Year and level of Benotto mexico bike for friend
Bikes: Yes
Quoted: 460 Post(s)
Liked 54 Times
Helped a friend find a cheap road bike. he will use for short commutes to light rail and wanted a something vintage. Trying to figure out year and quality ranking for their models as there is no number and many do have. I know it is Mexico as it has a Mexico decal. No serial on BB, still need to look for.
Quoted: 4722 Post(s)
Liked 3,044 Times
Shimano New 105, if OEM, places it 1987-1989. It appears to be the 6 speed version, which would narrow it down to 1987-1988. During this era, New 105 bicycles were typically considered lower mid-range. This bicycle does have the full New 105 group so it may have been upgraded but the graphics are correct for this period.
The Benotto model with new 105 was the model 1800. It used a Columbus SL frame. To verify this remove the seat post and check the size stamped on it, which would be 27.2 for Columbus SL. Also, remove the front wheel and check inside the bottom of the fork's steerer tube for five spiral ridges (see photo) that are indicative of the steerer used on Columbus SL.
Bikes: Yes
Quoted: 460 Post(s)
Liked 54 Times
Supposedly this is how it came, second owner said he bought, rode a year and parked for seven.
Not sure parts will narrow any more but;
Brakes, levers and derailleurs (front just says Shimano) are 105, shifters are 600.
Hubs are stamped "Touring" with "Patent" below that.
Headset is Benotto
Cranks are Coronado
Pedals are VP 380
Fork and rear dropouts stamped Benotto.
Pics pretty much show the rest.
I found this link but it appears to be for pre mexico, the stays are Diamond and not indented so I know some of this changed, as there is no way this is above low mid range at best. The analysis of steel and dropouts is interesting but again probably changed.
Benotto Bicycle Restoration ? How to identify a vintage Benotto bike frame?s year and model ? Part 2
Liked 3,044 Times
I overlooked your 2nd post where the aero tubes were mentioned. That would make this a Benotto Triathlon. These frames were hi-tensile steel and this is corroborated by the post diameter. Typically, New 105 wasn't spec'd on hi-tensile frames and I haven't see any Triathlons with new 105, so I'm still assuming replacements. Known original derailleurs were Shimano Light Action or SunTour SVX. The Thun crankset is also known OEM spec. The Triathlon was available from at least 1986 through 1988 and in stock form was an upper, entry level model. So, not much change in the timeline.
Bikes: Yes
Quoted: 460 Post(s)
Liked 54 Times
@T-Mar, I hope you are cataloging some of the stuff you know and firsthand experiences! You have come through on many occasion and its appreciated.
In case anyone else comes across one like this. Forgot these parts,; skewers are Miche. Freewheel is shimano MF Z012. Bars are 3T.
With your help I found some info in the range, nothing exact and this has probably been posted before, but I thought it good and was amusing. Supposedly 87' models;
Liked 3,044 Times
@T-Mar, I hope you are cataloging some of the stuff you know and firsthand experiences! You have come through on many occasion and its appreciated....
Carpe Velo
Bikes: 2000 Bianchi Veloce, '88 Schwinn Prologue, '90 Bianchi Volpe,'94 Yokota Grizzly Peak, Yokota Enterprise, '16 Diamondback Haanjo, '91 Bianchi Boardwalk, Ellsworth cruiser
Liked 14 Times
Thanks for all the good info. I've been trying to identify my Bennotto and the information in this thread, and a couple of other sites, has helped me identify it as a Triathlon. Mine has been repainted similarly but not identically, but all the construction details appear to match what is shown above. Thanks. (BTW, the single speed thing wasn't really to my liking, and I am refitting it as a geared road bike)
Liked 3,044 Times
Looks pretty close to the Modelo 2000 that I recently finished up for my daughter.
Bikes: Yes
Quoted: 460 Post(s)
Liked 54 Times
BTW, it was a ton of work and took a lot of beer , we finally did it this past Saturday. Broke it completely down and it cleaned up very nice, but all the grease was super sticky and degreaser would not take off. What does everyone use for that really old sticky stuff? Any simple or cheap solutions?
Location: York, England after 15 years in Massachusetts
Bikes: 1 frame and a heap of pieces
Quoted: 11 Post(s)
I had one, the original seat had little stick figure triathletes. a was a nice rider but I had no space in my fleet at the time
The seat tube is not aero. One other difference is that my daughter's bike has a chrome fork. I have no idea what the original groupset was. It had a mix of fairly high quality parts when I got it. I put a Shimano 105 groupset on it that I had. I pulled a very nice Suntour Superbe crankset off it.
