ISO and for trade thread part 5
#2051
Death fork? Naaaah!!
Top
#2052
Quoted: 1946 Post(s)
Liked 2,004 Times
#2053
PM me your cotters
Quoted: 1137 Post(s)
Liked 588 Times
Just destroyed an ill-sized ("standard" sized) black Cinelli 1a stem a previous-owner jammed in my all-French 1980 Motobecane Grand Record.
Now I'm hunting a correctly-sized anodized black 22.0 quill stem
Any brand, don't care, just needs to be black and 22.0 mm quill vs. 22.2 mm quill stem
Prefer 110-120 reach, but can't be picky so 100 or 105 would work.
Bar clamp size is negligible for me, I have some bar options.
-----> (NOTE: I cannot use a std 22.2mm quill without honing, it's French!)
I have a slew of silver Cinelli, Belleri, Pivo (and many other) stems to trade - I think I even have a Scheeren stem laying around, one of the really nice "I-beam" style stems.
Else let me know what you're looking for. Unless unobtanium-type vintage stuff, I may potentially have it.
My ideal stem would be in this ballpark:
Likes For francophile:
#2054
Quoted: 189 Post(s)
Liked 473 Times
Searching for:
A single Dura Ace 7400 brake caliper - can be front/back/broken/missing parts.
One Campagnolo Athena/Chorus vintage white brake barrel adjuster (see image).
#2055
Quoted: 1300 Post(s)
Liked 1,900 Times
#2056
Bikes: many
Quoted: 1441 Post(s)
Liked 1,386 Times
I am missing a wheel guide and washer from one early Dura-Ace brake caliper, and all four wheel guides from a second set, so five guides total. These puppies:
Anybody got some? A trashed set of calipers would be fine as long as the wheel guides are okay. The washer is clearly secondary. I'm sure I can replace the missing washer with a Campy or Dia-Compe caliper.
I have stuff to trade (need freewheels?), or can pay cash.
#2057
Quoted: 10234 Post(s)
Liked 5,178 Times
still iso a right shimano sti 9 speed shifter.
now I also need a shimano 9 speed cassette if anybody has one that has some life left in it.
I have a gold mavic rim I can trade.
thanks.
thanks.
#2058
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3869 Post(s)
Liked 6,455 Times
#2059
PM me your cotters
Liked 588 Times
I want to stay in this general wheelhouse, and maybe even seek out a black seatpost in the future, but that's easy compared to finding a black anno'd 22.0 quill stem. I'll probably move towards a navy-colored cable housing too, just to pop off the decals.
#2060
Quoted: 1088 Post(s)
Liked 1,205 Times
Correct. Can't do that with a black stem. I'm looking to stick with and expand on a specific look with this bike. Person I bought it from shoved a 22.2 black stem in it, I had to "gently" fork it out (it's pretty mangled).
https://www.ebay.com/itm/ORIGIN8-Cla...IAAOSwm8ZeG6hM
Likes For noobinsf:
#2061
Quoted: 7345 Post(s)
Liked 2,452 Times
You can sand down the submerged section and leave the exposed section unscathed.
#2062
PM me your cotters
Liked 588 Times
How about this one? I have used Origin8 stems in a couple of different French-sized steerers with no issue and no modification. Worth a try for the price?
For 1-inch/22.2mm diameter threaded forks/headsets.
PM me your cotters
Liked 588 Times
But at that point, I started thinking about the hours of work I'd put into it and decided there must be an out-of-the-box solution to this issue. Certainly, Cinelli must've made black french-sized quill stems?
Edit: Actually, it looks like Kalloy may've even made them: https://www.ebay.com/itm/124083311111
Liked 2,452 Times
francophile I don't think Cinelli made French-size stems, and if they did, you'll have to wait and pay dearly. The time it takes to make a stem fit will not be even an hour. Try it on that $8 stem if you're scared, and then decide if you want to repeat the operation on a nice stem. If you don't, maybe you can use the cheap stem.
$65.50 seems like too much for that Kalloy stem.
#2065
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
Likes For Ex Pres:
#2066
Bikes: '01 Klein Quantum, '91 GT Zaskar, '70s Di Lorenzo, '74 Gitane Champion du Monde, '50s Steyr Klunker, Cannondale Singlespeed
Quoted: 18 Post(s)
Liked 21 Times
In search of a few different vintage bits:
French thread bottom bracket – 118+/-mm length - French mfr or Campy
Magura hs33 or hs22 left lever (the whole unit)
Weyless 27.2 seatpost (the american one from the 70s, not the 90s one)
Also ISO some not-so-old stuff: Campy Athena 11 speed shifters, crankset, front+rear derailleurs. Shimano 11 speed cassette, at least 28t on the big cog. Would also consider a carbon square taper crankset instead of the Athena crank.
I'd like to trade:
A nice Campy fluted 27.2 seatpost with Olympic rings panto (Olmo?) for a fluted campy 27.2 with no panto. Same or similar condition and length preferred.
I'd also like to trade for a 1" diameter steer tube, caliper brake Wound Up fork. It needs to have 7 1/2" of steerer to be safe if threaded, more if threadless of course.
I can offer 1 of the following 2 forks in trade: either a Wound Up 1-1/8" disc fork with 8-1/4" of steer tube, or a Look HSC3 full carbon fork with a 1" threadless steer tube that is 10-1/2" long.
I'd like to trade:
#2067
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
edit: Never mind!
www.rhmsaddles.com.
www.rhmsaddles.com.
#2069
PM me your cotters
Liked 588 Times
I'm open to 3TTT and other brands. As long as the general look is roughly in ballpark with the 1A posted in my reply. There are some companies (Pivo, Belleri, etc.) I'm fairly sure didn't make any black anodized stems. I know 3T and Cinelli did, but not sure when it all started.
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
This comment made me realize I should probably mark up my original post.
#2072
Quoted: 1079 Post(s)
Liked 1,019 Times
I'm looking for a pair of 8sp 28h road hubs, so 130mm. I need these two build up a set or sun 24 1 3/8 rims for my son's bike. I've got a pair of Mavic Open Pro rims from 2005 which have a lot of life left, mafac cantis from a Gitane tandem, nitto Olympiad handlebars from a kuwahara and possibly some other things available to trade.
#2073
Bikes: 1973 Jack Taylor ToB, 1974 or '75 LeJeune Champ du Monde (possibly from the Carre Shop), 1971 Motobecane Le Champion, 1980s Rodriguez frame (future 650b conversion project)
Quoted: 38 Post(s)
Liked 7 Times
Hey, @francophile, just to add to your search, the New Royal Super Light stem was made in black and French-sized. I bought one at a swap that has the cool milling and ultralight Allen bolts. The anodized black has lightened a bit on mine. It fits your criteria at 110mm extension, but I’m not sure I’m ready to give it up.
here’s a catalog image that details 22.0 size was available and made to order.
https://flic.kr/p/8ZrGKM
I don’t have a good picture of mine, unfortunately. Good luck.
Likes For JT1973:
#2075
www.theheadbadge.com
Quoted: 2420 Post(s)
Liked 4,381 Times
Looking for one or a pair of scrap 650B fenders, 42C capable, provided the fender is smooth. I want to experiment on it to see if a pair of 3D-printed forms can be used to press fluting into the surface without damage (I want to imitate the pattern of the Le Nervuex Type B. Third fender from left):
-Kurt
-Kurt
Likes For cudak888:
