Replacement handlebars/grips for 2012 Trek 7.6 FX
I just picked up my new 2012 Trek 7.6 FX from the LBS and love it so far except for one thing, the handlebars. On my first ride, I decided to see how fast I could get it moving on smooth pavement and with my weight shifted forward, the right grip started to shift and the end cap popped off. I managed to get it tightened back up temporarily but it doesn't appear as though it will be a permanent fix. Also, I'd like to get bar ends and do not want to deal with having to purchase an adapter so now I need to get a new handlebar and grips. Any help choosing a good handlebar and recommending a set of bar ends would be appreciated. I'm comfortable on the bike with the stock setup so I don't need anything that will change my riding position. Thanks in advance.
Bikes: 2013 Cannondale Synapse; 2012 Trek 7.6; 2010 Trek 7.0 FX
I also have the '12 Trek 7.6. While I was waiting for my bar end adapters to come in, I swapped out the IsoZone bar with a Bontrager Select bar. However, just today I put the IsoZone bar back on and will ride it for the first time with the oringal bar. I'll be curious to see how it works. I also bought a pair of drop bar ends but am not too confident putting them on the IsoZone bar so I have a feeling I'll be swapping them back out.
Jim
I had my LBS order the bar end adapters and I installed them with bar ends, I like them, and they don't move at all.
Just make sure the screws are tight, and all is good.
Well, I ended up heading back up to the LBS and they got me squared away. Turns out the brake levers needed to be moved slightly inward so that the inner clamp on the grip had more surface area to clamp down on. They're now on there rock solid so I'm stoked. Took an 11.6 mile ride after leaving the LBS and all I can say is that I love this bike.
I put my IsoZone bar back on the bike and took it for a ride today, about 25 miles round trip. Had a few issues in the beginning, but took it to my LBS and they fixed her all up. I have to say, the IsoZone bar with bar ends worked out better than I expected. I'm pretty pleased with the current set up.
