Rim Tape/ Cleaner Recommendations
Old 03-26-19, 05:01 PM
Ald1
Bikes: Domane SLR 9 Fuji Gran Fondo 2.3 1978 Mercian
Quoted: 113 Post(s)
Liked 2 Times in 1 Post
Needed to change my rear tire. I'm using Pro Ones on Enve 4.5 AR Disc wheels. What cleaner do you use to get the dried up sealent off the rim? Also what tape? I need to redo as I got a bunch of spoke leaks and thought I'd get some more advise. What a PITA getting the sealant cleaned off......Thanks
Ald1 is offline
Old 03-26-19, 05:16 PM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
Quoted: 6435 Post(s)
Liked 349 Times in 225 Posts
You will get as many answers as there were in the thread about what gets wax out of concrete. I'm looking forward to the list of suggestions. Should be entertaining.
I've used many different solvents and none were magic. All required significant elbow grease.
Isopropyl alcohol seems to work OK on tape residue.
-Tim-
TimothyH is offline
Old 03-26-19, 05:38 PM
wschruba
Quoted: 465 Post(s)
Effetto Mariposa sells a latex solvent that works very well.
wschruba is offline
Old 03-26-19, 05:43 PM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2025 Post(s)
Liked 95 Times in 79 Posts
I like using Goo-Gone for cleaning up adhesive residue, and then rubbing alcohol to remove any trace of the Goo-Gone.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 03-26-19, 09:30 PM
rosefarts
Quoted: 266 Post(s)
Liked 43 Times in 15 Posts
Q-tips and a dental tool to get inside the rim.
rosefarts is offline
Old 03-27-19, 12:05 AM
aclinjury
Quoted: 113 Post(s)
things that are cheaply available to try:
- isoproply rubbing alcohol (any CVS, Target, Walmart)
- denatured alcohol (Home Depot)
- ammonia (Home Depot, hardware store)
aclinjury is offline
Old 03-27-19, 06:07 AM
u235
u235's Avatar
Quoted: 318 Post(s)
Liked 20 Times in 17 Posts
No magic found yet. Use something and turn to a new section of cloth every few inches helps a lot. A sticky layer on the surface and the cloth just rolls around.
u235 is online now
Old 03-31-19, 04:36 AM
Ald1
Quoted: 113 Post(s)
Confounded. 0 for 3. Way too many spoke hole leaks. I'm not new to this and have done tubless changes many times. Last attempt cleaned with recommended Effetto Mariposa cleaner and used their tape. Rim is spotless clean. I doubled taped this time. The second attempt I added sealent to see if it would correct the leaks. Nada. I alway mount my tubeless and leak test in sink before adding sealant. Been fine till now. My philpsopy has been if you need sealent to make a tubless setup work you do not have a tubless tire. After all do we need sealent in out tubeless car tires? Sealent should only be needed for puncture protection. Am I wrong? How many of my fellow tubless users rely on sealent to make the mounting work? I see tubes in my future. The juice might not be worth the squeeze.........
Ald1 is offline
Old 03-31-19, 05:58 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 2205 Post(s)
Liked 31 Times in 29 Posts
Not saying GooGone is one of them, but conceivably, aren't there cleaners that while would attack these residues, aren't there similar compounds in the resins of CF products that you obviously wouldn't want attacked? In other words, are there any chemicals out there in conventional cleanup products that you must keep away from CF?
Sy Reene is offline
Old 03-31-19, 10:04 AM
ThermionicScott
hungry
Good question/point. I was speaking only for aluminum, not sure if these would be good on CF.
RUSA #7498
Old 03-31-19, 01:10 PM
wschruba
Quoted: 465 Post(s)
Unfortunately, without holding them in my hands, I can't say what was wrong. Maybe the rim was spotless, and the tape job was bad. Maybe the tape you are using is no good for your rim. There are too many variables that aren't mentioned that could cause leaks...even rim damage.
Do you set your tape in place with a tire/tube first, or just install the tires?
wschruba is offline
PeopleAreIdiots
Singlespeed & Fixed Gear
7
04-20-18 01:52 PM
that_guy_zach
Classic & Vintage
32
04-17-10 03:41 PM
