montague paratrooper can i downgrade the wheel size?
I bought a montague paratrooper of craigslist so the sales kind of final :S
it feels to tall for me to get on(fine once im riding)
i thought i would fit according to what the internet says but i guess for 5'9" ive got short legs
i was wondering if it could use 24" inch wheels on it so it was ever so slightly lower to the ground
would i run into any issues?
thanks
thanks
Dirt Bomb
Quoted: 5464 Post(s)
Liked 288 Times
Pedals may be very close to the ground.
Where do you live? How much would you take for it?
I am now folderless. I gave this to my 8 year old grandson and he loves it:
Bikes: 2012 Masi Speciale CX : 2013 Ghost 29er EBS
thanks
thanks
Bikes: Montague DX Crossover, Raleigh i8
Obvious question, but did you adjust the seat height? I have a Montague DX and I'm 6'. I can adjust it really low. Going from 26" to 24" won't solve your problem due to pedal clearance as mentioned above.
Hi
I have 24 inch wheels on my paratrooper. I put them on as the 24s are easier to pack in a suitcase. The difference in pedal height did not cause me any probs. Of course, when on a corner you need to be aware pedal strike is possible and if off road your clearance will be a little less.
Cheers
Rob
Cheers
Rob
GN BIKN
Bikes: 1990ish MTB converted to 'cross, custom Vulture 29"er, Swift 2-speed Automatix folder, Madsen cargo bike
I would try making sure the saddle is adjusted properly, and spending some quality time on the bike getting used to it, before making a radical change like that.
You'll bring your pedals 1" closer to the ground, which is a BIG difference. Some people won't be bothered by it, but you'll need to be really careful to keep the inside pedal up in turns. I once landed flat on my face after clipping a pedal in a turn (while standing out of the saddle), not a fun experience.
As pacificcyclist mentioned, by lowering the axles without also changing other variables you will also radically change the handling. Your bike will have a lot less of what's known as "trail", which means the handling will be much quicker and less stable-feeling. Seasoned road-bike riders might find it preferable, but most beginning cyclists would probably find it twitchy and confidence-robbing.
And also as pacificcylist said, if you don't have disc brakes you won't be able to convert to 24" wheels (unless you also convert to disc brakes -- which may or may not be feasible depending on the age of your Paratrooper). If you do have discs you will be able to do it, but it still won't be cheap. No one makes a prefabricated 24" disc wheelset, so you'll need to have a custom wheelset built. Figure on at least $250 or so for that.
