trek 73fx question?
trek 73fx question?
I recently purchased a Trek 73fx bike and I am a newbie to this kind of bike. My old bike was a Schwinn Collegiate. Big difference! Does anyone know how to inflate the tires on this bike? It has Bontrager Racelite tires. The guy I bought it from said to inflate them to 60 lbs. On the tire it says 110 lbs. Does he know something I don't know? 60 seems low. Also, how do you inflate these tires? I tried a standard Schwinn pump and couldn't seem to get them to firm up. Also when I tried to test them with a pencil gauge I couldn't get a reading on the gauge. Anyone's help would be greatly appreciated!
Papaya King
Bikes: 2009 Felt X City D, 1985 (?) Trek 400, 1995 (?) Specialized Rockhopper, 1995 Trek 850
I have the same bike, 2009 model with Racelite Hardcase tires. Presta valves. If you also have Prestas, you have to unscrew the outer, brass portion of the valve after removing the valve cap, if that is what you are asking.
I believe mine also say max of 110 psi. I pump them to about 100. 60 is WAY too low, IMHO. I think the tires ride harshly, but they do roll pretty quick, it seems. Nice bike, I just don't really like the tires.
Hope this helps.
Hope this helps.
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1349 Post(s)
Liked 1,243 Times
The Woods valve is a confusing valve. My neighbor's wife has a bike she brought over from Germany.
He came over one day asking for help pumping up her tires.
Tried a presta pump and it worked.
Fred "The Real Fred"
Trek 7.3fx
Thanks to everybody for their input. I finally figured out the issue. The bike tires have Presta valves and the back tire had a Schrader adaptor over the Presta valve which too a newbie was confusing. Took the Trek out for an initial spin. Seemed light and fast with good handling and decent ride. The bike came with a Bontrager trip 4W computer which is nice. Might upgrade to a cushy saddle.
Bikes: Trek 7.3 FX
I have a 7.3fx -- the valve is a presta valve, a standard pump for car tire valves will not work. The bike shop i bought from told me to inflate the tires to 80 lbs. Get a pump that is presta compatible and keep the air up to pressure.
Hey waynesworld,
I don't have enough posts to PM you, but if you're still selling your 7.3 FX, I'm in the market. Please e-mail me at mystsofdayz@yahoo.com if it's still for sale. Thanks!
T.J.
Edit: I will also be in Trenton, OH this weekend, so that might be serendipity!
Second edit: I also didn't want to de-rail the thread. Sorry.
T.J.
Bikes: Bianchi Infinito Celeste, Trek 7.5 FX, Felt Z6
Quoted: 18 Post(s)
I think it depends on how much riding you (plan to) do. The more you ride, the more a padded saddle can cause chafing (from what I've read, not through experience).
So I would give it a week or 3 and see how you feel about changing the saddle after that.
Papaya King
Hey waynesworld,
T.J.
T.J.
Bikes: 2010 Trek FX 7.5, 2011 Trek 2.1
I've had a 7.5fx for 2 weeks now. The saddle is not very padded. It *hurt* the first 2-3 days, hurt a bit the 1st week, and now it's pretty much fine.
Bikes: 2009 Trek FX 7.3 ( pimp moment )
I can share my 5 cents( inflation ) on the air presure,my 7.3 has the same tires as your,110 lbs at max, my suggestion is base on what i found on varies websites,your ground which your bike rides on and your body weight determind how much air is at the ball park,take it into consideration, smooth surface is better suitable for higher presure and vice verser,if you are not a heavy person,say 180 lbs start off with 90 lbs at the rear and minus 10% for the front,which will be 81 lbs,like i mentioned, the bottom line is about comfort or speed,you need to know what you want first.Thanks for reading.
