Tubeless tires are ruining my marriage!
Old 04-03-19, 11:33 PM
Wattsup
Quoted: 376 Post(s)
Liked 40 Times in 35 Posts
Nah, they're not. I'm not even married. But...
How often is one supposed to replenish the goop in the tire? And how do you know how much goop to replenish with? I don't want to overdo the goop.
Wattsup is offline
Old 04-04-19, 04:19 AM
Quoted: 18391 Post(s)
Liked 15,465 Times in 7,306 Posts
Hit up your local LBS...before it dies out.
Old 04-04-19, 04:40 AM
hillyman
WALSTIB
hillyman's Avatar
Quoted: 280 Post(s)
Liked 384 Times in 183 Posts
I believe this is an issue that can only be resolved if you go on the Jerry Springer Show.
www.bikeleague.org
hillyman is offline
Old 04-04-19, 06:28 AM
PickleRick
PickleRick's Avatar
Bikes: Felt Z4, Trek Remedy 9.8, Pivot 429SL Di2, Salsa Warbird Di2
Quoted: 31 Post(s)
Liked 47 Times in 18 Posts
...Ohhhh, I'm thinkin' Dr. Phil will want to set him straight as well. - "Can't you see the pain you're putting your wife through.....what are you so afraid of?"
PickleRick is offline
Old 04-04-19, 06:45 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2761 Post(s)
Liked 2,534 Times in 1,433 Posts
Fill it half way.
Kapusta is offline
Old 04-04-19, 06:48 AM
BobbyG
BobbyG's Avatar
Quoted: 1361 Post(s)
Liked 1,669 Times in 825 Posts
"Goop".
In my childhood it was the liquid you put in Mattel's Thingmakers to make "Creepy Crawlers".
Now it's been culturally appropriated by Gwyneth Paltrow as the name of her "lifestyle brand".
I would love if you asked your question to Gwyneth's Goopsters.
BobbyG is offline
Old 04-04-19, 06:54 AM
bakerjw
Quoted: 169 Post(s)
Liked 84 Times in 62 Posts
It depends on the type of sealant that you are using.
I find that Stans dries out much faster than Orange seal. I might freshen it up in the road bike every 6 months. If in doubt, you can always pop the bead on one side and look inside. Easier said than done sometimes.
bakerjw is offline
Old 04-04-19, 06:55 AM
Lemond1985
Sophomore Member
Lemond1985's Avatar
Quoted: 1628 Post(s)
Liked 1,057 Times in 631 Posts
To paraphrase Lance Armstrong "It's Not About the Goop". Besides, hairy palms and blindness are not laughing matters.
Lemond1985 is offline
Old 04-04-19, 09:25 AM
motorthings
Quoted: 56 Post(s)
Liked 10 Times in 6 Posts
milkit makes a nice syringe to check/set sealant levels
i have best results so far using orange seal endurance
stans and finish line dried out much much faster.
motorthings is offline
Old 04-04-19, 11:21 AM
5teve
Quoted: 69 Post(s)
Liked 65 Times in 29 Posts
Heh, you don't want to under-do the goop either. I top it off 2-4 times a year. Heat makes sealant evaporate faster-if you live in a hot place, store your bike in a hot garage, you'll probably want to top it off a couple of times in the warmer months. If I get a puncture that is bad enough to notice (ie, fountain of sealant until it seals the hole) I tend to add a little bit to replace the expelled fluid. Another way to check the level is to put the valve at the bottom of the wheel, let it set for a couple of minutes so the sealant settles, then deflate and remove the core. See if any sealant gets squeezed out the valve as the tire depresses. If there is little or none, it wouldn't hurt to add some.
5teve is offline
Old 04-04-19, 01:28 PM
Trsnrtr
Super Modest
Trsnrtr's Avatar
Quoted: 10951 Post(s)
Liked 4,605 Times in 2,112 Posts
What 5teve said. I hardly lost any this winter in riding temps from 25-40º. I use Orange seal.
I check mine by popping a bead and then pulling the stuff out with the same syringe that I use to inject the sealant with. My syringe holds 2 oz. so I can quickly see what i pull out. Put the same stuff back in if it hasn't separated.
Keep the chain tight!
Trsnrtr is offline
Old 04-04-19, 01:29 PM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 526 Times in 349 Posts
It also depends on the size of your tire.
jadocs is offline
Old 04-04-19, 01:51 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
There is no need to pop the bead.
Popping the bead is a waste of time and likely a huge mess.
Just remove the valve core and use a zip tie or similar as a dipstick. That's all.
-Tim-
TimothyH is offline
Old 04-04-19, 07:04 PM
Roadlizzard
Bikes: TREK 8000,Trek Domane 4.5,Felt FR
Quoted: 21 Post(s)
Liked 3 Times in 3 Posts
Once a month I turn the bike upside down let all the air out of the tires remove the valve cores. I check the sealant with my Orange Seal dip stick. If needed I add a little OS install valve cores reflate the tire. Takes just a few minutes.
Roadlizzard is offline
Old 04-04-19, 08:04 PM
Bmach
Quoted: 440 Post(s)
Liked 264 Times in 162 Posts
Which Orange Seal are you guys using?
Bmach is offline
Old 04-04-19, 08:23 PM
HerrKaLeun
Bikes: Giant Toughroad SLR1 and Motobecane Sturgis NX
Quoted: 900 Post(s)
Liked 231 Times in 168 Posts
My rule of thumb is to start out with 1oz per inch of tire size. So my fatbike gets 4 oz and so on.
Every 3 months I add half of that to replenish.
This likely is on the high side, but what is the hurt of too much? If I have multiple holes I'm covered.
I make my own sealant, so it is cheap and I don't care about 2oz more weight.
HerrKaLeun is offline
Old 04-04-19, 09:07 PM
CodyDog
Bikes: Specialized Vado SL/Trek Fuel EXe
Quoted: 55 Post(s)
Liked 38 Times in 29 Posts
Wow! That brings back memories...creepy crawlers.
CodyDog is offline
Old 04-05-19, 09:54 AM
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
Liked 512 Times in 306 Posts
For some reason I can't post an image today so here's the URL.
https://getyarn.io/yarn-clip/a03c7d2...a-847ac7374c7e
NoWhammies is offline
Old 04-05-19, 10:28 AM
Hiro11
Bikes: 2022 Specialized Allez Sprint custom build, 2019 Giant Defy Advanced Pro 0, 2018 Seven Mudhoney Pro custom build, 2017 Raleigh Stuntman, various others
Quoted: 782 Post(s)
Liked 475 Times in 238 Posts
I'm currently running tubeless on a road bike, gravel bike, MTB and fat bike. With road tubeless, if you hear the sealant sloshing around in the tire when you shake the tire back and forth you're good. I never pop the bead unless I'm replacing the tire. I put about 2 oz of Stans in 700x28 road tires. I find that 2 oz of Stan's sticks around for a long time, 6 months-ish. I just squirt some in through the valve if I can't hear anything sloshing.
Hiro11 is offline
Old 04-05-19, 11:16 AM
I take my wheels to my LBS to have sealant put in and two have new tires mounted. They are not dying out.
Old 04-05-19, 11:22 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5222 Post(s)
Liked 3,574 Times in 2,338 Posts
Originally Posted by BobbyG
Mattel's Creepy Crawlers
not that you care, but I had one of the originals I think, the kind that used a hot press. burned a cpl fingers & the blisters prevented me from doing my guitar practice & lessons. after that, I never really got back into it & let my older brothers become the guitar players of the family ...
rumrunn6 is offline
Old 04-05-19, 11:45 AM
NomarsGirl
NomarsGirl's Avatar
Bikes: Specialized Ruby Sport
Quoted: 318 Post(s)
Liked 314 Times in 165 Posts
Are they famous now?
NomarsGirl is offline
Old 04-05-19, 11:53 AM
nomadmax
Quoted: 1104 Post(s)
Liked 1,824 Times in 878 Posts
And people say tubular tires are a PITA
nomadmax is offline
Old 04-05-19, 01:40 PM
rumrunn6
rumrunn6's Avatar
lol, one is infamous but staying out of trouble now that he's older. he kept up the guitar & is quite good, so are two of his sons, but sadly, none derive employment with their talents. my other brother dropped the guitar later in life, but became sorta famous by writing books & has been interviewed on national TV by Donahue, Katie Curic & The view. his latest book is about writing his other books. he never stops, but his cash-flow is intermittent ...
rumrunn6 is offline
Old 04-05-19, 03:31 PM
Wattsup
Quoted: 376 Post(s)
Ah, great idea! Thanks to everyone else, especially the guy who said to "fill it halfway!"
Wattsup is offline
