Anyone have experience with Canyon's sizing?
I've been eyeing a Canyon Ultimate lately and am at a bit of a stand still when it comes to which size I would hypothetically order. Apparently they just take your inseam and height and suggest a size for you. I have a 33in inseam (83-84cm) and am 6ft 1/2inch tall (just over 184cm) . Now when I enter my height at 184cm they suggest a medium bike, and when I enter 185cm for my height they suggest a size large. So, it sounds like either way I'm going to have a bike thats slightly too big or slightly too small for me. Does anyone here ride a canyon and if so what size did you end up going with?
Six months ago I bought a medium Canyon Endurance AL. I'm 6'0" 33 inch inseam and 170 lbs. The thing is a perfect fit.
Quoted: 880 Post(s)
Liked 727 Times
Why not use the geometry chart? The stack and reach measurements on my Canyon Inflite AL in small was bang on with those of my medium Giant.
Likes For surak:
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
I recently bought an Endurace and the recommended size was XS. I’m 5’6” and it fits me right out of the box better than any bike I have ever owned.
This week my wife’s Inflite was delivered. She got a 3XS and it is a perfect fit. Stand over, reach, bb offset, stem... everything is where it needs to be. Very minor tweaking of the fore/aft saddle position and that was it, other than dialing in seatpost height.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
The problem is that the output is counter-intuitive.
In my case, my ideally-fit custom bike has geometry very similar to a Trek Domane 54, which conventionally falls into the "medium" range.
The Canyon website-based fitting takes my input and screams at me in a thick German accent that my legs can't possibly be so short and I am clearly a genetically defective human being, and need a "small". I have zero confidence that I would get the correct-sized bike, and it put me off doing so. (This ultimately may have done me a favor, after warrantying the kid's Canyon frame three times.)
Quoted: 880 Post(s)
Liked 727 Times
In OP's case, being between sizes means deciding whether to go with taller stack and longer reach or shorter stack and shorter reach if the bike has a one piece cockpit that makes it hard to adjust, otherwise the only other things that would likely make a difference in ride feel that aren't easy to change would be wheelbase and crank length.
Bumping this thread rather than creating a new one.
I'm considering the Canyon Inflite SLX 9 Team. This bike seems to run big, can anyone confirm? Most of Canyon's lineup seems pretty big for the given size, something I've also noticed with BMC.
I plan to use the bike for fast / interval-type training on gravel paths and 2-3 hour gravel races. I have another gravel bike that's more relaxed/stable, this will be for fast days. I'm 5'10" with a 33" cycling inseam (PBH) and Canyon is recommending a Small. The Small has a 550mm effective top tube and a 80mm stem. My road bike has a 545mm effective top tube and a 100MM stem but has a longer head tube than the extremely racy Inflite. I always buy a Medium/54 (or 55 if available) in most drop bar bikes, it feels strange to order a Small. Still, I think Canyon's right.
I've got 2 Canyons (Aeroad and Ultimate) both size 2XL. I'm 6'6'' (198cm) with a 38/39in inseam.
Both fit great but have slightly different geometries. Aeroad is more aggressive making it feel like I'm definitely towards the max height allowable for the bike.
But the Ultimate is a bi more relaxed. I feel like I've got some more flexibility to play with the adjustments if I wanted to.
For me, if I were really on the line between sizes, I would definitely size up on the Aeroad, but I'd have no problem sizing down on the Ultimate.
Given the effective top tube of 550mm, I ended up going with the S as recommended. Also, my seat height of 740MM is smack in the middle of the seat height ranges quoted by Canyon (very helpful measurement that all manufacturers should provide, IMO).
It's cool that Canyon offers so many different sizes. Still, in 25 years of cycling and countless bikes of every sort, I've never ordered a "small" before.
Did you get one?
I've been eyeing a Canyon Ultimate lately and am at a bit of a stand still when it comes to which size I would hypothetically order. Apparently, they just take your inseam and height and suggest a size for you. I have a 33in inseam (83-84cm) and am 6ft 1/2inch tall (just over 184cm). Now when I enter my height at 184cm they suggest a medium bike, and when I enter 185cm for my height they suggest a size large. So, it sounds like either way I'm going to have a bike that's slightly too big or slightly too small for me. Does anyone here ride a canyon and if so what size did you end up going with?
I am the exact same size as you. I am curious as to if you purchased one and sized it up or down?
Quoted: 880 Post(s)
Liked 727 Times
If you're in Europe I hear they'll swap cockpit components if you ask when ordering, but AFAIK they still don't do that in the US.
The new method of sizing uses stack and reach. Size numbers or letters are meaningless. If you know your saddle height, it's easy to select a stack height that will produce a specific saddle to bar drop. Reach can only be compared accurately at the same stack height. If comparing two sizes that differ by 20mm in stack, subtract 6mm from the stack height of the smaller frame, assuming that 20mm of spacer will be added.
If you have measured your cycling inseam properly, stack around 530mm would produce a racing fit with a maximum to bar drop of about 10cm. If you want an endurance fit, add 20-40mm to the stack. Cycling inseam is measured from the floor to firm crotch contact in bare feet. My inseam is 83cm, but I'm only 168cm tall.
Klaatu..Verata..Necktie?
Quoted: 10460 Post(s)
Liked 11,957 Times
I gave Canyon my height (5'11.5"/182cm) and my inseam (34.5"/88cm), and they came back with Medium. I checked the Reach and Stack on their Medium and compared it with bikes I already had on which I had ridden thousands of miles comfortably. Both were about 20mm lower than my bikes. But the Large was right around the same. If I got the medium, to replicate the saddle-to-bar reach and drop, I'd have to swap the 100mm stem that's standard on the Medium for a 130, AND I'd have to run the full stack of spacers. On the large, I'm running the standard 110, and 12.5mm of spacers.
The problem with two measurements to choose a size is that it doesn't address questions like arm length, flexibility, etc. Sure, the Medium could be made to fit me, but the Large was a lot closer, and didn't require extreme measures.
Likes For genejockey:
Quoted: 4451 Post(s)
Liked 4,911 Times
As I have relatively long arms (high ape index) I think size L would be the better fit and with the M I would almost certainly have to swap out the standard 100 mm stem and probably run maximum stack. But ultimately I could probably make either size work.
Quoted: 338 Post(s)
Liked 408 Times
179cm tall, Canyon Speedmax in size S here.
A friend of mine who is about your height rides a medium Aeroad, which seems a bit big for my height and taste.
I select the frame size based on my 73cm saddle height and my preferred 10cm saddle to bar drop. The tallest stack I'd want want would be in the 525-530mm range and the shortest that I have now is only 509mm. The 509mm stack can give me the same bar height with the stock 15mm headset top cover and a -6 stem. I'm using a 30mm top cover and a -17 stem to leave the steerer 15mm longer to preserve resale value. A small frame that's totally slammed might to tough to resell.
If your saddle height is 50mm taller than mine, add that to the stack height. Add more stack height for less saddle to bar drop.
AdkMtnMonster Great to hear! I'm thinking about buying a Canyon bike size XS (I'm also ~5'6"). Think you could send me a direct message so I could ask you a couple questions? I just joined bikeforums and can't send private messages yet.
Quoted: 398 Post(s)
Liked 788 Times
I opted for doing a few upgrades to my bike and holding out another season before upgrading to a new bike. After a lot more research, I do think the XS Canyon Grizl is the right size for me tho
