Hints and tricks thread
#577
Bikes: 80/90's Specialized Crossroads (3), '91 Miyata Triplecross, '91 Bianchi Boardwalk, 2002 Schwinn Frontier, 2002 Gary Fisher Tarpon, 2009 Trek FX 7.2, 2014 Motobecane 400 HT
Quoted: 9 Post(s)
Trying to toe-in your brake pads so they don't squeal? It's had to reach around between the fork and rim to fiddle with the pitch. Grab a medium sized zip-tie and trim off the slim leader. Loosen the nut, and use the zip-tie to lift the back end of the pad while squeezing the brake lever, and tighten the nut.
#578
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
- The cones on the front axle of my Feida didn't come with lock nuts, so keeping the cones in proper adjustment was a real nuisance every time I unmounted and remounted the wheel. With the lock nuts on, the fork turned out to be too narrow for the axle to fit, so I used another axle rod to spread the fork out a little; I spun the mounting nuts onto the rod backwards (the washer sides facing outward,) placed the rod in the dropouts, and turned the nuts outwards until the two blades were split wide enough to accommodate a mounted axle.
- Because of the scarcity of bikes that use them, 20x1-3/8 (37-451) tubes - and tires, for that matter - are rare and extremely hard to source locally mainly because very few shops stock them due to the lack of demand. So when I asked one Indian repair man near my house to find me a couple of tubes for the Feida, what he managed to get me instead was a pair of 22x1-3/8 tubes! When I told him sternly that these would be too big, he taught me this neat trick of tucking the tube in on itself until it's the right circumference for the tire:
You can get the tube to be as short as you want with one or more knots like these - within reason, of course.
#579
Quoted: 1814 Post(s)
Liked 923 Times
Why isn't there a cassette lockring tool available with a handle?
Here's a quick attempt.
Used a heat gun to soften the PVC fitting & pressed it onto the tool.
The fittings are not glued so far.
Only used a couple of times now, but works.
I think a pivoting handle- like a breaker bar- would be good.
Edit: In use for almost a year. I recently shortened the handle to 1' to fit with the rim size better, & glued the elbow.
#580
#581
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,424 Times
Well there is the Park FR-FH, but I couldn't find it on the Park website, maybe it's discontinued.
So when you heated and pressed, did that create grooves in the plastic to hold the tool really firmly? I have a bike that I have never been able to get the lockring off, I've tried standing on the wrench (and holding the chain-whip at the same time), no go. I think at an extreme like that, a plastic tool would break, but for a lot of cases, that seems like a great idea.
EDIT: joejack found it. I was looking for fr-Fh instead of 5h, because of typo on treefortbikes.com.
#582
Liked 923 Times
Huh. Never seen that for sale in a store or on line, nor noticed one in a shop.
My improvisation wouldn't be good for extreme cases, but has managed a couple of routine cassette changes.
#583
Bikes: trek 800 sport, K2 nomad
Just one of many found on a Google image search: Lockring Tool with Handle | Park Tool
get a crowfoot wrench that fits one of the lockring tools [mine is 1"]. This will allow use of any pivoting/fixed breaker bar.
You'll still need a chain whip and a cheater pipe, but that cassette WILL come off...
#584
For any electrical or signal connectors and "contacts anywhere", recommend "Dielectric Compound" available at most home stores and many hardware stores. Of course you can buy it on Amazon, eBay, etc., also. It doesn't make a mess, is easy to apply, etc., and 30 years from now if you loosen a connection you will see it still there working properly and the contacts will still be shiny as new.
#585
I thought it would be a good thing to have a thread where people post and discuss little tricks they came up, during the course of their cycling and bike-repair experience.
One trick I have: I noticed that, no matter how good the rubber insulation on the battery lid of the cyclecomputer, in the Finnish wintery rains, at least a tiny little bit of water will make its way in, and cause a little bit of condensate inside. That might be just a cosmetic problem, or it could drain your battery's life, depending on the amount and place of condensation. This is even much more pronounced with bike lights, where the water can find much larger "holes" on the lid (much longer edge), and the insulation is usually worse than with cyclecomputers.
My solution is to put a little bit of lithium grease on the strategic places. Lithium grease is hydro-repellant and very stable. Together with the existing insulation, it will provide nearly 100% security against water infiltrations. Try to avoid getting it on the contacts with the cradle, even though it's not critical.
#586
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
#587
elcraft
This compound is used in plumbing connections, especially water heaters. Where the steel connector joins with copper pipe, electrolytic corrosion occurs more dramatically. You can find this in the plumbing section of your home center, usually next to the water heaters. I use it for electrical connections that are exposed to weather, as in an automobile. Nice stuff!
#590
elcraft; Not quite really. Let me add to to expand the post.
The paste dielectric compound would not be acceptable for the plumbing connections of a hot water heater. It would fail inspection. The code required items are called dielectric couplers, one for each line. About $5 a pair at any home or hardware store. They are about 3-4 inches long and screw into the threaded fittings on the tank. Then the plumbing lines (typically copper) connect to them. These couplers have a non-conducting center section and a vinyl lining which prevents the electrons from flowing between the dissembler metals (which is what used to cause the iron tank to rust out on the inside and burst during thermal cycling). The paste will not prevent the two different metals from touching and thus worthless for that use. Refer to the US Residential House code. I think this standard kicked in about 1985 or so, mostly due to pressure from insurance companies who were getting killed by water damage claims. There may be a use for the paste in a electric water heater such as on the wiring connections to the heating element (which it would be for as found near water heaters in the store).
The intended use for the paste DiE is for the electrical connections such as those you mention; Any connection exposed to weather or water/moisture and is awesome for the threads or pins of any light bulb anywhere, trailer connector, cable and satellite antenna, etc. I believe there is a slightly different compound required for boats, airplanes, etc.
Yes agreed, nice stuff. I always have tubes of it in my tool bags.
#591
elcraft
I stand corrected.....
#592
Bikes: GT Palomar mountain bike (from 2000, still my favourite) my dry bike, Land Rover Windsor hybrid (my wet bike), 2 foldies, a 1980 tandem.
Just a couple for now....
When replacing a punctured tube, make sure you cannot possibly mix up the new with the old. I did this on a freezing cold rainy night, with a rear puncture, bolts not QR axle then, bike was laden with heavy panniers, tried to rush it and managed to refit the old tube. You don't fall for this one again in a hurry!
If you snap your QR back axle, don't take all the spacers and nuts off before replacing, it's then much harder to work out the spacing (also don't put the freewheel back on until you have tested the wheel in place).
And remember, hindsight is always 20/20. Live, learn and share.
More to follow.....
More to follow.....
#593
Location: Creede CO in summer & Okeechobee, FL or TX Gulf Coast in winter
Bikes: Zenetto Stealth road bike & Sundeal M7 MTN bike
Quoted: 90 Post(s)
"Third Eye Pro Helmet Bicycle Mirror" just won't stay in place on bumpy roads. Have tried many solutions and none worked long enough to be worth it. I finally think I have problem solved. I tried "Finish Line Fiber Grip Carbon Fiber Bicycle Assembly Gel" on both helmet end pivot points. ROCK solid for days now!
#594
EJ; Huge amount of truth in your post. Thanks. I use the DAG and several other Park tools (and/or Campy equals) to check all aspects of the frame and fork alignment before building up a new ride and to correct friends rides that are wonky. I continue to be amazed at the percentage of new and old frames that are completely wacked... It takes a bit of time to set them right using the proper tools, but then often they have none of those weird problems that so many folks run into and painfully post their needs to the Bike Forums.... /K
Do everything in the most logical order.
Clean your bench before you begin working. Set a space aside for parts you're working with, so you won't lose them. Especially important when working with small screws and bearings.
Make sure the wheels are both straight in the dropouts and true before you adjust the brakes. Otherwise, you may waste your time tuning the brakes initially, because you'll have to reset and/or true the rim and then adjust the brakes again afterwards. This also applies when using the Park Tool DAG-1; if the rear wheel is crooked, so will be the derailleur hanger if you use the wheel as reference.
Make sure any part you're working with is in good condition before reinstalling it. If it's likely to cause problems, fix or replace the part now.
If a bike is giving you a really hard time, relax, kick back, have a beer, and try to think of a creative solution. Preferably more creative than just using brute force Subtract the beer if you're working at a shop, and have it after work instead. One example of changing the order of things depending on the particular circumstances.
Never, ever half-ass anything. If you do, it will come back to haunt you. Spend that little bit of extra time doing it right the first and only time, and you won't have to worry about it later. In the long run, this approach will save you time and headaches, and will also keep customers very happy. The only customer I've had come back with a problem with a bike I had worked on (aside from those who've broken or worn something of their own accord) was one with a disconnected front V-brake... I had disconnected the brake in order to remove the front wheel for transportation in her car. I assumed that she knew how to re-attach it Now I make sure customers know before seeing them off. Live and learn.
#595
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,424 Times
Hi Brad,
Welcome to BF, but this is not really the right place. Hints&tricks is more for if you have an answer than if you have a question.
Mechanics is the right subforum though, you can just go there and click "New Thread" to post your question.
#596
Quoted: 5772 Post(s)
Liked 2,567 Times
Newbies start new threads all the time in the mechanic's forum. And, coming to ask about a problem is often the very reason newbs are here in the first place.
I believe the restrictions are related to posting links (and possibly photos), to keep spammers from coming here posting links to all kinds of malware.
So, go back and repost in the mechanics thread, and you'll probably get answers within minute.
To the Mod - I apologize if I'm wrong on the newbs rules, and would appreciate being brought up to date.
FB
Chain-L site
FB
Chain-L site
#598
Bikes: 1970s Itoh
My road tires (Schrader valves) lose about one pound per day (90 psi to 60 psi in 30 days). Is this normal for road tires? I will check the valve cores. If not the valve cores, then what else.
#599
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,424 Times
Hi paullouisf, see the discussion with BradClark right up there, this thread is not the place to ask new questions, you should go start a New Thread and people will be along with responses.
#600
https://www.instructables.com/id/Bicycle-cone-wrench/
