Stickering a Frame
Stickering a Frame
Hi,
Sorry maybe this belongs in a different thread, I couldn't find the most appropriate straight away.
I've been collecting random stickers for a few years with the idea of using these to 'paint' a frame and I recently came across a frame that might be good to try it on. Will this work if I strip the current paint, put the stickers on and cover it with a simple clear lacquer to finish it off? Are there any foreseeable problems I should be aware of?
Thanks in advance
Thanks in advance
Quoted: 9 Post(s)
I stripped the paint of my aluminum cx bike and sprayed a laquer to try to give it a little luster. The lacquer flaked off entirely in the following weeks.
Granted: I bought the cheapest I could find and had no idea what I was doing. Obviously people have succesfully coated aluminum, but this is just to say that it can be done wrong.
Steel might be a different story, if that's what you're working with.
Lacquer might also do strange things to the stickers.
If this is aluminum I think it would be neat to leave it raw. The stickers would wear down and bleach much. Could be neat.
Quoted: 4198 Post(s)
Liked 3,849 Times
Stickers can have a base material that can stretch or contract with age and temps, paint tend to not do so. Paint likes even/smooth surfaces with no cracks or gaps to flow into or cover. Stickers often will have thick edges and are applied with uneven layers. But it's your bike. I might not strip off the OEM paint though... Andy
AndrewRStewart
AndrewRStewart
Thanks for the advice...
Quoted: 9 Post(s)
Is yours an aluminum bike? I think the raw look is pretty elegant, so if you're not happy with the paint give it a shot. Here's what mine looks like.
Quoted: 303 Post(s)
Liked 136 Times
For clear coat an automotive type might be best, you certainly want some UV protection built in to the clearcoat.
Non-UV protected finishes do poorly outdoors. It would also slow the bleaching of the stickers by the UV.
Bikes Not Bombs Sticker is on my Bike.
