Addiction LXXVIII
#5451
Quoted: 18455 Post(s)
Liked 15,691 Times
The Forester would still get 28 mpg if I were to properly inflate the tires.
#5452
Bikes: '88 Bianchi, '94ish Trek
Quoted: 1085 Post(s)
Liked 128 Times
I'm past due in my Jeep to change the transmission and T-case fluids, and to rotate the tires. I've also put off dealing with my oil pressure sensor that needs to be replaced because FCA, in their infinite wisdom, now requires half of the engine to be taken apart to change it- and that's only a slight exaggeration. But it's a Jeep- it's supposed to have that check engine light on, right?
"The mystery of life isn't a problem to solve, but a reality to experience."
#5453
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12832 Post(s)
Liked 7,757 Times
I've had the most ridiculous time setting up zone 2 irrigation for the northwest lawn. I'm changing it from 4 sprayers to 2 rotors, so I ran some new pipe out to the corner of the lawn, plug all the Tees for the olde sprayers and flush the pipe for 20 secs. Then put the swing joint and rotor on the end, open the valve and there's not enough pressure to pop the rotor up. Urrggghh.
So I put a cap on the swing joint, remove a plug from an olde tee, open the valve and I got Old Faithful pressure. So I uncap the swing joint, open the valve and dribbles.
For the run to the corner, I tapped into an olde tee that was 1/2" thread, so it choked down to 1/2 through the tee and couple inches more for a connector and a street elbow that put it back to 3/4 pipe that was about 6' long and rose about 2".
Maybe the necking down to 1/2" and then opening up to an uphill 3/4" run is impacting pressure that much? Seems unlikely, and I was really close to sitting down and working out the fluid dynamics of such a situation, bit then I decided screw it, gonna cut that 1/2" crap out of the equation. Dug up the tee, cut it off, made the whole run to the corner 3/4".
Turned on the valve, and it's dribbling out the swing joint.
I finally got the idea to pull the swing joint and check pressure. Full blown geyser!
Turns out there was a damn pebble in the run that wouldn't pass through the swing joint, but didn't get flushed out upon the earlier flushing.
What a day.
What a day.
#5454
VFL For Life
Bikes: Velo Volmobile
Quoted: 28679 Post(s)
Liked 1,863 Times
#5455
Bikes: everywhere
Liked 7,757 Times
#5456
Super Modest
Quoted: 10980 Post(s)
Liked 4,646 Times
I think that I told this before but I’m old and forgetful so here goes:
My wife still worked for a couple years when I retired and she would ask me every night when she got home what had I done all day so I started making a list to prove I wasn’t a slacker.
1. Did some grocery shopping (rode bike to the convenience store and got a cup of coffee)
2. Did some yard work (picked up a piece of trash or a stick in the yard)
3. Did some banking (hit the ATM at the convenience store while buying a cup of coffee)
etcetera, you get the idea.
Keep the chain tight!
Likes For Trsnrtr:
#5457
Super Modest
Liked 4,646 Times
What a day.
What a day.
#5458
Quoted: 3369 Post(s)
Liked 3,675 Times
#5459
So it is
Quoted: 11415 Post(s)
Liked 4,789 Times
What a day.
What a day.
#5460
So it is
Liked 4,789 Times
The person that owned this house prior to us did that gravel thing. It's forever, unless you pull a front loader in and dig down a foot or two. We fight it constantly, and it sucks.
#5461
Liked 3,675 Times
I figured it wouldn't be worth it just to save some time and effort on yard work. I don't want to shoot myself in the foot like that.
#5462
Liked 15,691 Times
R.I.P. Jerry Stiller.
Likes For indyfabz:
#5463
Mostly Harmless
Bikes: Have two wheels
Quoted: 13730 Post(s)
Liked 4,541 Times
#5464
Quoted: 20810 Post(s)
Liked 9,456 Times
#5465
Mostly Harmless
Liked 4,541 Times
We're in zone 5. No timers needed.
#5466
Should Be More Popular
Quoted: 22639 Post(s)
Liked 8,953 Times
#5467
Liked 8,953 Times
Likes For datlas:
#5468
Liked 3,675 Times
#5469
Mostly Harmless
Liked 4,541 Times
I assume that, if you want a gravel lot, you need to do something to stop things from growing. Sounds like a major undertaking.
Likes For rjones28:
#5470
VFL For Life
Liked 1,863 Times
#5471
VFL For Life
Liked 1,863 Times
#5472
Administrator
Quoted: 11982 Post(s)
Liked 6,692 Times
*gasp*
#5473
Mostly Harmless
Liked 4,541 Times
The rjones28 lawns have biodiversity. I just make everything the same height from time-to-time.
#5474
Administrator
Liked 6,692 Times
#5475
Mostly Harmless
Liked 4,541 Times
