Pot hole messes up rear derailer?
Got a new bike today (giant defy adv 2), and was riding on my usual rural routes. on the last road, there is a spot where they cut the pavement for some work, and unevenly dumped gravel to try and fill it, but poorly - leaving a drop and a 2" to 3" ledge that i bounced through. Needless to say, going through it, and coming out the other side, my rear derailleur it out of whack. Immediately jumping gears, etc. Seems odd, i've not yet experienced shimano 105s get jacked up so quick. I adjusted it, but it still seems not quite right. Has anyone had such an experience? It also seems like the magical carbon wheel in the rear got ever so slightly out of balance from it, but barely noticeable.
Chases Dogs for Sport
Is it possible that a piece of gravel got tossed up into the derailleur cage, jammed the works, bent the cage, then fell out? (I once had a piece of gravel bounce up into my rear derailleur cage. It wedged in and locked everything up. The gravel didn't fall out -- the force ripped the rear derailleur off the bike. I ended up having to replace the derailleur and the hanger.)
wears long socks
The dropouts are the rear most part of the frame and are slotted where the wheel skewer slides in before its tightened.
If the skewer slipped a little, your wheel is now in crooked and could be why your shifting was weird.
Quoted: 5224 Post(s)
Liked 3,581 Times
Wifey trashed 2 tires in her new car this spring, in some sick potholes. cost her $500 to replace them
wears long socks
Quoted: 1581 Post(s)
Liked 1,189 Times
I'm still with rim brakes myself on the road bike. Heck, even my mtb has quick release wheels.
Quoted: 6193 Post(s)
Liked 4,809 Times
If it's a new bike, why not go back to the shop and see what they can do before you goof something up that voids any warranty you might have.
Quoted: 479 Post(s)
Liked 277 Times
Please don't take this the wrong way... but, regardless of the current wheel/derailleur issue, it sounds you need to become a bit more familiar with the bike, the parts, how it goes together and how it works. You WILL need to remove that wheel on the side of the road someday. Maybe spend sometime in the garage with a beer and YouTube and pull the wheels off, put'em back on, adjust the rear derailleur...
Some of these seemingly complicated tasks are comically simple (like adjusting a rear derailleur). And really, YouTube is a goldmine for this.
