Needed-Cleat Redesign
Lots of old school riders with rat trap pedals. We need cleats designed for the new shoes that work with toe clips.
Expired Member
Quoted: 3675 Post(s)
Liked 5,441 Times
Current clipless pedal systems work well. Clips and straps are dangerous and fiddly if used as designed. Give clipless a try.
Edit- Yellow Jersey, who knew? Those things look scary!
Likes For shelbyfv:
Quoted: 18424 Post(s)
Liked 15,581 Times
Back in the 1970's I rode with cycling shoes with toe clips and cleats. I'll never do it again. Once the strap is tighted tight enough to hold the shoe, it is not easy to remove your foot from the pedal in an emergency. More than once I fell over at a stop light because I couldn't get my foot out in time. For me, yes the nostalgia is there but not the will to do it again.
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
I rigged up my old bike with its original Dura Ace pedals, complete with period correct pedals and slotted cleats.
It was a little interesting getting out of town. The open country roads were fine even with the zero degree float.
I think it was a 50 mile experiment. I don’t regret it, I stayed upright. I put my clipless back on after that ride and haven’t looked back.
Fortunately, my old bike is from the 80’s, so things like red and white Looks are a perfectly correct option.
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,437 Times
I had a pair of cycling shoes that had the higher ridges. If the straps were tightened more than a tad loose, it was hard to disengage from the pedal. I am fine with the current available systems. I mostly use SPD on all my bikes. I like SPD-SL. but I get off my bike much more than I did in the past. I have covers for those, but, of course, I have to remember to take them with, and then put them on when I dismount the bike. SPD, plainly and simply, works best for me in most situations. I do have an errands bike that has plain flat pedals. I can just jump on it and not have to change shoes.
If you are worried that you might have problems with clipless use the CHEAP Shimano SpD MTB pedals. They are easy to get out of. The expensive pedals are harder to exit from. I would also suggest Pearl Izumi off-road pedals since they have good walking surfaces as well. Too bad the Performance shops are gone, They used to carry a selection of shoes so that you could actually try them on. Bicycle shops normally have a smaller selection and usually expensive shoes.
https://mrpbike.com/collections/power-grips
Likes For coupster:
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 169 Post(s)
Liked 192 Times
I started riding with slotted cleats and straps back in the day. As soon as I could afford the new clipless Looks and compatible shoes, I switched and never looked back (1989 I think). I have no idea why on earth anyone would prefer those horrible old contraptions. They don't work as well for power transfer, are less convenient, and are 100x more dangerous.
Should Be More Popular
Quoted: 22601 Post(s)
Liked 8,928 Times
If you do, go ahead. But foolish imo. As multiple posters above pointed out.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
You want rat trap pedals, Ditch the toe clips and get a pair of Power Grips. Almost as secure as clipless. 500% safer than slotted cleats and straps, They were and still are dangerous. Screw nostalgia.
(BTW, if I'm not mistaken, our new OP is out of posts for the day and will have to wait until tomorrow to try bolstering his case. )
Quoted: 1814 Post(s)
Liked 923 Times
Dangerous? Not really. I tipped over once during years and 10s of ks of riding, but I was riding past the high school & looking at girls.
It's the toe clips & straps that are the PIA, cleats or no cleats.
Quoted: 1944 Post(s)
Liked 2,164 Times
There is one major advantage to using a traditional toe clip, strap, and cleat setup…
you never have to look for your bike after a crash.
John
John
Likes For 70sSanO:
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
Forum member 79pmooney swears the old slotted cleats and leather straps were and still are the bees knees. (Okay, maybe I shouldn't put words into his mouth. But I believe that's what he'll swear, based on many of his posts.) Of course, he also chooses to ride a fixed gear up and down long, steep Oregon hills. A guy who carries an extra fixed gear cog or two and the tool to change them on his hub, a century after the derailler was invented, is probably the only kind of guy who will shun clipless pedals (assuming some kind of retention is called for).
Don't get me wrong--I have some fixed gear and single speed bikes, and I ride them often, on flat-ish terrain. I also have some flat pedals with straps and plastic cages that I use with everyday shoes. I like them as a compromise between bike-specific shoes/clipless pedals and no foot retention. In more extreme riding situations, especially big elevation changes, I don't see why anyone would shun deraillers (or an IGH, or pinion gearbox... something that lets you shift on the fly just by moving a lever). And I fail to understand why anyone would still want 100 year old technology for foot retention, when modern clipless pedals are so good.
Luddites, amiright?
Luddites, amiright?
Quoted: 405 Post(s)
Liked 430 Times
Yeah, a bit, especially getting into them. And, because retention is adjustable on the fly, you end up fiddling with it as conditions change. These are clear advantages for clipless pedals, and are the main reasons they took over as fast as they did.
Dangerous?
No, they're not. Even with the 600 / Dura-Ace pedals and matching PD-64 "winged" cleats, which had three points of retention, (slot in the cleat over the rear cage of the pedal, "wings" at the front of the cleat in the little tab it engaged at the front of the pedal, and the strap,) unless you've got your straps so tight that you can't feel your toes, if you yank your foot up and back, you come out of the pedal. In a crash? The only time I didn't part company with both pedals, (and the rest of the bike,) was when I crashed on the track with slotted cleats and double straps pulled hella tight.
In fact, the only time I've ever crashed due to not being able to get my feet out of a pedal, that pedal was clipless. They were the first clipless pedals I ever bought, the utterly reprehensible SR/Sampson. They had this feature where when you unclipped, the retention spring pressed on the spindle to keep the pedal level. When they got dirty, which they did because they're pedals, they wouldn't release at all. It was a zero-speed stop sign crash, and the only injury was to my pride. (Of which I had an excess, being 14 years old and male.)
Bottom line, toe clips, straps, and slotted cleats are not dangerous. They're just not. They're less convenient, you may not like them, and far be it from me to question anyone's preferences. But preference is all it is.
If I had a bike that I only ever rode in cycling shoes, that bike would probably be clipless. Although the NIB pair of Dura-Ace PD-7400s in my parts box might get the nod, as I really liked the PD-6400s I had... which replaced a set of Speedplays that I also really liked. (The only downside to the PD-6400 / 7400 is that cleats are unobtanium unless you have an original pair and a 3d printer.)
For anything other than a dedicated go-fast road bike, I'm going with clips & straps on a wide, flat, supportive pedal. For MTBs, I've used PowerGrips on every one I've ever owned, although I'm very interested in the Restrap diagonal straps, as they work like PowerGrips but you don't need to break out an allen wrench every time you change shoes and the mounting hardware looks way less vulnerable to damage.
--Shannon
Quoted: 4806 Post(s)
Liked 3,932 Times
Falling over at a standstill? No big deal. I just relax, realize I made a fool of my self and greet the ground with all the skin and flesh I can. (Enough and nothing gets bruised. I get up, dust myself off if needed and ride on;.
Liked 3,932 Times
Luddites, amiright?
Luddites, amiright?
Expired Member
Liked 5,441 Times
Quoted: 405 Post(s)
Liked 430 Times
Actually, they're kinda clipless-y in general. With the straps loose, the retention of the cleat / pedal interface is about 80-90% of the retention you get from most clipless pedals... somewhat similar to my Speedplays, actually, where they feel a lot looser than they actually are. When you need to hammer, you tighten the straps and you're connected. The thing is, they're only great with the PD-64 cleats, which are about as common as toothbrushes for chickens. I have one pair, and one of the front wings is partly broken on one cleat. They still worked as normal, except that getting that cleat fully engaged to pedal was a bit fiddly. If I had access to a 3d printer, it'd cease to be an issue.
--Shannon
Really though, specific shoes to ride a bike that turn into ice skates if you need to walk around in them, couple of hundred dollars for the shoes, pedals …….seriously? Surely cycling designers could come up with something better. Myself, any shoe will do that fits into the toe strap on my metal rat traps, easy to get out of, never had my feet unexpectedly disengage
Likes For sacr:
Expired Member
Liked 5,441 Times
