What drop downs to buy?
Hi all, I've decided I want to buy some drop down handle bars, I'm currently doing mainly 60-80 mile routes with lots of climbs and descents and I'm finding my current flat bars uncomfortable on my large (56.5cm) sirrus comp 2008.
Of what I've found the 3t Ergonova Pro Alloy Handlebars looks best from my budget, does anyone have any views on fitting the 46cm version or does anyone have any other drop down suggestions?
BTW I'm 6'2" tall with a shoulder measurement of 47.5cm.
cheers
cheers
Super Moderator
Quoted: 1173 Post(s)
Liked 924 Times
I assume you have picked out new/used brake/shift levers compatible with your drivetrain ?
Two-Wheeled Aficionado
Bikes: Santa Cruz Blur TR, Cannondale Quick CX dropbar conversion & others
Liked 5 Times
I'm riding those bars. They are a bit narrower than other bars I've used of the same size. It seems like the rated size is where they flare outward (slightly) in the drops.
They're ok, but I'm not gaga over them. I will switch to carbon wing bars eventually.
What's a bike?
Bikes: Bianchi Veloce
Why not just use Back-Up Barz? j/k
You will need shift/brake levers as stated above. You also may need a new stem depending on what you have now. Just another thing to point out, is your bike geometry something that will be comfortable with drop bars or will you still be too upright/short?
Bikes: Felt AR1, Cervelo S2
Quoted: 17 Post(s)
to expand on what adclark is saying - the geometry of your hybrid might have you sitting too far upright, which would make getting into the drops awkward - requiring too much of a bend at the waist. might need a different length stem at least. Also, you will need shift/brake levers and new cables, which will cost some money. It might be better to sell the hybrid and get an entry level road bike.
if you end up doing this, there are three major bar types, and infinite brand choices:
a traditional-bend bar like the 3T Rotundo
a compact bend bar like the FSA Compact line
an ergo bend bar like....every ergo bend bar.
Bikes: 2011 Look 566 Ultegra, 2010 Specialized Sirrus Sport
I looked into converting my Sirrus to drops and decided to sell it instead. It's not as easy as just swapping out the bar and brakes/shifters. There's plenty of information in the hybrid forum here, start with that.
Quoted: 18883 Post(s)
Liked 10,645 Times
Liked 6 Times
I'd say just get whatever generic drop bar is available cheaply, throw it on and ride it. No matter what you buy, you'll most likely want something different down the road, so minimize your initial outlay until you have a good handle on what you REALLY want.
SP
Bend, OR
SP
Bend, OR
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1111 Post(s)
Liked 243 Times
These bars are decent bars for the price and they come in a 46, not the most expensive bar on the market, if you want that then try others, but see: https://www.jensonusa.com/store/produ...%20-%2026%2040 I have the silver version on one of my bikes for many years and they work just like bars are intended to work, and their actually lighter then the ones you're looking at.
Wow, thanks for all the responses!
Ok looks like the cost inhibits doing this, I understood the shifters were expensive but finding a cheap second hand pair is almost impossible, I also realised I'd have to replace the crankset on my sirrus adding more cost!#
I will keep this option in mind but I think it will be easier if I just buy a second hand racing bike instead!
This way I will have more of an idea of the type of bars/bike setup I need. Cycle shops really should allow you to rent bikes for a day and allow you to do a 60 mile ride, I would have made a more informed choice back in 2008 (now too)!
GTryder
8
07-17-17 08:29 PM
