Bottom Bracket/Crank Arm Damage
Hello all,
I noticed something was off with my '78 Centurion LeMans when the non-drive side crank arm started to feel loose when I pedaled. I took it off today to find out that the threads on the spindle (?) of the bb (correct me if I'm wrong please, I'm not exactly sure what this part is called) is chipped. Is this salvageable, or do I need to replace it? Any information regarding what my issue is, or how I can resolve this would be helpful!
Quoted: 4211 Post(s)
Liked 3,880 Times
I've seen this more then a few times. The axle is hardened and as such tends to not deform like most abused threads do at first. It chips instead. Try threading a nut back on. How does it seem to fit. This is all judgement based so we can't give other then opinions. Most of the time I've dealt with this the axle's threads were in good enough condition so the nut went on and off easily and with a lot of remaining contact surface. Only a very few times did I feel the reusing the axle would not be the right thing to do to a customer. I have to admit I don't remember any of these, when I left the axle as is, coming back with further issues. Of course some of that is also about the crank arm condition and how you torque down the nut (and test ride then re torque). Andy
AndrewRStewart
AndrewRStewart
Quoted: 1438 Post(s)
Liked 1,092 Times
If the nut cannot be secured satisfactorily a replacement spindle can be obtained, or a cartridge-type bottom bracket installed.
It's had to tell from the photos but it also looks like the actual taper interface may be slightly messed up as well. I'd just replace it with a cheap cartridge BB and call it a day.
Dangerous Old Man
The threads do look damaged. Basically you need to chase it with an threading die. You can see lots of material in the thread valley's and some of the thread ridges themselves are gone on the top side. After chasing to fix whats is left and the nut goes on properly (I would get a new nut), reassemble and see what is...
Quoted: 980 Post(s)
Liked 584 Times
If the nut doesn't thread on easily, you can get a "THREAD FILE" to restore the threads. Chances are when you removed the nut, the threads were set more-or-less right. The chip, unless you somehow impacted the left-side crank, might well have been there since the bike was new.
Of more concern, IMO, is the possibility that riding the bike with a loose crank has damaged the square taper on the crank since it's aluminum (softer than the crank axle). If this is the case, a new BB cartridge will not be the final solution.
I'd recommend re-installing the crank, torquing it properly, then riding it. Check the torque after a few miles, then after a couple of longer intervals. If it doesn't loosen up again, you're home free.
Thanks for everyone's input.
I have already tried threading the original nut back in, but it will not secure properly and cannot be torqued properly. I can't really tell if the nut is any good, but I'll try a different one and see how it goes. Hopefully, I didn't already screw up the threading on the axle already while removing the nut the first time...
Quoted: 1572 Post(s)
Liked 643 Times
Nobody's mentioned the crank arm but my bet is the square hole is, since it was loose, the square hole is buggered badly enough to be un-fixable too.
Liked 3,880 Times
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Quoted: 980 Post(s)
Liked 584 Times
Yes, I'm aware of this. The files are also hardened, and though it's not as effective as it should be small defects in the threads can be removed with some effort (in my limited experience). It's probably hard on the file. I sure wouldn't use a die unless I were willing to throw it away. Your recommendation to replace the spindle is the most reasonable.
Quoted: 1944 Post(s)
Liked 2,164 Times
So, what are your plans? About 15 years ago the woman next door moved and left a couple of bikes half rusted in her back yard. One was an 80’s Lemans. I stripped off what wasn’t rusted/frozen. Included was a 116mm threaded spindle.
Those cranks are probably 144bcd, which limits you to a minimum 41t inside chainring.
Personally, I would go with a more versatile crank and a cartridge bb, but PM me if you want the spindle. I probably have the GLP cranks somewhere around here.
John
John
