My gears aren't shifting smoothly...
Bikes: 2011 Specialized Sectuer, 1988 Bianchi
Should I bring it to a bike shop, or is the adjustment something I can do myself?
Bikes: Colnago CX-1 Record 11sp. Carbon Epic expert 29er, Claud Butler Dalesman. Proflex X-px Works, Cougar 653. KHS Montana Pro, Hercules Alassio. Ammoco Monte Carlo F/SS. Corratec Superbow Fun 29er. Claud Butler Midas. Kenisis T2. Peugeot Perthus.
Give it a try first, check out Youtube tutorials and Sheldon Brown.
Quoted: 2026 Post(s)
Liked 1,095 Times
It's something tyou can easily do yourself IF (big if) you know what you are doing. First, we need a lot more information:
1. What type of gears? Derailleur, internal gear hub?
2. Where is the rough shifting occuring, front, rear or both
3. A much better description of the problem and symptoms
Quoted: 1572 Post(s)
Liked 643 Times
1. Retro Grouch's quick and dirty answer: Look at where the shift cable enters your rear derailleur. See a barrel adjuster there? Stand behind the bike and turn it counter-clockwise 1/4 turn. My bet is that'll fix it.
2. The engineer's answer: Look up rear derailleur adjustment on the Park tool website. They'll have a good set of step-by-stem instructions. Start at the beginning and don't skip any steps.
3. The lawyer's answer: Take it to a bike shop. If they can't fix it to your satisfaction at least you'll have somebody else that you can blame.
1. Either, Put your bike on a stand(if you have one), or turn it upside down, or raise the back wheel off the ground
2. Turn the pedals in a forward motion.
3. While turning the pedals, shift the gears
4. While shifting the gears, watch the chain guide to see if it is loose
5. Check to see how much pressure you have to apply to the brakes to come to a full stop. This could be a sign. That your brake cables need replacing. If that is problem, a bike shop would have the time, and parts needed to fix the problem.
My gears haven't shifted smoothly in a long time. Then I started taking antidepressants and benzodiazepines. My gears still don't shift smoothly but now I don't care so much.
Bwahaha..... Gosh I still miss the bennies from long ago.... And I can tweak my own bikes yet today, thanks to you-tube. 👍
Something you most likely "can" do. Whether or not you want to take the time to learn is another story. I found it was quite complicated and I kept learning as I tinkered with more bikes, but now am glad I learned. I still get confused sometimes though as we all do
Expired Member
Quoted: 3649 Post(s)
Liked 5,382 Times
OP would have to be pretty slow if he hasn't figured this out in 8 years.
ParkingTheBus
Bicycle Mechanics
5
06-08-15 06:17 PM
illdthedj
Bicycle Mechanics
30
08-20-13 03:22 PM
