Perfect Handlebar
Perfect Handlebar
I've been searching high and low for a full carbon drop bar handlebar with internal cable routing, no aero qualities (I want to be able to mount lights, clip-on aero bars, GPS, etc. anywhere and everywhere), and in a 360mm or 380mm width. Any suggestions?
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
ENVE's standard road bar is pretty round at the tops. The compact weighs more. Both versions are kind of porky though. $350 & 205g
Ax-lightness is pretty round at the tops as well. The internal routing is super easy to run cables/housing, etc...You'd have to contact them to get custom reinforcement in the clamp area if you intend to run clip-on aero-bars. Not a big deal, really. €359 & 157g
Either bar is worth the cost & in my experience as comfortable as any other bar you're gonna find.
If you're already in carbon bar territory...At ~$50 more to save almost 2 ounces off your bike, the Ax-lightness is a no brainer.
You might look in to Darimo But, at €400 to save another ounce...& then lose it to reinforcements for internal routing & currently 2 months wait time for manufacture...I dunno. The Ax-lightness is cheaper, in-stock, has the features you are asking for at what amounts to grams difference.
I've been considering those, I feel like I might be able to get slightly better value elsewhere though.
I am potato.
Liked 1,631 Times
(Sorry, slow fingers. )
Car dependency is a tax.
Never heard of Ax-lightness, thanks for the option!
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
CM not MM.
Quoted: 18883 Post(s)
Liked 10,646 Times
So it is
Quoted: 11407 Post(s)
Liked 4,761 Times
I have these:
https://planetcyclery.com/easton-e10...SABEgKinvD_BwE
They're awesome. They're comfortable, and they don't flex.
Likes For LAJ:
Quoted: 4560 Post(s)
Liked 2,802 Times
Check FSA handlebars. I haven't looked at their catalog recently. But I'm satisfied with their low end aluminum Omega compact drops after more than two years with 'em.
I am potato.
Liked 1,631 Times
I had these on a bike for a couple years and really liked them a lot. For what it's worth, there's a recessed basin along the bottom of the bars for the cables, once you wrap the tape you really can't tell anything is there. If internal routing is very important for some reason, that's not what these are though.
I mostly referenced the weight to give a sense of scale to the OP & to provide a transition mechanism to the Ax-Lightness & Darimo options on the market.
The Easton 100's linked to by the other poster do look like they will garner a lot of attention among the weight conscious. Same price as the Enve, but nearly an ounce lighter. The times are getting interesting indeed.
Quoted: 980 Post(s)
Liked 776 Times
The perfect handlebar should also be a value.
Whoever makes the perfect handlebar is just plain silly for expecting to get a premium price for their products.
