Lighing to compliment our C&V's
Quoted: 174 Post(s)
Liked 243 Times
You can feel the weather in my neck of the woods start to shift from Summer to Fall. The mornings are darker and the sun is going down sooner. Lighting is starting to become an issue and the online bike companies know it due to the amount of emails I've received from Nashbar and the like reminding me to 'get your lights now!'.
On my '91 Voyageur I currently have black colored Knog's on the front and rear as lights designed to be noticed, not to light my path. I like them because they are minimal, clean, simple, fairly powerful and easy to transfer to different bikes in the stable quickly. What I don't like is that they suck batteries down and I feel like I need stronger, tougher lights when it comes to the shifting weather and harsher conditions that I plan on riding in.
I want lighting that is strong, able to be used as a path lighter not just a 'notice me' light, minimal in design, not a helmet light, does not have an external battery pack (unless it somehow keeps it minimal), rechargeable/USB would be nice and aesthetically pleasing.
That said, what do you use and/or suggest?
Knog lights*:
*This is not my bike or my pictures
Knog lights*:
Quoted: 378 Post(s)
Liked 1,409 Times
minimal in design,
not a helmet light,
minimal in design,
not a helmet light,
I like it a lot, and I hate bike lights.
missing in action
Quoted: 42 Post(s)
Liked 49 Times
I've got several LED flashlights from dealextreme that run on a single 18650 rechargeable battery. They're not pretty, but not too obtrusive either, and the output is fantastic.
Bikes: I hate bikes!
Quoted: 431 Post(s)
Liked 710 Times
Are you against using a generator hub? You can mount the head light to the front wheel's quick relaease to facilitate easy swapping between bike and PB Super flash for the back.
I can't really help. I want the lights to be on when I'm on the bike. I don't want to mess with batteries. I'm forgetful. I want to have bright lights that light the road well ahead of me. These are some of the reasons I use a dynamo hub. The only bikes I ride at night are those equipped with dynamo hubs.
A battery tail light is fine with me as they're very efficient. Fender1 is right. The PB Super Flash is ridiculously bright. It's annoying to ride behind someone who uses one. And now, they have a Turbo Flash. It's an attention getter for sure.
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
+1
for ~$15 for the light itself you can get 300 lumens.
A little over double that gives you 900 lumens (claimed).
2 18650 Batteries + charger IIRC ~$18.
I use a TwoFish block to mount the light under my handlebar. I think I paid ~$12 for 3 pkgs of 3. More than I need.
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Quoted: 174 Post(s)
Liked 243 Times
Thanks everyone. Fender, I like the idea of a generator hub but since it requires a bit more research, planning and cash, I'm going to consider that a long term option I'd like to eventually build up too. Good suggestion!
Bikes: some
Quoted: 10 Post(s)
Those Knog lights don't look too bad. I may order me up a pair. Just checked their web site, they do have at least one rechargeable, athough it's larger than those pictured above.
Quoted: 174 Post(s)
Liked 243 Times
Colonel/Fender, does the generator hub need to be rear wheel driven? I'm starting to like the idea the more I (re)consider it.
Bicycle Repair Man !!!
I use knogs and other blinkies as backup lights for bikes that typically don't have anything mounted... for serious night riding I have much brighter LED and Halogen lights that are battery powered as well as a few generator hubs wired up.
Nice solution is to use an old incandescent headlight and convert it to LED... classic look and modern performance and believe one company makes a nice retro light in this manner... just cannot recall who makes it.
No Money and No Sense
Generator hubs are used in the front, and there's a two wire connector on top for lights. Sanyo makes one that costs around $40, Shimano has a smoother one for around $100, and Sturmey Archer makes a generator/drum combo that uses Sanyo hub parts that runs around $70 or so. Germany requires bikes to have an approved lighting system, so they've added all sorts of accessories like phone chargers that can be run off the hub.
Curmudgeon in Training
Bikes: 1974 Gazelle Champion Mondial, 2010 Cannondale Trail SL, 1988 Peugeot Nice, 1992ish Stumpjumper Comp,1990's Schwinn Moab
Quoted: 19 Post(s)
Liked 9 Times
For rear lights, I generally get one that has a reflector type surface as well. That way should my batteries die, the car's headlights might reflect off the surface.
Quoted: 469 Post(s)
Liked 2,442 Times
I don't like putting lights on my bikes. I wear whatever clip on tail light on my backpack(which I usually wear when riding) at night. Where I live, there aren't a lot of street lights, so I use a Niterider Cyclone on my Helmet. It's pretty dang bright, and gets me to where I need to go after dark. Only drawback is the weight of the light on my head, and the heft of the battery pack.
Sometimes, I'll use a cheap LED light strapped on the bars with a rubber band.
NOTE: for bikes with fenders, I have seen a couple of fender mounted tail lights that don't look terribly bad. I may end up trying one of these just for ..its and grins:
Bikes: Devinci Tosca S
Quoted: 26 Post(s)
There are these from SOMA:
https://www.somafab.com/accessories/lighting
I read though that the body of the front light is made of plastic. Not sure how durable that's going to be.
Randomhead
Liked 3,687 Times
I would ask someone you trust to check and see if they can see your light from a distance. My experience with lights on bags or helmets is that they are effectively invisible except for short, useless flashes.
These work well with LED lighting but do not generate enough to run a halogen.
Quoted: 469 Post(s)
Liked 2,442 Times
I will do that, thanks for pointing it out. I should mention that my backpack has a sewn on reflector(about an inch thick) that stretches across the back, and a little to the sides.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
I use the PB SuperFlash Stealth on several bikes. Is all but invisible on a silver seat post. For headlights I like the looks of the B&M Cyo in chrome. I use generator hubs on several of my bikes. I also use rack and fender mount tail lights those vary by bike.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Half way there
Bikes: 69 Hercules, 73 Raleigh Sports, 74 Raliegh Competition, 78 Nishiki Professional, 79 Nishiki International, 83 Colnago Super, 83 Viner Junior
+1 I used to see a cyclist heading the other way from me in the morning. I noticed that he had a helmet mounted light, but the problem was that it was all but obscured by his backpack.
CliffordK
41
05-14-18 01:20 PM
Richard Cranium
45
04-28-12 10:44 PM
dougmc
6
08-05-11 06:44 PM
