Raleigh house brand crankset
Quoted: 1872 Post(s)
Liked 692 Times
I'm wondering if anyone knows if the house brand Raleigh crank that comes on a lot of their models (mine's a Tamland) is compatible with a Shimano non drive side crank arm. I'm looking at getting a Stages power meter and I'm thinking it may work to just put it on the Raleigh drive side crank arm since they both seem to use the Hollowtech standard.
2019 Salsa Warbird
2019 Salsa Warbird
What does the non-drive side arm look like, can you post a picture?
EDIT: OK I found an example of one online. From a first look it does appear to be very similar to a Hollowtech crank in it's design. Sadly that's no guarantee that you can just slide on a Shimano crank arm though.
Liked 692 Times
I can't find any example online of what the crank looks like, but I'd be surprised if it were Shimano compatible.
I may just have to be the guinea pig. I'll take off the wife's shimano nds arm and try it tonight. I won't be able to stop thinking about it till I know
2019 Salsa Warbird
2019 Salsa Warbird
Almost certainly not. Most "OEM" level cranks are made by FSA. Using the Shimano spindle design would be a huge patent infringement.
my stuntman came with a Sammox crank. I think it's also on my son's merit 3.
