Cannondale bike value?
Bikes: 2004 Cannondale T200 --- 2005 Trek 4300
Quoted: 8 Post(s)
Does anyone know a ballpark cost for this bike when it was new?
Thank you!
Thank you!
Bikes: 2014 CDale EVO, 2007 System Six, 2004 Litespeed Solano, 2002 Burley Duet
Quoted: 92 Post(s)
What year and what model? Vintage Cannondale has a serial number decoder and archived catalogs.
Quoted: 8 Post(s)
update
I don't have the serial number, just this picture. It just says Cannondale and touring. Also says "made in the usa".
Just wondering about ballpark because I'm thinking about buying it for $150
Thanks again.
Thanks again.
Sunshine
Quoted: 10954 Post(s)
Liked 7,482 Times
You have wasted time and perhaps lost out on the bike.
Its an incredible deal at $150, even if it takes another $200 to get it updayed...which i doubt it would
Quoted: 8 Post(s)
Thanks for your advice. Sounds like a good buy then. I'm heading to pick the bike up now.
Quoted: 1182 Post(s)
Liked 833 Times
It looks like a mid-2000s (2003/2004) T series Cannondale touring bike. They retailed for about $1300. Cannondale quit making their bikes in the U.S. in 2010. That was also the last year they made a "real" touring bike. Beautifully built bikes that will only be harder to find in the future. If the frame was in good condition, and it fit, I'd buy it at $150 just for the frame!
Look for dents in the frame. We have 2 Cannondale aluminum frame touring bikes in our family fleet, and they can be dented.
Expired Member
Quoted: 3658 Post(s)
Liked 5,404 Times
At $150, that's a great deal even for just the frame.
Quoted: 8 Post(s)
Thanks everyone for your input. I have the bike now and everything seems to work great except I can't get the left hand shifter to shift onto the biggest sprocket (front sprockets). If that's the only problem I think it was a steal. Thanks again.
Brad
Liked 833 Times
It could also be a matter of cable tension or FD limit setting. Try Brad's recommendation first and then go through the process of adjusting the limit and cable tension if the lubricant did not help. Any or all of those conditions may be contributing to the problem.
Can you make the FD shift to the big chainring by pulling on the cable by hand? Does the shift lever actually click into the third index when you try to shift to the big chainring? Is there a lot of slack in the shift cable when you have the chain on the smallest chainring?
Quoted: 8 Post(s)
Thanks guys, I will try your suggestions tomorrow. Also, upon closer inspection the plastic cover around the cable has a crack in it near the lever and I can see rusted wires. It's a very small crack so the WD40/LPS2 will probably still work.
Sunshine
Liked 7,482 Times
At the peice you bought it for, i would expect cables and hlusong wpuld need to be replaced. Same with tires and perhaps bar tape and brake pads too.
Quoted: 8 Post(s)
update
The other shift cable and brakes seem to work fine. As soon as it warms up here (I live in wyoming and it's 30 degrees outside right now) I'm gonna go spray everything with WD. Looks like that cable will need replaced though.
Brad
Quoted: 8 Post(s)
So I'm going to replace the shift cables. The shifters say shimano ultegra and from decoding the serial number the bike is a 2002 model. Can anyone give me a link to buy some new cables. I'm a total newbie to roadbikes and have never changed shift cables on a bike. Once again, thank you all for your time and advice.
Miles to Go
You really scored it is a T2000. I had one a while back, wish I had kept it. It retailed for almost $1600.
Quoted: 8 Post(s)
Bikes: '07 Trek 520, '09 Gary Fisher Triton, '04 Trek 8000, '85 Trek 500, '84 Trek 610, '85 Trek 510, '88 Trek 660, '92 Trek 930, Trek Multitrack 700
Quoted: 19 Post(s)
Looks like it is a 2002 T800, serial number begins in "N" and T2000 was offered in black that year.
https://vintagecannondale.com/year/2002/2002.pdf pages 53-54
"When I hear another express an opinion, which is not mine, I say to myself, He has a right to his opinion, as I to mine; why should I question it. His error does me no injury, and shall I become a Don Quixot to bring all men by force of argument, to one opinion? If a fact be misstated, it is probable he is gratified by a belief of it, and I have no right to deprive him of the gratification."
T. Jefferson
T. Jefferson
Quoted: 3458 Post(s)
Liked 1,465 Times
For touring, things like replacing cables is good learning experience so you can learn how to fix a bike out on the road.
OOPS, I WROTE THE ABOVE BEFORE i READ THIS:
A good pair of cable cutters sold for bicycle purposes is useful. I use one made by Sram. Was not cheap, but good tools rarely are. I got mine at a ebay seller, but I bought it over the counter at their physical store.
Replacing cables in a shifter like you have is something that might not be intuitively obvious, look on you tube for tutorials. Park and some other companies have good tutorials.
Liked 833 Times
Check out this site for help:
Repair Help Articles | Park Tool
Park has good, easy to follow instructions on how to adjust the derailleurs' limit settings and cable tension.
It might be a good idea to go through all your cables at the same time. It is a good exercise in brake adjustment. I'd recommend getting the complete kit, which includes new ferrules and housing. Check out the online bike stores for good prices on kits.
Miles to Go
You mentioned it has Ultegra shifters, which is what the T2000 was outfitted with while the T800 had Tiagra shifters. You could also check the front deralleur. The T2000 has 105, the T800 is Tiagra. The T800 is pretty darn good, too.
Quoted: 8 Post(s)
The front derailer does say 105 on it.
Miles to Go
Would you describe the color as "battleship grey with silver decals?" If so, it's either a 2001 T2000 with MSRP was $1499.99, or a 2004 with the same MSRP. The way you can tell is that from 2000 to 2003 the rear derailleur was XTR, and was XT 2004 to 2007.
Quoted: 8 Post(s)
Yeah, I'd say that's a good description of the colors. And the rear derailleur says XT, so sounds like it's for sure a 2002 T2000. Thanks for your input and helping me figure it out.
Big Blue Book of Bicycle Repair ? 3rd Edition | Park Tool
Park tools, Big Blue Book Of Bicycle Repair. A person on a bicycle tour should be able to take their cycle apart and put it back togther.
Before you spend any money, check the frame for cracks. Then look down the frame to see that it is not bent.
All is well? replaceing the cables and cable housing is a good place to start. New brake pads? Grease the wheel bearings?
Some people have learned bicycle mechanics by voluntering at the local bike coop or a charity that fixes bikes for children. If you live in Wapiti Wy, you might enjoy park tools videos on youtube.
