90mm hub with 100mm fork
Bikes: 80's Colnago
hi,
i have a front wheel with a 90mm hub (came off of a custom TT bike from the 80s). I'd like to use it on a bike with a fork that is made for a 100mm hub. does anyone see any potential problems with adding a 5mm spacer on each end? could this cause the load to be applied to the axle and bearings incorrectly? etc.
thanks in advance
thanks in advance
Extra Medium Member
I don't particularly think you would have any real issues with it. I'm assuming that you are going to be installing a longer axle to make up the difference, yes? I wouldn't use it for loaded touring or anything, but general riding shouldn't really hurt anything.
Bikes: 80's Colnago
hmmm... that doesn't sound all that reassuring. if there are any negative effects (i.e. nothing loaded) then a hub swap will be in order
Mad Scientist
Bikes: Dean TI fixie... Viner ProComp... NEXT pink sparkely!
what kind of fork are you using?
my first thought was to just put the wheel in and go... 5mm of space (on each side) on a steel fork would be fine.
Bikes: 80's Colnago
