Going Tubeless
Bikes: Fuji CCR-2; Scott Scale 960; Surly Steamroller
Going Tubeless
So I just got a new gravel bike that has tubeless ready rims (Stan's Radlers) and tires (Clement X'Plor ). It comes from the factory with tubes.
What would I need to get to go tubeless? Strips/valve and Sealant? Or just valve and Sealant?
So I guess the real question is, do the rims come with the correct taping (I haven't removed tires yet) needed for going tubeless?
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
You can use the tires with tubes. However, you can run lower air pressure without the risk of pinch flatting if you remove the tubes. It's a great advantage on rough and soft gravel.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
It should have tubeless tape but the only way to know for sure is open it up.
The wheels should have come with valves. Where did they go? Did the retailer not supply them or was it a private sale?
You will need a valve core removal tool and sealant. Might as well get some tape while you are at it. If you have the bike for any length of time then it won't go to waste.
-Tim-
-Tim-
Bikes: 2015 Redline Conquest Elite; 2014 Fuji Tahoe 1.1 27.5er; 2006 Scott Speedster S30 (sold); 2001 Specialized S-Works CX; 1990 Trek 750 (sold); 1999 Bianchi Volpe; 1988 Bianchi Campione D'Italia.
Quoted: 131 Post(s)
Edit: Deacon beat me to it and with a better answer too.
- Soli Deo Gloria -
Liked 736 Times
Also a pump able to blow the tires onto the bead seat.
A compressor will work too.
Quoted: 19 Post(s)
Think twice before you run "non" tubeless ready tires without tubes. Often can be done, and often is done without issue. The problem is when there's a problem -- like a bead pops off. Odds are you'll make a quick acquaintance with the ground. Shortly after you'll probably make a quick acquaintance with your dentist or an ER doc. Not worth it to me, I'd rather buy some tubeless ready tires, but YMMV.
Quoted: 910 Post(s)
Liked 288 Times
Good point. The 700x36 Clement is tubeless ready, but other models are not. The OP should use a tubeless ready tire if going tubeless.
Sorry, I thought I stated that both my rims and tires are tubeless ready. But thanks all for the information. I will more than likely go ahead and purchase some tape, will need at some point.
Quoted: 19 Post(s)
As @Barrettscv correctly pointed out, *only* the MSO 36s are tubeless ready. Not clear for bike in question whether it's stock, new/modified or new-to-you/used so it wasn't clear to me that you have the 36s -- Also, I'm not aware they are OEM spec on any bike but I may be talking out my a$$. Sorry for the confusion and for making assumptions.
I've already answered my own question by checking the rims and confirming that they are taped and ready to go tubeless. I can also verify that my 36s are tubeless ready, unless the "Tubeless Ready" stamped on them has a different meaning.
Quoted: 910 Post(s)
Liked 288 Times
You have tubeless-ready tires. Getting conservative and cautious advice is better than getting mindless advice.
Quoted: 18883 Post(s)
Liked 10,646 Times
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Here is some "free" internet advice, so take it for what it is worth.
I've used 'skinny strippers' to add a little (?) safety to getto tubeless. These inexpensive latex strips bond with the latex sealant and in essence convert a tubeless tire to a tubular tire that completely seals the air chamber - even off the wheel. It will not (should not) burp or come off the rim.
FattyStripper Tubeless Fat Bike Solution and SkinnyStripper Tubeless CX & DH Solution <link rel="image_src" href="https://fattystripper.com/media/FattyStripper_Logo_320.jpg" / ><link rel="image_src" href="https://fattystripper.com/media/FattyStripper_L
Liked 415 Times
Like you noted, you have to look, as every wheel can be a bit different...
