Cinelli Super Corsa
Cinelli Super Corsa
Hi to everyone!
I would like to know your opinion about this Cinelli Super Corsa, re-painted without chrome parts, and with a mix of components: Akron stem, universal brakes , campagnolo shifters,campagnolo sr? headset, campagnolo gran sport rear derrailleur and crankset,campagnolo high-flange hubs,and 3ttt saddle,that is all i know.
Thank you very much in advance!
Regards from Spain.
First photos are older, the last one are recent.
Regards from Spain.
Quoted: 4511 Post(s)
Liked 6,381 Times
Same thing we think about all SC's, awesome, cool as heck, love em. Nice specimen you have there.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
OK, I'll be the guy to nitpick about the misaligned seat tube decal. Blame it on OCD.
My Bikes
My Bikes
Quoted: 3464 Post(s)
Liked 2,829 Times
Plenty there to like.
Plenty to hold back the value, that cuts both ways.
I would strip the paint right off, I just don't like brown metallic and I even own one brown bike but it was such a good deal I could not pass.
Quoted: 378 Post(s)
Liked 1,409 Times
I can't see the detail well enough to know if it's even a Cinelli, much less a Super Corsa. Close-ups of the seat stays, head tube lugs, etc would be needed, or I simply missed what I was looking for.
Liked 6,381 Times
Looks like the right fork crown and I think I see the right seat cluster.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Maybe it has the wider 73mm BB? It may be older than you think. I know the serial number database is a mess but maybe @juvela can shine some light? The headbadge appears to be brass so at least early 70's?
Quoted: 834 Post(s)
Liked 2,126 Times
Why is the Cinelli-badged stem stamped made in Spain? Cinelli didnt make any stems in Spain, did they?
Liked 6,381 Times
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Velobase says that an "Akront" made stems and other parts in Spain: VeloBase.com - View Brand
Liked 6,381 Times
That's just a sticker, right?
Crawlin' up, flyin' down
Quoted: 1025 Post(s)
Liked 2,526 Times
Leaving aside the somewhat odd melange of component and focusing solely on the frame, I see some tantalizing clues and have some questions.
In enlarging the photos, the head lugs appear to be the "wolf's ear" kind. Those were phased out c.1960. Close-up photos are needed to confirm this, as the absence of chrome on thos lugs makes it harder to see.
In enlarging the left side bottom bracket photo, it does not look like it has an oil port hole. That would be inconsistent with the wolf's ear lugs. Again, close-up photos needed. Also needed are photos of the underside of the bottom bracket to see if the drain port is there.
The fork crown looks about right, albeit without chrome.
The seat cluster looks more or less correct, but again, close-up photos are needed to confirm. And again, the absence of chrome makes it harder to tell from the photos provided.
So, color me somewhat confused. The head lugs say 1960 or earlier, the bottom bracket says 1965ish or later, the absence of chrome says it was most likely repainted, and the crooked rainbow stripe on the seat tube (good eye, @andy k) says the decals are most likely replacements, too.
I would also like to see a photo of the serial number on the bottom bracket, not because Cinelli serial numbers of that time are any help in dating the frame (they aren't), but because the format and placement of the serial number would help answer the "Cinelli, yes or no?" question. Similarly, I would like to know the seat post diameter - that is about as good a "rule of thumb" clue as there is.
My gut says it is a Cinelli Speciale Corsa that has non-original paint and non-original decals, but with the inconsistencies noted above, I could be convinced otherwise (a 26.8mm seat post would do it, for example).
Liked 6,381 Times
This was itīs previous condition if it can helps, I donīt have more photos because i havenīt bought it yet, but itīs right, it has been repainted with new stickers. Iīm not a specialist on cinelli, but in my opinion i think itīs a supercorsa.
Phyllo-buster
Liked 2,054 Times
Quoted: 1857 Post(s)
Liked 664 Times
I think the original steel crank, bottom bracket parts, and pedals are significant clues. If the seller still has them, perhaps he can throw them in.
Another point: the headset on the rebuild is Record, not Super Record. The Record headset was the absolute best/smoothest one available (IMO) until the Super Record came out. The Super Record was absolutely not contemporary with that frame.
The key outward difference is that the Super Record was alloy, not chromed steel.
If the races of your Record are in good condition, it will last most of your lifetime if you overhaul it once a year or after a major rain ride. Same for all your other high end bearings on that bike. Very good quality materials and design, but usually not much attention was paid to gaskets or seals to keep water out. In some cased they had labyrinth seals to reduce water intrusion, but they don't do the whole job.
Overall, my guess is that it is a Cinelli and more likely to be a SC than a Model B or Riviera. Based on the cotter-pin crank, it might be from the 1950s or up to the mid-1960s. Steel cotter-pin cranks were used in serious professional racing into the '60s, because teams were worried that alloy cranks were too new and unproven. It is NOT a sign of a mid-range or low-range bike.
The stem could have been sourced through any of a number of channels for the rebuild. The original one looks to have an oval logo on the front of the handlebar clamp, which could have been an original Cinelli. If the bike was originally supplied with a Campagnolo rear derailleur, it was most likely a Gran Sport or a Record, not a Nuovo Record.
Phyllo-buster
Liked 2,054 Times
Interesting, those could be early 60's components according to Velobase. So perhaps the frame was ordered and built with all Spanish equipment.
Which groupset is the right one, campagnolo record?
Quoted: 79 Post(s)
Too many question marks with this one. It was in a horrible state of disrepair and there is no documentation. Do you love it? If not, then pass on it and keep searching. It's just an old bike.
Really i like it and the price is good,itīs a supercorsa on my size, and painting with a color that i like. The worst are no chrome lugs and the groupset, although this one can be solved well.
