Addiction LXXVIII
#4901
VFL For Life
Bikes: Velo Volmobile
Quoted: 28605 Post(s)
Liked 1,856 Times
#4902
VFL For Life
Liked 1,856 Times
#4903
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Likes For ls01:
#4904
VFL For Life
Liked 1,856 Times
#4905
Mostly Harmless
Bikes: Have two wheels
Quoted: 13711 Post(s)
Liked 4,525 Times
#4906
So it is
Quoted: 11400 Post(s)
Liked 4,748 Times
#4907
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12767 Post(s)
Liked 7,678 Times
8 weeks since they shut down MLB
#4908
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
#4909
VFL For Life
Liked 1,856 Times
#4910
VFL For Life
Liked 1,856 Times
#4911
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#4912
Administrator
Quoted: 11966 Post(s)
Liked 6,632 Times
BUT, there are football replays. Even better-er.
#4913
So it is
Liked 4,748 Times
#4914
So it is
Liked 4,748 Times
Likes For LAJ:
#4915
So it is
Liked 4,748 Times
#4916
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
So, a question for the tubeless faithful. In the absence of almost literally anything else interesting to do this summer (and with a bunch of close-to-home rides should anything happen), I'm going to try tubeless again.
1) Which tires are currently favored?
2) Which sealant? Still OrangeSeal?
3) What should I use to inject the sealant?
4) Anything else I should bring along on the rides?
#4917
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
2- yes
3- the bottle tip through the valve is what I’ve always done
4- other than a spare tube and CO2?
#4918
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Last time I tried this the Contis hadn't come out yet. Also, the bottle tip didn't seem to be thin enough for the valve. And the reason I gave up last time was that the first time I (knowingly, but there were no orange patches of visible dried sealant) hit something with the Hutchinsons, it refused to seal and I had to give up and, yes, pop in a tube. There was talk of "bacon strips". Do people still use those? Take a mini-pump to try giving more air for the sealant to work with?
#4919
Fat n slow
Liked 2,085 Times
my first set of Maxxis Padrone I had the same problem, cut the tire and it didn’t seal and there was no indication the sealant doing its job. The shop had used Stan’s, I blame it on that
#4920
Liked 9,456 Times
I had been using the tube that phrantic mentioned for years - it comes with the smaller (8oz?) bottles of OS - but recently picked up a sealant syringe from Amazon. I think that it's going to be a really worthwhile addition - less guesswork when checking sealant levels and it'll allow me to remove old, watery sealant without unseating/reseating the tire. The only problem at this point is that the ID of my current valve stems (Stan's) is about .2mm too tight for the 3mm tube that comes with the syringe. I'll replace the Stan's stems with some WTB or Milkit stems when I swap out my tires.
I still bring my normal flat kit and bacon strips. The pump is nice if you have to top off when you lose a bit of air before the sealant does the job.
I have used a bacon strip on the aforementioned Goldilocks puncture, but it wouldn't hold - the pressure/size of the cut pushed it out. This was at home, in the stand, though - it may have been a different story during a ride, getting squished with every revolution. The plugs with the brass barbs look interesting, too - I'll probably pick those up sometime, but may not have an occasion to use them for years.
#4921
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Orange Seal
Syringe
Plug kit
Keep the chain tight!
#4922
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Thanks for the comments guys - I was wondering if Schwalbe or Vittoria was better-regarded than Conti for tubeless. I'll ponder. Though come to think of it,this may be a project for a few weeks later - we're closing on the new house next Friday.
Likes For Bah Humbug:
#4923
Bikes: everywhere
Liked 7,678 Times
3) for setup I inflate without sealant to see if the beads will pop on. If they do, I peel one bead about halfway off, and pour some sealant right into the tire, then pop that bead back on and reinflate. For top-ups I use an olde 4oz Orange Seal bottle and hose (rinse after every use).
#4924
Liked 9,456 Times
#4925
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
When do you take possession? Immediately? Exciting!
