This is a long shot - derailleur adapter
Quoted: 206 Post(s)
Liked 102 Times
I have a Campy front derailleur that I really like, but the clamp broke, so it is useless. Is there any chance I could modify the derailleur so it could be attached to a front derailleur adapter that is used for braze-on derailleurs? Anybody done this before? I’d really like to salvage this part.
Maybe use something like this and modify the derailleur to bolt on to it.
Some days, it's not even worth gnawing through the restraints.
Quoted: 1944 Post(s)
Liked 2,164 Times
Someone with Campy knowledge can give you a real answer. Because of where the clamp bolt is located, it seems conceivable that the clamp could be removed and a braze-on attached. I wouldn’t put it past Campagnolo to design something like this.
John
John
Dangerous Old Man
I just checked Ebay. Saw two solutions. First one was the same derailleur, new, selling between $37 and $43. Or, you can get a clamp-on adaptor and the appropriate Campy braze-on derailleur for about $10 more. What worries me is the small fixed pin on far left that needs removing to complete disassembly to get the backside broken part out. I did not see a conversion kit/rebuild kit for yours...
Sr Member on Sr bikes
I just did a quick search for "Campagnolo small parts" and got this.
https://branfordbike.com/front-der-p...ur-small-parts
Looks like the part you need is only $5.88. But, I've never used this particular company. Maybe a phone call to their Seattle, WA shop would be prudent. Number listed in 'contact' on menu. Link to their homepage -- https://branfordbike.com/
Edited to add: Well, after second look it appears that the exact part you need either isn't in stock, or isn't carried. At least it's not available on the webpage. But again...maybe a call to the shop might produce something.
Good luck.
Dan
Quoted: 206 Post(s)
Liked 102 Times
Not such a longshot, I think...
Good luck.
Dan
Good luck.
Dan
Branford Bike in Seattle, at one time in Branford, CT and then in Montana or Idaho, are the Campy experts. They know the secret handshake. I sent a cracked right Chorus 10 brifter to them and they sent it back working as good as new.
If anybody has that part it would be them.
Likes For zacster:
Quoted: 645 Post(s)
Liked 797 Times
Likes For Litespud:
