Sail bike?
Avatar out of order.
Bikes: Fuji Absolut '04 / Fuji 'Marlboro' Folder
Sail bike?
I'm sure someone has done this. After fighting the wind the other day, it seemed to me that there is a market for a sail-driven bike. The sail could be mounted on a post behind the rider, and be turned to take advantage of the prevaling wind. With tacking, it could be used even when the wind is coming from a frontal angle. Seems to me that with just a small boost speeds of 30mph could be common (yeah, I know -- for some of you they already are).
Does anyone know of such an invention?
You know you want to.
Bikes: Pinarello Prince, 1980's 531 steel fixie commuter, FrankenMTB
speeds of 30 mph? Maybe I'm misunderstanding sailing, but in my mind, it would be much harder to go 30mph unless the wind was going that fast as well.
Sailing isn't like an electric motor. It doesn't help you go faster, it just helps you more closely match the speed of the wind.
Weather today: Hot. Humid. Potholes.
OK, having done some 30 seconds of research and thought about this, I'll concede that a sail can, in fact, go faster than the wind. (If anyone else has questions about this, just google "sail faster than wind") However, you need to be able to trim the sails, and that would be an impressive feat of engineering and/or riding on a bicycle.
holyrollin'
I saw this in a '50s-'60s issue of either Popular Mechanics or Popular Science, a small news writeup with only one photo. It was a four-wheeler made of bicycle parts, with a small sail. Builder was English, and it appeared to be a one-off, not produced in quantity.
Managing a sail on a two-wheeler might be demanding. Would be an interesting design project.
coitus non circum.
I sail. You can defineitely go much faster than the wind. Ice boats (on blades like skates) can go over 100 mph. One of the problems to overcome with a sailbike would be the heeling induced by the sail. Think of how those boats are leaned way over in the wind. A thought I had is a sail on a skateboard, sort of like a land windsurfer...
don't pedal backwards...
Bikes: Surly Long Haul Trucker set up for commuting and loaded touring, old Sekine road frame converted to fixed-gear, various beaters and weird bikes, waiting on the frame for my Surly Big Dummy build
The only way to sail a bike faster than the wind is to have a wide vehicle that can resist a serious tipping power.
A run, when the wind is at your back, allows you to approach the speed of the wind and applies little to no tipping force to the craft.
When the sail is hauled in and the craft turned to cross the wind, then the speed picks up. I think the optimum angle (for a boat) is about 30 degrees off of the wind on either side. The elusive component that allows a sailboar to move forwards and not just blow sideways is the keel or board. The boat has what is literally a wing flying through the water underneath it. The propulsion (other than on a run, when you have a floating parachute) is caused by the fighting of the wing under the water against the wing in the air (the sail).
If you had a wide trike, you could probably sail crosswind. The keel's job would be provided by the wheels (preventing the sideways motion of the craft) and as long as the rig was wide enough to be stable, you could probably get some speed up.
The biggest problem is that you are heavily limited by the direction of the wind, so you would probably only be able to sail in a large open area, like the salt flats or a big sports field. I don't think that a sail would be able to provide any advantages or even be very feasable in town or on trails, unfortunately.
That said, I'll put in a six pack to the first person to create a sailbike capable of traveling crosswind at speeds greater than the measured wind (without pedal/motor assistance, naturally). Gentlemen (and ladies); start your welders!
Senior Member?
Bikes: orbea onix, Cervelo SLC, Specialzed Allez, Cervelo P3 Alu
google "kite buggy" or "land yacht" Hell, while you're at it, check out kiteboarding... it's my obsession before the windy season ended and biking took over...
it's all about kites.....
it won't work on a bike though... the sideways pull of the sail/kite would fight the gyroscopic stability of the spinning wheels, you would lose it.
Liked 5 Times
https://paulworden.freeservers.com/Safety%20Sail.htm
https://traylorfwd.home.mindspring.com/sailbikes.html
https://www.ihpva.org/wiki/index.php/Sail_Bike
I've gathered the parts I need to sail my tadpole, but haven't had time to put it together.
Liked 5 Times
And RANS had one of their trikes over 90 mph.
Pedaled too far.
Quoted: 11 Post(s)
Liked 7 Times
Let's reinvent the wheel here. 10 seconds of googling turned up the
North American Land Sailing Association.
https://www.windline.net/land_sailing_links.htm
They've been working on the technology for 50 years.
https://www.nalsa.org/landsailing_in_america.htm
MacG, I think you owe a beer to Bob Schumacher, 116.7 mph with a 30 mph wind.
https://www.nalsa.org/speed_record.htm
Looks fun.
Looks fun.
Bromptonaut
Bikes: 1994 Diamond Back Racing Prevail ti; Miyata 914, Miyata 1000, 2017 Van Nicholas Chinook
Quoted: 23 Post(s)
The Iron Duck uh? Looks pretty cool.
Feel free to follow me on Instagram
I thought I'd go ahead and revive this thread since it's an interesting topic. Sounds like my thinking is pretty similar - I was thinking about the idea. It also occured to me that a recumbent would be more well suited for a sail because of the lower center of gravity.
That said, as others have mentioned a small, adjustable, removable sail on a standard bike might be useful in some situations. If you were traveling with a tailwind or light sidewind, it could provide a useful boost. This is especially true with hills: if you're riding a long, steady incline with a tailwind, it seems to me that a sail would make climbing much easier. Since you would be going that fast, there'd be a little to no drag effect.
Obviously there are conditions where a sail would be a hindrance: When you are riding on flat or downcline surface with little or no wind a sail would obviously create a great deal of resistance (which it why it would need to be easily removable). An obviously it's probably not a good idea in the city, only on an open road (even then it would need to be fairly small). But I'm really curious if anyone has had any progress and success with this idea.
Liked 5 Times
In the DC area where I live, there are many bike trails. I'm looking at systems having sails that would remain within the 36 inch width of my recumbent trike.
MADE IN HONG KONG
Bikes: some but not enough
I sail, windsurf, Kite buggy, land sail, kite board/surf, with 10+ years experience in Kite power vehicles.
IHMO, roads are not the place to take advantage of the wind. If you have a big open area like Ivanpah dried lake, or hard pack beaches, you can play with sail powered land vehicles. Small grass fields are not enough to get up to speed.
We had people show up at Ivanpah and El Mirage with sail powered wheelchairs and yes, kite and sail powered bicycles. they are mostly a curiousity, not very efficient or quick. The limited ability to resist side loading and deteriorated controlabity is the main detriment.
However, even tho it is not an effective form of transport. The dreamer, tinker and artist in each one of us must be fed. Go ahead and build it! it will be fulfilling and fun.
Meb, if you want to try kite power, drop me an IM
mashedtatersngravyplease
Bikes: cannondale alpine series(mt), cannondale r6oo, sekine (rd), schwinn varsity, schwinn suburban, western flyer nerdbike, rickshaw from yogyakarta(sp?), ripped up baby trailers to use as a truck, and some other stuff too
hmm
my guess was going to be long based sociable tandem trike, and i thought i was going to be thought of as a genius, but the long based trike was one of the first photos i saw...
not any sociable tandems though...i guess i'm still a ******* genius
Liked 5 Times
Are the kites tethered via string?
Or is the concept different?
How much propulsion does the kite achieve?
Would think a tethered kite would limit you to travelling with tailwinds. Is that the case.
As for road sail vehicles, the concept has been tried proven and manufactured by RANS:
https://www.rans.com/25C_Early_Years.htm
And Worden has shown a small airfoil providing satisfactory supplement on a smaller sail suitable for bike trails:
Liked 5 Times
We don't need no stinking low center of gravity
https://ventduvoyage.free.fr/Materiel.htm#voile
There making us eat crow on the feasibility of two wheeled recumbent sailbikes.
Here's a thread in the recumbents forum on subject:
https://www.bikeforums.net/showthread...50#post2431550
Hi
yes there is such an invention, it is awesome. Called a Whike if you go to https://www.whike.com you will see it.
Bikes: Terratrike Tour, recumbent tadpole tricycle.
Liked 6 Times
What do you call a cyclist who sells potpourri on the road? A pedaling petal-peddler.
Right. If bike-sailing on, say a beam reach.....and a big gust happens, to keep from tipping over you'll need to quickly 'sheet out' your sail or you must quickly 'fall off'/head downwind, potentially causing you to crash into the person sailing downwind of you.
So Id start with a downwind rig. Most kayak sailors only use a downwind rig, (only works downwind mostly=less chance of capsize) they are simple to deploy and simple to dowse....and CHEAP!
Kites in urban environment are out of the question. ive been kiteboarding since 04'
Im sure a kayak sail could easily be rigged for a bike. Good luck i wanna see whatever you make when your done!
Mostly Harmless
Hi
