Rim tape shifts
Rim tape shifts
Old 07-04-18, 02:56 PM
Aubergine
Bad example
Quoted: 825 Post(s)
Liked 208 Times in 95 Posts
Rim tape shifts
I just got a flat, and found that the puncture was from a spoke hole. I had installed Zefal rim tape that was the proper size for the wheel well. In other words, it lay flat in the well and butted against both walls of the rim. Yet the tape had shifted over time and had climbed up the walls up to 3 or 4 mm in places. So clearly, I need more learnin’ about installing rim tape! What makes the tape shift, and how can I install it so that it stays where it is supposed to be?
Aubergine is offline
Old 07-04-18, 03:11 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
my Mavic ex 721 rim extrusion, has a channel in it and the rim, tape snaps into that channel...
fused loop plastic tape ..
I use the hole in velox cotton tape, put my screwdriver through it and the valve stem rim hole ..
then pull the tape around the rim , with a tension like cotton bar tape..
reusing it the adhesive is not as sticky..
fietsbob is offline
Old 07-04-18, 07:23 PM
RGMN
Quoted: 241 Post(s)
Liked 232 Times in 153 Posts
Velox cotton tape had been my go-to solution for any rim strips for years (decades?), but several of the new tire/rim combination that are tight to begin with are next to impossible with Velox. I then tried Vittoria high pressure and Zipp rim strips but I also had issues with them moving out of place, and then one started to fray and actually punctured a tube. I've since switched over to Kapton tape and haven't had an issue since. I usually use 2 wraps per rim, and get about 7 rims out of a roll of tape.
RGMN is offline
Old 07-04-18, 08:08 PM
speedevil
I never finish anyth
speedevil's Avatar
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times in 86 Posts
Even though it was centered properly when applied, a tight bead could cause mounting the tire to move the tape. I switched to Kapton tape as well, mainly because the 35mm Compass tires I mounted were so tight using Velox tape that I didn't think I could fix a flat at the side of the road. The Kapton tape did make a difference for me.
Dale, NL4T
speedevil is offline
Old 07-04-18, 08:09 PM
Aubergine
Bad example
Quoted: 825 Post(s)
Thanks for the recommendations. I have not had issues with Velox, but I will check the Kapton tape.
Old 07-04-18, 08:10 PM
speedevil
speedevil's Avatar
Quoted: 294 Post(s)
It comes in different widths, I picked up both 16mm and 19mm rolls.
Dale, NL4T
Old 07-05-18, 08:24 AM
pdlamb
Quoted: 2604 Post(s)
Liked 1,928 Times in 1,210 Posts
Reading some of Heine's marketing blurbs about how he thinks rim tape and tires should work, I was wondering about that. Sounds like another reason (besides the $75 price tag) to use another tire ...
pdlamb is offline
Old 07-05-18, 09:51 AM
Aubergine
Bad example
Quoted: 825 Post(s)
That makes sense, but these tires were easy to mount and unmount. I actually was able to remove it without using a lever! Also, the tape had moved in several places along the rim, so something else must have been at play here. So frustrating.
(FWIW the tires were Swift 27x1-3/8 Sand Canyon. Nice tires, similar to Paselas for 700c rims.)
Old 07-05-18, 10:44 AM
fietsbob
Bikes: 8
try applying some rubber cement on the rim well , and let it dry,
so giving the tape something to stick to.. rather than slick metal..
talc it a bit , like is done to tires and tubes..
fietsbob is offline
Old 07-05-18, 03:00 PM
SquidPuppet
Calamari Marionette Ph.D
SquidPuppet's Avatar
Bikes: 3 Chinese Gas Pipe Nerdcycles and 2 Chicago Electroforged Boat Anchors
Quoted: 2358 Post(s)
Liked 33 Times in 26 Posts
It depends on the rim. I have Compass tires on two of my bikes, with two different rims, velox tape, and my installs were tool free.
SquidPuppet is offline
Old 07-05-18, 03:32 PM
Aubergine
Bad example
Quoted: 825 Post(s)
I was thinking of using sewup cement, actually. Rubber cement would definitely be easier.
Old 07-05-18, 03:42 PM
2_i
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times in 251 Posts
Hair dryer or heat gun applied equally to the tape and rim makes the glue on the tape stick.
2_i is offline
Old 07-05-18, 04:04 PM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,581 Times in 2,342 Posts
you have my sympathies
rumrunn6 is offline
Old 07-06-18, 08:04 AM
Iride01
Iride01's Avatar
Quoted: 6193 Post(s)
Liked 4,808 Times in 3,316 Posts
I know that they say to let the old rim tape, like Velox run up to the bottom of the bead seat, but I go much narrower and don't even let it get out of the spoke channel. I always figured if I cover the spoke nipples by a milimeter or two that's all I need.
It has been hard to find the narrow Velox at the retailers both online and local I use, so last time I found some narrow Zefal locally and it's been great so far. Hope it last the 20 plus years the Velox did for me.
When that 20 year old Velox failed, it too was pushed out of the spoke channel uncovering a couple spoke nipples. I've wondered if it was due to a brief period I had of wanting the bike to look really nice and cleaning it. I suspect the cleaners or solvents I may have cleaned the spokes and wheels with seeped down the spoke holes and loosened the tapes adhesive.
Iride01 is offline
Old 07-06-18, 10:05 AM
fietsbob
Bikes: 8
many mysteries , unseen, under an installed tire, your guess is more local than one coming in over the internet..
had to cure a mystery on my rear Brompton wheel ,
it uses a fused loop plastic tape , on a single wall rim.
removed the tape , created one from a rubber rim tape,
shortened, joined at stem hole with duct tape.
put the plastic loop tape over it ,
and it has been fine.. since then..
spoke head may have been the issue..
fietsbob is offline
Shadowjaxs
Road Cycling
20
12-26-16 04:12 PM
joeyduck
Bicycle Mechanics
8
07-02-14 03:23 PM
rowebr
Bicycle Mechanics
42
04-10-13 11:06 PM
PatrickGSR94
Bicycle Mechanics
18
05-08-12 07:30 AM
chandltp
Bicycle Mechanics
21
05-11-11 08:12 PM
