Options for fitting a 6 speed hub to dropouts designed for 7 speed
I picked up an older Specialized Hard Rock mountain bike that was missing wheels as I had some wheels laying around. The front wheel fitted but the back wheel had a large gap between the rear dropouts and the hub axle nuts. I then realized that my wheel was an older model with a six speed freewheel and I think the spacing between the dropouts of the Hardrock is designed for a 7 speed axle. Not wanting to buy another wheel, I was wondering what are my options.
Can I just add spacers to my current 6 speed wheel? Would this create another other problems?
Thanks
Thanks
Gone, but not forgotten
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times
Sheldon "https://sheldonbrown.com/frame-spacing" Brown
sheldon_brown,
Thanks for the reply but I was wondering why just to the left side and not equally to both sides. I am thinking if I add an equal size to each side I would not need to redish the wheel. And if I decide to use a 7 speed freewheel, would adding just the spacer on the left side cause the freewheel to be too close to the right dropout?
Thanks
Thanks
Igor
Bikes: peugeot fixie
py272, your frame spacing should measure 130 or 135mm. Your wheel will measure 126 or 130mm at the locknuts. Right? If your frame is a good distance off from this you need to cold set it (bend). The Hardrock frame is super strong and can handle this a few times. Bend the rear triangle (with the help of your lbs of course) to the same size as your rear hub. That 6 speed wheel is plenty strong and if it's old you don't want to mess with it too much.
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
Well, adding spacers to the left side only allows you to redish the wheel for reduced dish and this yields a stronger more reliable wheel. Also the shifting performance and range won't be compromised. The swing of the RD may not be enough if you try to center the wheel with spacers equally on both sides.
