear derailer.
I got it to work through the whole range by adjusting chain length and axle position in the dropouts.
Tightening the chain was the key to clearing the biggest cog.
The narrower spread of chainring size definitely made this possible based on what I've learned from my previous struggles using the NR rear mech.
Always ensure that shifting to the big-big won't result in the chain "sticking" on the big-cog position, and that the chain doesn't go over-tight where there is sudden resistance felt at the pedals. Testing and adjusting in the bike stand is really useful here, even as I normally don't use a stand at all when building or working on bikes.
A slight bit of rumble felt in the small ring and biggest rear cog won't hurt anything when used only occasionally as expected on the hardest climbs.
I similarly use a 12-34t 9s cassette and 52/42t chainrings with an Ultegra 6503 Triple rear derailer rated for a maximum of 27t. I get just a hint of rumble as the top pulley just touches the largest cog when in the small chainring. It's a great setup that gives no problems over years of use! Shown below:
dddd is offline
Old 03-17-20, 10:31 AM
Road Fan
Road Fan's Avatar
Quoted: 1052 Post(s)
Liked 114 Times in 101 Posts
Kurt
I have had this work well, but it can depend on geometry factors, such as chainstay length. Correct chainline matching front to rear can also have an effect, in my experience. It also depends on whether you meed equivalently clean operation in all gears. I'm terrible at avoiding cross-chaining, so I am rather picky.
As well, Campy and other companies have (but don't always publicize well) that there are two limitations: The maximum spread adds the range of the chainrings to the range of the sprockets, and there is a maximum value for that. There is also a limitation on the maximum rear sprocket size that the derailleur cage can clear when twisted over as much as it can be. Extending the length of the dropout tang helps, as is used on 1x12 systems.
Road Fan is offline
