Przewalski Testimonials
I recently bought a pair of Przewalski 4D Bike Shorts and absolutely loved them and consider them at $27.99 to be the best value in Bike Shorts you can buy.
What Przewalski Products did you buy and what did you think of them...Thanks,mjac
Likes For mjac:
Quoted: 1068 Post(s)
Liked 781 Times
Tried 4D and sent them back. Really cool thing was that my CC was credited as soon as UPS Store entered the returned shorts as being checked in.
I will bet that was an Amazon return. That was what was amazing to me and it has happened several times. As soon as UPS registers the return,which is very shortly after you dropped off the return, your refund is issued and your CC is credited before it is even shipped let alone received. So there is no need to take an Amazon Credit for a fast refund when you can get a cash refund extremely fast. There is no long drawn out delay. It is much quicker then getting a refund back to your card from Walmart or NAPA. Gives you the chance to try different things and sizes painlessly...Thanks,mjac
Likes For mjac:
I bought a pair of their Bib fleece lined tights this winter. I haven't worn my Gore windblocker tights since then that cost 4X as much.
You, "Canklecat" and "Old Try Guy all like the 3D pad over the 4D pad, even though both are good. I really have to try the 3D pad. But the 4D pad I have is so comfortable I can't imagine that it could be that much better.
Do the shorts fit true to size? I'm a 34 waist and according to the size chart I'd be a large. When I read reviews on amazon some people say they fit true and of course others say the run small or large.
This is important in order for you to be able appreciate the Przewalski Bike Shorts and get the most out of them. So instead of making a recommendation on sizing I am going to simply relate to you my experience and you can make your own judgement as to what to do. Right now my waist, unfortunately, measures 39" so I bought the XXL which the size chart says is 33.1"-37.1" They were obviously too big. So I ordered the XL which is listed as 31.5"-35.5". (Notice the overlap in sizes) These were okay, but still didn't have the compression I was looking for. So I ordered the L which is 29.9"-33.9" and held on to the XL to compare the fit. The L was perfect, real good compression,good fit and made the pad work more efficiently and be more comfortable. These shorts are made to work being tight. So I ended up with shorts 5.1" smaller then my measured waiste from the maximum measurement for the L. Buy them with Amazon Prime an order the smallest shorts you think you could possibly fit into and the next size up. Try them on side by side and use the Prime to return the one you don't want for free. You have to get a nice tight fit to enable you to enjoy them...Hope this helps,mjac
Just hold on to the large if you are not sure and order the medium and then compare them side by side. I was undecided about the XL, I was kind of happy with it but I said let me try the L just for the heck of it and I was kind of happy with the XL. But when that L came with that extra compression it was like night and day, you know that feeling when something is right. All I am saying is that these shorts work when they are tight,especially the pad. If your L is the least bit loose or just not tight compression don't hesitate to order the M. You would be cheating yourself. I can not overemphasize this.
I forgot to mention something, at least for me, everybody is different, the one problem was the legs ride up significantly for me. "Canklecat", who recommended the shorts to me,said they don't much for him. I bunched as much fabric as I could around the inseam on the leg bands and sewed it on the outside and the inside to make sort of a hem creating more compression at the leg bands. It eliminated a lot of the ride up. You may know of a more sophisticated way to do it like sewing in bigger,wider silicone grippers or something.
Likes For Moishe:
There ain't no shipping and "handling" charges with Amazon Prime and all returns are free and very,very simple with an almost immediate credit to your bank account the moment the return is registered by UPS which is right after you hand them the return item and they package it for you. The only way to roll, love them or hate them, you have to give the devil it's due. Try again.
Just got a pair of the 3D based on the praises here. I'm about 6' tall, 175 lbs. Waist is about 34...okay, 35. Ordered the medium, normally I'd get a large. They seem well made, nice pad for the price of $20. I suppose fit is personal. I found the medium a bit too tight - okay for the compression affect, but quite tight around my thighs - not that I have big thighs. I would probably keep them but I prefer a higher rise and a longer inseam. The BALEF 3D shorts, also on Amazon and costing just a bit more gives me that, in a large. I do like the pad in these Przewalski shorts. I will return these and see if a large is a little more comfortable. Will report back
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,830 Times
Am I mis-interpreting the website? The 3D pad is only available in the underwear shorts? Not the bibs or riding shorts?
From what I understand the 3D is available in the Bike Shorts and the new two tone Flourescent Green/Grey 4D Pad is available in the Bibs. The 3D shorts are less expensive then the conventional 4D shorts. I have the 4D Shorts. You can PM "Canklecat", he knows this stuff inside out...mjac
Advocatus Diaboli
Quoted: 4731 Post(s)
Liked 1,531 Times
fwiw, Przewalski seems to be a brand originally (or still) owned by Tenn Outdoors (a UK company), which is evidently currently in liquidation.
These may be similar quality but under their original parent name brand
Tenn Outdoors | Pandion Cycling
Quoted: 722 Post(s)
Liked 353 Times
so why are we spending $100 -200 on bibs in usa.
name brand stuff is crazy.....
Precisely. It is called Marketing. It would be great if Przewalski and companies like the became "Name Brands" based on quality and value not hype. I will do anything to have these companies recognized. Which is the reason for this thread. To give them the recognition they deserve for giving us a good product at a good price, no BS.
Anyone have issues with the leg opening bands on the 3D or 4D? They look kind of dorky and I've read they're not very tight, get looser with use and don't do a good job of keeping them from riding up. Thanks in advance.
I have the 4D and I love them, just got through with another ride. That is the one problem at least with the 4D, I do not know about the 3D. The legs ride up significantly. They look good, have a nice wide leg band and small silicone grippers inside the leg band, but they ride up quite a bit. There is an inseam that runs all the way through the leg band. I gathered leg band material on both sides of the inseam and sewed a hem in the leg band on the inside and outside to tighten the compression of the leg band. This stopped almost all of the leg rise. There may be a more sophisticated way to do it by sewing in wider,thicker silicone grippers. Maybe someone could tell you. But don't let this issue stop you from getting the shorts. They are phenomenal and their compression increases as you where them. Just come up with your own solution for the leg rise and you are set with the greatest value in shorts on the market at $27.99. I would compare them with any $100 shorts on the market...Thanks,mjac
