GPS computer for multiple bikes
Bikes: 2015 Cannondale Synapse Carbon 105, 2021 Trek Checkpoint SL5
Quoted: 12 Post(s)
I am looking for a computer with GPS that can be used on 2 bikes. What unit would be the easiest to have this setup?
Right now I am looking at a Garmin 520 Edge Plus but I can't find any mention as to whether it supports using it on 2 bikes? I am primarily leaning towards the GPS functionality as I would be doing cycle touring with it on one bike. My other bike is a road bike so I would use it to keep track of my rides, distance, cadence etc. Any thoughts on how well it functions in this regard?
Any other comparable units I should look at in this category?
Quoted: 3270 Post(s)
Liked 2,109 Times
GPS units are bike agnostic. In plain English that means you just get additional handle bar mounts for different bikes and use the device on whatever bike. I have mounts on 6 different bikes.
The device figures out speed and distance from the GPS plot you start at the beginning of a ride. It knows the time and moving time so knows avg., etc...,. A Garmin uses a smartphone app called Garmin Connect Mobile to pair via BlueTooth to the device. At the completion of a ride, you press Save and the ride data goes to the cloud, in this case Garmin Connect, which is an online activity tracker. Or you can have that ride data saved to Strava or RideWithGPS.
It’s not like the days of a cycling computer that used a magnetic wheel sensor to determine speed and that was somewhat specific to a particular bike due to wheel circumstance settings. A GPS could be mounted on the family dog and it’ll plot a ride.
For touring you might want some navigation functions such as turn-by-turn directions. For that you can plot a route on Connect, Strava or RWGPS and have a route sent to the device. You might also want to be able to view the map to select roads or alternatives and for that, the larger the screen the better. A decent model designed for touring is the Edge Explore, sells for around $250. Doesn’t have a lot of the functions related to performance functions - power meter, timed intervals stuff, etc... it’s a more basic unit with a touch screen (useful for panning and zooming a map) as well as a
larger screen than the 520 Plus, which is a button control unit.
Likes For Steve B.:
Like mentioned, the bike computer doesn't care. That's why you don't see that as an option. It could be in your pocket and you can jog with it or drive down the road with it in your car (MTB people seem to forget to shut it off on their drive home) and it will record the drive too.
The only thing it cares about is any external sensors you may have paired and even that is not big deal and it will ignore any sensors it can't find. An example.. Bike 1 could have a cadence and speed sensor. You slap your computer on bike 2 and go for a ride. You will not get cadence info obviously and your speed info will be based on the GPS signal instead. Next day go back to riding bike 1 and it will just work and you'll be back to getting speed and cadence info from the sensors. You could swap the speed sensor and cadence sensor over to bike 2 and adjust the speed sensor settings in the app for the different wheel circumference on bike 2 and now everything will work on bike 2. I'm sure you could also buy additional sensors and pair both but I've never did that.
I reread what i wrote and it looks more confusing than it had to be, bottom line, you can use it on any amount of bikes with little to no effort.
Quoted: 12 Post(s)
I would have speed and cadence sensors on both bikes. I realize GPS doesn't care where it is positioned, but I would still like to track the actual kms ridden on each. This is helpful information to know when you may want to service the bike among other things. I take it that most of these units you can probably have two profiles setup and just select the profile you want when you are going to ride.
Comparing Garmin to Wahoo, the Garmin looks harder to setup and program, relying on the buttons instead of the phone app like Wahoo. Seems like the Wahoo Bolt does GPS as well (albeit not in colour like the Garmin 520) and has turn by turn navigation. I am just wondering if this is redundant and using a phone with GPS would be nearly as effective. I have only ever had basic cycling computers, so I am still learning what features might be useful to have.
Most modern bike computers are made to be paired with an app or website where they tally your ride data and you can setup multiple bikes there. You can even jog with a bike computer and designate the activity as a "run". This is why you will not easily find this feature on the computer itself.
Liked 2,109 Times
I have Garmin connect send my competed ride data to RWGPS, which I use for my activity tracker and I edit the ride info to have gear indicated, thus can track mileage per bike and can add comments on stuff like “Chain replaced”, etc.... in general it’s easier to do this online than on the unit.
I’ve used 3 different Garmins as well as a Wahoo Bolt. The setup on the Wahoo app was maybe a bit easier but really it’s just different and I never had issues setting up a Garmin. I think maybe features are a bit scattered, but as there are typically more features than found on a Bolt that’s expected.
If you want navigation, I would hate to be dragging out my phone in the middle of a ride. It’s easier to use a dedicated unit with Turn-by-turn and a map and I’d recommend a larger Garmin than the 530 as well as don’t get a Bolt, which have very basic maps. A touchscreen makes it easier to move around a map, zoom in/out, pan, etc..... The Wahoo Roam has improved maps with a color screen and I’ve read can pan and zoom.
Liked 2,109 Times
I think the Explore is the most cost effective unit in the Garmin cycling device lineup, but it’s legacy comes from the Touring model, which was a very buggy unit (seemingly all fixed in the Explore), and as such it’s not a unit to get if you desire a lot of performance metrics. Besides no power meter support, there’s no barometric altimeter, no activity profiles, more limited Connect iQ app availability, no temperature, no battery save mode, no Di2 support, no interval training, etc...... There’s a list at the link below and you can clearly see that the Explore does not have a lot of features of the more expensive units. Nothing wrong in that as what it does it does really well at a great price, and I recommend it all the time. Had it been available when I was replacing a 1000 would have gotten it.
https://www.gpscentral.ca/products/g...isonchart.html
Quoted: 6251 Post(s)
Liked 4,851 Times
On older Garmin Edges, it was called bike profiles. Some time about the edge 510 or 520 they gave it more abilities and changed the name to activity profiles. I'm pretty certain you can attribute the sensors of different bikes to different profiles you create.
I do it on my edge 500 with just bike profiles. So just look at the online manual for the various garmin's and see if that device has activity profiles.
Quoted: 54 Post(s)
Liked 175 Times
I have an Edge 520 + and for now it's only purposed for one bike. I purchased mine simply for the fact that it was on sale at MEC for $199 Cdn in addition to having full routable maps with turn by turn capabilities. That being said, I'm still getting acquainted with the device but find it convenient to create my own routes using ridewithgps.com, uploading them to the unit as well as logging my rides. As mentioned, there are no bike profiles to speak of but instead there is the provision of a sensor pool and at least a dozen sensor selections to choose from the drop-down menu. You can give each sensor a title appropriately identifying a specific bike. As long as you have a different sensor attached to your road bike the 520 + will simply add it to its pool and actively connect to which ever bike is being ridden. One could also set up one or more activity profiles, identify them by name, color and default ride whether it's road, mountain, gravel, mixed, commuting……and change the field displays accordingly.
https://www.dcrainmaker.com/2018/04/...h-mapping.html
Compared to 1030? Of course! But not to 520/520 Plus - these guys are significantly less powerful slower devices which simply can't run full set of navigation features and related hardware (like higher resolution touch screen). But releasing a device that has similar hardware to 1030 and the same software features and costs half the price is effectively the same as killing sales of 1030, so, of course, Garmin couldn't have done this. So, we got 5XX devices - good for training but quite limited for navigation and Explore - good for navigation but quite limited for training. Choose one or another. You want both? Sure - Garmin has 10XX line for you, just prepare your wallet. ;-)
As long as you don't need any advanced training features.
The comparison chart you reference is not always correct, e.g. Explore definitely has a battery saving mode. Judging by the device performance it really looks like chopped down 1030 platform artificially limited by software to not compete with higher price Garmins. I'll not be surprised if some of the things that are supposedly missing, like barometric altimeter, are in fact present and just disabled in software. I know for a fact that temperature sensor is present and was working perfectly in the first few iterations of the firmware. And then it suddenly disappeared. Tons of users thought it was a bug and complained - and Garmin answered that "temperature sensor feature is not supposed to be present on this device according to its specifications".
Liked 2,109 Times
Liked 2,109 Times
Liked 4,851 Times
I had called Garmin tech support early on with issues on my 810 and asked if Bike Profile information - I.E. the data as to which bike was used on the ride, was uploaded to Connect. The answer was “No, but that’s a good idea, you should submit that”. My thought was the friggin support technician should submit that !
Is this just extra info? I didn't think the OP was concerned about the bike info being uploaded to Garmin Connect. I thought they were just asking if there was a way to use the same device on multiple bikes, each with it's own set of sensors.
RideWithGPS lets you set up multiple bikes and gear. You set a default for your upload and if it is different, you can change it anytime after uploading. I'm sure others do something similar. However that won't do anything about using the same device with differrny bikes having different sensors. The device has to handle that.
It fully makes sense to me why Garmin expects a customer to make suggestions for new features and not the customer support rep. They have a site just for that https://www.garmin.com/en-US/forms/ideas/
Liked 2,109 Times
"Is this just extra info? I didn't think the OP was concerned about the bike info being uploaded to Garmin Connect. I thought they were just asking if there was a way to use the same device on multiple bikes, each with it's own set of sensors."
Yes, that was the original question and I've gone off on a tangent with the comment that it would be nice to also be able to automatically upload the data as to which bike was used on a completed ride.
"RideWithGPS lets you set up multiple bikes and gear"
Yup, that's what I do now. RWGPS does a good job of tracking bike usage.
"It fully makes sense to me why Garmin expects a customer to make suggestions for new features and not the customer support rep. They have a site just for that https://www.garmin.com/en-US/forms/ideas/"
It's just my opinion but it seems dumb that while you are on the phone with Garmin that they have no ability to take a suggestion for product improvement while you are chatting with support. That suggestion may very well be related to whatever issue you might be having, with the device not functioning as expected. And let’s face it, the manual just sucks, so the intent of some features isn’t always clear to a newbie. But you are correct that I just needed to get off my butt and write up the suggestion, so just did that.
