Pedals won’t move forward
Decided to go out biking again, but my pedals won’t move forward. They work fine backwards and as well as when the rear wheel is lifted. They also work when I remove the front chainrings. But whenever the chains rings are on or when the rear wheel is on the ground the pedals immediately become stuck.
Expired Member
Quoted: 3674 Post(s)
Liked 5,435 Times
Welcome Noxious!. You obviously need some Harder Hittin' Breaker/Cracker pedals
Mine don't really "move forward" either. They are fixed in place. They spin. The crank arms move forward, but, more specifically, they also spin around a bottom bracket spindle.
Remove the chain, and tell us specifically what's going on. What kind of equipment? Freewheel or freehub? Can the rear wheel be spun forward by hand? Is this a problem with the bottom bracket, pedals, or rear wheel?
Im pretty sure it’s a freewheel and yes the back wheel can be spun forward. I think it might be a bottom bracket spindle problem.
Someone told me that the freewheel ratchet could be stuck under the load and as well as the bottom bracket. They say it can be fixed by lubing the freewheel. What do you think?
Bad example
Quoted: 826 Post(s)
Liked 213 Times
Quoted: 4208 Post(s)
Liked 3,874 Times
I've followed this thread with some interest. From what is really meant by "my pedals won’t move forward" to what the problem turns out to have been. Like so many threads here I suspect the problem is relatively easy to find with the basic deductive process, easiest done with the bike in hand.
AndrewRStewart
AndrewRStewart
Quoted: 608 Post(s)
Liked 352 Times
I watched your video and it certainly looks like a freewheel problem to me. Maybe others can actually watch the video and make a suggestion. I also think if the bike is that old a full overhaul of the bottom bracket wouldn't hurt at all.
https://imgur.com/gallery/0TYwzgI
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Your first video shows the drivetrain working normally, but the second shows the "lockup". Were these videos taken at different times?
I don't see a freewheel problem in your second video. You are able to put tension on the chain and the freewheel has locked to the hub through its pawls. It appears that the wheel itself is preventing proper operation.
Are your brakes on? Is the axle mounted so that the tire is centered between the stays (and not rubbing). This looks ok in the video but we can only see one side. I also don't see much of a bottom bracket issue - if you can spin the crank backwards it can clearly spin forwards.
Check your brakes and how your wheel is mounted.
If the bike is parked, the pedals aren't going to rotate forward, unless you lift the rear wheel as in the first video.
Or are you saying they won't move forward even if you are riding the bike?
-- NVM: Is this a troll??
Bikes: 2014 Wilier Zero.9, 2010 Orbea Aqua, 2007 Ross mtb, 1972 Sekine GS, 1971 Motobecane Grand Record, 1953 Parkes Magpie
Quoted: 7 Post(s)
Liked 8 Times
If I saw you standing on one pedal and it wouldn't move, it would have more impact.
