Drop in replacement for Schwinn le tour GT400 rear derailleur?
Hello, I’m looking for a drop in replacement for my 1974 Schwinn le tour which has a Schwinn Le Tour GT400 rear derailleur. The teeth on the gears of the derailleur are totally chewed up.
Here is info about my derailleur which I found on Disraeli gears.
I am not looking for anything crazy expensive, just the cheapest rear derailleur that can get the job done.
Thanks.
- Derailleur brands: Schwinn, manufactured by Shimano
- Country: USA, manufactured in Japan
- Date of introduction: 1974
- Date of this example: 1974 (two letter date code is ‘YI’)
- Model no.: GT400
- Weight: 267g
- Maximum cog: 28 teeth (Sutherland’s 4th edition)
- Total capacity: 28 teeth (Sutherland’s 4th edition)
- Pulley centre to centre: 46mm
- Index compatibility: friction
- Chain width: 3/32”
- Logic: top normal
- B pivot: two sprung pivots
- Materials: aluminium knuckles, steel parallelogram plates and pulley cage plates
Thanks.
Quoted: 767 Post(s)
Liked 1,898 Times
New or vintage?
No need to over think it, as plenty of stuff will shift that range. A Shimano Titlist from that period would work fine. Lots of other options too.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,480 Times
https://www.ebay.com/itm/1-Pair-Shim...IAAOSwnnlbdr9~
You will also need a little bit of grease.
Likes For SurferRosa:
