Touring & Gravel (currently only road experience)
Quoted: 5 Post(s)
Hey All,
Found some great threads on here and decided to join. Had a Fuji Sportif 1.5D as my first road bike but was stolen some time ago. Currently in the market for a new bike and if you have time to offer any guidance it would be appreciated!
The Fuji Sportif was great, I know I do not want a more aggressive riding position than that. I felt a little stretched, but it was the correct size frame. It was smooth to ride but if I can keep vibrations down and comfort up that will put a smile on my face (I am not racing) Given some crappy roads in my area and just the potential for trying something new I am considering a gravel bike. Price point is a bit of a factor and I'd like to keep it under $1000. I have looked long enough and just want to get riding again.
Considerations are:
Fuj Jari 2.5, Fuji Touring, Raleigh Willard 2, Bombtrack Arise 2.
I am really eyeing one of the Fujis but placed the others there as it came up frequently in gravel searches and I don't want to be closed minded. Fuji has a lot of info on Geometry and I am curious if there is much of a difference in their "Adventure" vs "Touring" geometry? I am trying to maximize comfort and me wanting to be on the bike. I don't want to be straining to reach, Id like the ability to pedal around town but want to retain drop bars as an option. Not sure if the Fuji Touring will deliver a more upright situation the the Jari or is it pretty much the same?
Thank you for any and all pointers, I cannot post links yet so that will hurt with the price comparisons and specs for the bikes, but I am looking closer to the entry level side of things. All of these bikes I found for 900 or lower,
Considerations are:
Hey All,
Considerations are:
Considerations are:
Poseidon X $600 A great looking and equipped bike that is very customizeable and is decently light weight.. Internally routed cables, disc brakes and carbon fork an amazing buy at the price especially. I will be buying this one by the end of the year.. It seems to be the perfect balance of everything I want.
Aventon Kijote $600 Another great looking Bike at a good price, this one is geared High for road use with some gravel qualities.. I hear reviews that this one is very comfortable but a lil heavy.
Bikes Direct Gravel X3 $500 An awesome looking bike with so many damn mounting points for touring and very decently equipped for it's price.. Bikes Direct is the Off brand store that sells some bad ass Bikes..
Bikes Direct Omni Strada Comp $1000 Another Bike from this store that is a lil more High end.. It's gearing is more for road but can handle gravel..
Shimano 105 for most of it's drivetrain.. Has some mounting points for touring..
I didn't list the Raleigh Willard because you had already mentioned it. I also looked at the Willard 2 and 4.. Both of them seem like Solid Choices.. That Willard 2 looks really classy.. I love the look of it..
Diamondback also has a good set up with their Haanjo Series of bikes.
Quoted: 169 Post(s)
Liked 84 Times
There are many good hybrids that will serve as a dual role bike. i.e. road and gravel.
Myself, I am into bikepacking so my gravel bikes are mountain bikes but often set up a bit less stretched than my road bikes.
Quoted: 5 Post(s)
Thanks for the suggestions, any thought on the Fuji Jari vs Fuji Touring concerning performance & geometry differences?
The Omni Strada Comp costs the same as the Fuji Touring but has much better parts on it.
And looks just as nice if not better.
The Omni Strada Comp gets you a Carbon fork a nice FSA Crank and the rest is all Shimano 105
and it's a 2x11 speed
For the price it would be very hard to beat.. $1000 for all of what it offers
Quoted: 18403 Post(s)
Liked 15,495 Times
For those of you who haven't toured, you need to consider gearing carefully.
BTW...Claiming a low gear of 28x32 when the smaller of the two chainrings is a 34 makes no sense. I also don't see any front rack brazeons on the fork.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
If one is doing fully loaded touring somewhere other than over flat terrain one would likely be replacing drivetrain parts on a new bike.
For those of us unversed in touring, are you suggesting that a newcomer should probably be looking at a triple if they're going to encounter hills and ride dirt with full loads? I'm reading between the lines on your post, and you seem to be suggesting there's no good substitute for a granny gear up front. That makes sense to me, but I'm just making sure I didn't make that up in my own head.
Likes For livedarklions:
Liked 15,495 Times
For fully loaded, the need for the front braze-on is obvious, good catch.
That Motobecane isn't gear much lower than my much lighter ti road bike, which has DA9000 with a low gear of 34x28.
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
The Omni Strada has relatively short chainstays, no front rack mounts, only 2 bottle mounts, and a woefully underwhelming and overgeared drivetrain for loaded touring. Its a completely different bike than the Fuji Touring, so comparing them is absurd. Just because they both cost the same doesnt mean they are comparable.
Likes For mstateglfr:
Sunshine
Liked 7,474 Times
Hey All,
Considerations are:
Considerations are:
The first pic is the Fuji Touring and the second pic is the Fuji Jari 2.5. Just compare the stack and reach frame measurements for your size. Stack is how high up the handlebars feel. Reach is how far out the handlebars are. These measurements are frame based, so they exclude variables like spacers or different seem lengths and allow you to compare 2 bikes on the part that cant be changed- the frame. Handlebars, stems, and spacers can always be adjusted to make a bike fit better, but the bones cant change.
In general, it looks like the Touring model has a higher stack and shorter reach than the Jari 2.5 so it would effectively ride more upright. But thats comparing stated size of one to stated size of another. Perhaps one model in size M is best while the other model in size L is best. This is the benefit of stack and reach- it normalizes differences in seat tube and head tube angles as well as other measurements to give a more easily comparable setup.
Quoted: 169 Post(s)
Liked 84 Times
I use frame bags for my touring/gravel bikes. My first bikepacking bike had a suspension fork on it but the next one has a Lauf. On the front fork, I tywrap 2 water bottles on each fork. I have a custom EPDM tongue looking thing that keeps the bottles secured. In this early iteration, I was still using hose clamps. There are always options and one size does not fit all.
Sunshine
Liked 7,474 Times
I was simply listing the obvious ways in which the two bikes are different- and the lack of front rack mounts is a big one for traditional loaded touring...which the Fuji Touring is designed for.
As said- they are different bikes and shouldnt be compared.
Your style of touring is also different from traditional loaded touring.
None of the setups are right or wrong, they are all just different.
Quoted: 169 Post(s)
Liked 84 Times
Not to derail the thread. My touring is on environments like the Tour Divide. Anything from pavement to gravel road, to rutted jeep trails to horrid single track. It is also very minimal as the load out is concerned with a target bike and gear weight of around 45#. This is a full loadout sans water bottles on the forks.
Likes For bakerjw:
? I struggle to understand how the Omni Strada Comp has better components.
Quoted: 5 Post(s)
Thank you all for this lively discussion! Appreciate the dimensions breakdown. I have been fitted on a machine at the Trek store when I had been in search for the Fuji that got stolen.. Consistently there and even at the store I bought my last bike they all reverted back to saying 56cm was just too small. I am too much a novice to be able to discern small increments unless it got uncomfortable, so I am just running with 58cm based on that. Looks like the Fuji touring has a higher stack and a longer reach? In reality Id probably love either bike and either would meet my needs, I just don't want to be reaching too far..
Sunshine
Liked 7,474 Times
Basically, 3mm is so small i wouldnt give it much consideration.
Quoted: 5 Post(s)
If you look at the 58 in both sizes(there is an argument that you shouldnt, but whatever) then the reach is 3mm bigger on the Touring bike. That difference is so insignificant it almost isnt worth considering. A stem swap will reduce the effective bike reach by 10mm. Handlebar reach varies by more than that much between models, so you could make up the difference with different bars too.
Thank you, the differences in dimensions often seems so small it's hard to determine what the actual impact on overall fit is. It is hard not being able to get to a store that has numerous models available to try out locally but I appreciate the help here.
Quoted: 47 Post(s)
Liked 97 Times
Marin Four Corners - standard. $1,000. Steel frame with a more upright position, especially if you flip the stem. It’s spec’d for specifically for adventure, touring and gravel.
Quoted: 5 Post(s)
I actually just looked into the Marin bikes and they look like reasonable bikes for sure. Took a short hiatus from my hunt but found a couple of bikes from bikes direct, I was apprehensive about going that route but have read some good reviews. I was able to come across their "best" range for gravel and was wondering what you all thought? I am unfortunately not allowed to yet post a link or the screenshots I was trying to provide.. There are inexpensive carbon bikes listed but I am uncertain as to whether the carbon from bikes direct is good and/or safe? Thoughts appreciated and thank you so much, the resources on this forum just searching old threads have really opened my eyes to a lot.
Liked 15,495 Times
Don't fixate on what the seller calls the bike. Answer some personal questions like: Does it have gearing suited to your abilities and how you like to ride? Is capable of supporting the type of gear carrying system you intend on using? (E.g. Braezons for racks and fenders if that is what you plan to use.) Long enough chainstays if you plan on using a rear rack and panniers. Strong enough wheels to support your load and accommodate the width of tires you want to use.
I ride my Surly LHT on all sorts of unpaved surfaces during mixed road/off road tours. It's not a "gravel" bike but it suffices.
Quoted: 7649 Post(s)
Liked 3,465 Times
First off ... @indyfabz has done some serious road touring and knows some stuff.
Second ... How Much Touring? Once a year, once a year for a month, a week, a few overnights a month?
I looked at the Marin, the Yari, and a Fuji Sportiv and got the Sportiv because for Light touring it is fine and for loaded touring it can take a clamp-on front rack, though some people say it cannot (careful with tightening and loading.)
However ... if you are going to be doing loaded touring for any amount of time, you probably want much lower gears than 50-34 .... I'd take 46 or even like a 42/32/22 MTB triple, because the hills only get longer and steeper and the load only gets heavier particularly for the first week or so. And some days, the next campsite will be "over that small mountain up ahead," and your body will say "Can't we just sleep on the highway?"
It depends what kind of camping/touring you do. if you need all your water for a couple days, that weighs a lot. Add food, and if you want a stove .... plus shelter and a sleeping bag, and tools, and weather gear ..... Bikepackers get away with sleeping in bivvy sacks and just suffering sometimes ... I am too old for all that.
However .... if you just want a "do-it-all" bike that can serve reasonably well in several roles and Won't be expected to do multi-week tours (or not often) the Yari is a pretty solid bike. I haven't looked at one in a while so i forget the specs .... but i think ti had like a 46/32 or something up front? which is low for the road but you will appreciate on gravel, and with wide tires, all roads become smoother.
You really need to decide what you want the bike to do best, and what it just needs to do well enough. I can load my Sportiv with a ton of gear ....I could easily do a three-day tour, so long as the terrain was flat. I have tried to climb a semi-steep (6~7 %) hill fully loaded and it Sucked .... and that was early in the day.
But if you plan to mostly ride pavement with an occasional foray onto gravel and a few short tours now and then .... most of the bikes you have listed look strong. You really need to figure out as closely as possible, what you plan to do with the bike and how often, to dial in the best choice for you.
Liked 15,495 Times
Zactly. From a numbers perspective, most of my trips are paved road trips. However, I try to get out west every year and do loops that feature mixed surfaces that can run the gamut (except no single track). Last year was a good example. First day was all paved. Second day featured a 15 mile, unpaved climb on a Forest Service road that was well maintained. Day three started out on pavement but then switched to an unpaved Forest Service road, then a 14 mile, pretty well maintained, unpaved bike trail, then a another unpaved Forest Service Road, then a less well maintained, unpaved bike trail, then I-90 then a well paved bike trail. I've got a loop planned for this summer that features a good amount of "dirt," including one 23 mile, hilly road that even has a section of bare rock. I can get by with what I have on the types of paved and unpaved surface I ride, but if I were going to do something like the Great Divide Route I would certainly buy a more appropriate bike.
