Flashlight for bike?
So I bought a bike 2 days ago from Walmart (Im a newbie at bikes) and I noticed there’s an object between the handle bars that looks like a flashlight for bikes. What is it and how can I exactly turn it on? (I can’t provide images because I need to post 10 threads.) Thank you.
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,593 Times
What is the brand and model name of your new bike?
Quoted: 18373 Post(s)
Liked 4,508 Times
@RiotArrows's Album
https://www.bikeforums.net/g/user/509029
https://www.bikeforums.net/g/album/15885583
There are quite a few different bike light types. If you do purchase lights, I'd encourage going with both front and rear lights, and getting RECHARGEABLE.
If you use your bike as a commuter, then anything that isn't bolted to the bike is subject to theft.
Liked 4,508 Times
You haven't asked yet, but that thing that looks like a wood screw should adjust how far out the brake lever ends up when you release it. I.E. How close the levers are to the bars when not in use.
If you have small hands, then tighten the screw until the brakes are comfortable.
If you have large hands, then leave the screw alone. You may even be able to remove it.
The greater range of motion of the lever, the less chance it will bottom out against the bars and not stop you.
The less range of motion, you'll have to take more care to adjust the brakes.
That silver locknut and screw on the end of the cable allows you to adjust the brakes somewhat closer to the rim, or further from the rim if they rub. With high quality road bikes, one often targets 1/16" to 1/8" between the rim and brake pads. With MTBs, perhaps 1/8" to 3/16".
Over time pads wear, and cable can stretch, so adjustment is common.
If you adjust the levers with that "wood screw", you may have to compensate by letting out a little more cable, either with that adjustment on the cable, or the pinch bolt at the brake calipers.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Probably not impossible nowadays to design an LED light that looks just like a simple bike reflector, but not aware that has been done.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Answering another question you didn't ask, here's the lights I run on my bike. These are definitely of the "be seen" rather than "for seeing" category. They're rechargeable with a USB cable, and don't require any hardware to install. I like them because I can easily switch them from bike to bike.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Liked 4,508 Times
For a battery powered light, one still needs the batteries. Button batteries work, but don't last long.
For the rear, cars are required to have reflectors, and light/reflector combinations are common on both bikes and cars. One can shine a light through a rear reflector.
It is less commonly done on the front, and one would generally desire a headlight to be focused rather than scattered.
Quoted: 523 Post(s)
Liked 229 Times
Plenty of budget lights out there
Before you get carried away spending nearly as much on your lights as you did for the bike, go to the Electronics, Lighting, & Gadgets forum https://www.bikeforums.net/electroni...hting-gadgets/ and look at the three stickies at the very top of the page where you will find suggestions for reasonably priced LED bike lights for bike headlights and taillights. Go to the last page or so in each heading.
This is my favorite bike flashlight/headlight shown in the top right picture.
It is a CREE XML-T6 flashlight (~900 lumens) and 360 degree flashlight holder made especially for flashlights that can use a Li-ion batter. The holder costs a bit more than a dollar from overseas vendors or about $4 from US sellers. The last time I bought a couple of these flashlights as gifts they were under $7 from US sellers on eBay. A high quality Panasonic 18650 battery for the light is about $7 each and a simple charger for Li-ion batteries is a couple bucks. You can also find a good 100 lumen USB rechargeable tail light with a 500-650 mAh Li-ion battery in it for well under $10. You can run these flashlights on alkaline batteries as long as you buy one that includes the battery holder.
This is a 100 lumen RayPal 2266 tail light with a 500 mAh Li battery and is USB rechargeable. I see it at $6 from a US seller on eBay and a little under $5 from Chinese eBay sellers. It uses the latest chip-on-board LED technology. It's plenty bright for day or night use. I've owned mine for several years and it still works fine.
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
There is a somewhat reasonable way to use a small flashlight as a cycling light, but that's to put it on your helmet and keep it zoomed in narrow and positioned such that it is aimed quite down when your head is in usual position. Then you can light where you need to see - mostly the ground in front of you, or a possible obstacle you need to check out. You can also rapidly pan it across oncoming traffic (especially motorized) while still at a distance to draw attention, without keeping it in others eyes. And most importantly of all, as you're actually passing someone you can tilt your head to aim it down and to the side - which is probably where you want your own eyes too, on account of their light.
Liked 4,508 Times
Please don't use a flashlight on the handlebars. Because the pattern is round, it's going to put light in the eyes of oncoming cyclists, rather than on the ground and horizontally where you need it.
In many cases, one gets the best view by focusing the beam on the horizon, and getting scatter downward. But, unfortunately an equal amount of scatter upward into approaching pedestrians and vehicles.
Many of the bike lights are extremely bright, with essentially a point source which is aggravating to oncoming people.
If you have a flexible mount on the light, it can be polite to either dim it or point it towards the ground when approaching others.
Tragically Ignorant
Liked 9,098 Times
Unfortunately that is a common problem with many of the cheaper lights, giving off a symmetrical beam.
I've always found bicycling to inherently involve more necessary multitasking than driving.
Liked 4,508 Times
If you're on the road at night, I suspect that constantly having to adjust your headlight is going to cancel out some of your margin of safety you've gained by having lights because it's just one more distracting thing you have to attend to. Much better to just find a set it and forget it position and brightness. You're describing a lot more adjustment than flicking between your brights and dims on a car.
However, one thing that I like about dimming in one form or another is that it acknowledges to the person you're approaching that you've seen them.
I disagree that dimming is beyond the scope of what a cyclist can safely handle.
Quoted: 523 Post(s)
Liked 229 Times
It is not unreasonable to use a flashlight as a bike light. The one I recommended can be focused for beam width and the 360 degree flashlight holder allows you to aim the beam toward the ground in front of you exactly where you want the light to go. It doesn't cast vast amounts of light straight ahead and up. It certainly can be seen by vehicles even when aimed at the ground. I simply can't understand why some riders get their shorts in a bunch over the light from a flashlight aimed at the ground when the beam from a vehicle approaching from the other direction is far brighter and more widely dispersed.
Tragically Ignorant
Liked 9,098 Times
The biggest risk is missing the person without lights coming up behind the person that you see.
If there's a switch that you don't have to feel for sitting on your handlebars, and you don't actually have to reorient the light, that's probably right that it's within the scope of safe operation, but that's not what you were describing.
My observation is that at night, I need to attend to things like pothole avoidance, etc., that are a lot harder to do than during the day. There's no way that adding another task to the list is going to make you safer, and everything I know about the human brain says that the more tasks you have to perform at once, the more likely it is you're going to screw one up. Safety measures and equipment are all issues of probability, and it's completely absurd to argue that there is any benefit to having to fiddle with and fine tune equipment while riding on a bike at night.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Three days and 15 posts later, let's hope the OP - missing in action - has figured out that their reflector is 'always on'. Would have been a good candidate for the Cateye Reflex Auto front and rear safety lights, which had large reflector surfaces combined with LEDs, activated by photocell/motion switches.
Tragically Ignorant
Liked 9,098 Times
Liked 4,508 Times
Not a peep from the OP, @RiotArrows?
genec
Quoted: 13658 Post(s)
Liked 4,532 Times
I love my Niterider lighting system, with thumb controls for light intensity.
I also ride with two rear flashers, one high and one low, well as the steady red from the Nightrider. See, AND be seen.
I also have a backup flashlight, easily removed, should I need to find my way or fix a flat. I use that light as a daytime front blinky.
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
But DO NOT put light on helmet unless an off road mountain biker who needs to see around more. Helmet use will surely blind other cyclists when they look at other cyclists and they are prohibited in many of the night rides I go on for this reason.
Quoted: 930 Post(s)
Liked 393 Times
A fixed round pattern flashlight has to have too broad a beam and too much light if it is going to provide sufficient coverage in a setting without streetlights. With fixed light you can't check out things to the side without wiggling the bars, and you can't scan further ahead than the fixed down angle allows. Thus to actually see what you need to, you end up putting out too many lumens in too broad a beam: there's a reason viable fixed lights don't have a round pattern.
But a head-mounted light can be a very narrow beam, because it only puts light exactly where you are looking - by default the ground directly in front a braking distance ahead, but if you chose also way up at the limit of vision where you are checking for reflective signs in the distance, at that odd shape beside the trail you are wondering about, or only very briefly while they are still far away, throwing an attention getting flash of light across that cyclist, pedestrian, or car.
Once you've identified what they are, there's no reason to look at them (and their light), instead look down and to the outside, same as they teach in driver's ed for dealing with oncoming headlights.
Should their path actually change, that's readily visible in peripheral vision.
If you must sneak a peak, look with your eyeballs while keeping your head (and thus your own light) down and to the side.
Bikes: Shmikes
Quoted: 10165 Post(s)
Liked 5,856 Times
Quoted: 18410 Post(s)
Liked 15,530 Times
