Cannondale's new gearing
Bikes: Cannondale T600, Scattante R-660, Diamond Back Response Sport
Pardon if this is old news.
The new 2008 Cannondale Touring 1 bike has 11-32 cogs, 30/39/50 rings.
https://www.cannondale.com/bikes/08/cusa/model-8TR1.html
The new Cannondale 2008 Touring 2 bike has 11-34 cogs, 26/36/48 rings.
https://www.cannondale.com/bikes/08/cusa/model-8TR2.html
The 2007 bikes (T2000, T800) both had 11-34 cogs, 26/36/48 rings.
https://www.cannondale.com/bikes/07/c...odel-7TR2.html
https://www.cannondale.com/bikes/07/c...odel-7TR8.html
Well, I'm a bit disapointed in the lack of low gearing in Cannondale's top of the line 2008 model!
Bikes: Bridgestone MB-5, Rocky Mountain Oxygen Race, Surly LHT, Specialized Roubaix Expert, Marinoni Sportivo, Steelwool Tweed
As I read the specs, the Touring 1 is a 10-speed rear derailleur. That limits access to cassettes, derailleurs etc. I don't see any need for 10 speed kit on a touring bike.
There isn't a non-custom touring bike out there that comes with low enough gearing. They assume that most people buying these bikes don't do real loaded touring, they just buy them for the more comfortable upright position. Most if not all bike shops will swap-out gearing for you at little to no cost.
I, for one will not start a cross country tour or any tour for that matter with gearing that is only "marginally adequate". Not when it's so easy to change.
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,216 Times
The crank on the T2 is a 104/64 BCD Shimano crank. It's easy to change the inner ring to a 22. The T1 crank is a 130/74 or it might be a 130/92 BCD (not sure which). You could change the former to a 24 inner but the best thing to do with the other one is sell it on Fleabay
Stuart Black
Stuart Black
I was running a 46-36-26 and 11-32 on the Trans America this Summer and only thought I might have used a lower gear a couple times in Virginia. The 34 that is on the lower end Cannondale would have made it about right. Lots of folks I saw along the way were running the same or similar gearing.
This doesn't mean that some riders in some locations won't want lower gearing, but that it is a "reasonable" choice for standard equipment.
Actually I consider it adequate. You will notice that I said at least marginally adequate.
OK so you had a few times where lower gears might have been nice, did you have any times where you wished you had higher gears? My guess is not, I certainly didn't and that is my only point, I know it's splitting hairs and I'm sorry for that, it's just that changing gears when you first get the bike from the dealer is free, and why not go ahead and get what you need.
I agree with what you are saying about changing gearing at time of purchase. OTOH a new inner ring is what? 12 bucks maybe? So it isn't a big deal to do at any point unless the crank doesn't take it.
I don't get why they put road cranks on so many touring bikes though. I guess that maybe most of the touring bikes sold never tour, so maybe that is the rationale.
What are the widest tires that will fit on the T2? Think it'll handle 40s?
Liked 4,216 Times
The T800 handles 37mm with loads of space. I don't think they'd make it narrower.
Stuart Black
Stuart Black
No, but I did use the highest gear a good bit and wouldn't choose a lower high gear.
WOW! you must be a strong rider, I'm using 22/32/44 X 11-34 and I never got close to my highest 44/11 gear and used my Granny 22/34 gear hundreds of times. Can I borrow you legs for my next tour?
I agree about (not) using road cranks, mountain bike cranks give tourist many more options.
I mostly used the big gear either on downhills or when drafting my 21 year old daughter. She would be flying along at 18-20 a lot of the time and was on the front a lot more than her share of the time. I do like to mash a big gear some of the time on my own too, though.
Bikes: Cannondale t2000, Schwinn Moab mountain bike, Specialized allez cro-mo
T2000
That is quite an improvement my 2001 T2000 came with 11-32 and 52-42-30. I changed that out. I now have a 48-36-26. I like that much better.
Not to complain to much but the '07 T2000 had 700x37c Schwalbe Marathons, but the '08 T1 has 700x32c. I'm disappointed in a company whose very first bike historically was a full blown touring bike, not a sports tourer.
The first one I bought many years ago came with an Huret Duopar on which I put a 36" cog.
