2nd hand road bike, should I remove bar tape to inspect bars?
I've just bought a 2nd hand Focus Summit for my son. Apparently the previous owner only used it on a turbo trainer. I have heard horror stories of handlebars breaking due to corrosion caused by sweat. The front derailleur is rusty and completely seized suggesting the bike has been exposed to a lot of sweat. The handlebar tape looks fine but I'm concerned the bars underneath might have corrosion. Is this likely or am I worrying unduly?
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1124/20230923_222802_1307256362a9e5ee7bce9c36dbf7b165b8a5d3f5.jpg)
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1124/20230923_222922_505c50373dd1cbd413a8c539420097a0b8758558.jpg)
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1124/20230923_222724_0718997b61cbfaf39e830943d4d20bef3f1125ef.jpg)
Likes For bboy314:
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Liked 330 Times
I would. Think of how nasty the tape is from the same sweat (TBF looks possible it's been replaced, perhaps as a cosmetic makeover).
Liked 5,004 Times
Hard to say. I've never found any bars that had much if any corrosion under them whether mine or the few others I've dealt with. And the few that had any corrosion of any notable amount were bare alloy or steel bars. Those appear to be anodized or painted, so less likely to have issues I'd think.
If you are confident and decent at wrapping, why not? Some tapes can be re-used.
Klaatu..Verata..Necktie?
Liked 12,379 Times
You should remove the bar tape, if only because the blues don't match. ![Wink](images/smilies/wink.gif)
Seriously, though - replacing things like cables and bar tape makes the bike yours. Well, okay - PAYING for it is what literally makes it yours. But I mean it's what makes it feel like yours.
Likes For genejockey:
Likes For 50PlusCycling:
I would also remove the bar tape and inspect. They certainly can corrode with heavy trainer use. Ask me how I know?
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Liked 1,252 Times
The cost of a roll of tape would put your mind at rest.
it would also be a good excuse to get rid of the extra brake levers.
Barry
Barry
Likes For Barry2:
I've seen heavily corroded bars, though never really enough to cause a failure but I always hated peeling the tape away to find the powdery gray corrosion from people over sweating. For that reason I'd always replace the tape on a used bike just cause of how gross it could be without seeing it.
Sunshine
Liked 7,726 Times
It's bar tape- just replace it with new stuff that your kid likes, whether thars color or texture.
The stuff is $6-30 depending on brand, website, and sale. Hardly something to even think twice about.
seńor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,649 Times
I always replace the previous owner's gross bar tape ... during a full overhaul of the bike, of course.
Likes For SurferRosa:
I am potato.
Liked 1,728 Times
IOW: those levers outside of that specialty use are a redundant waste of space & as such most people remove them.
Car dependency is a tax.
Likes For base2:
aged to perfection
Liked 1,313 Times
suggest you also replace the bolts holding the stem faceplate
and re-torque them properly (4-6 Nm)
some evidence of corrosion on this bike.
/markp
/markp
Liked 1,719 Times
Whats the big deal... Strip it down, buff out the existing rust, replace rusty bolts, put on new cables and tape, polish the bike up.
The bike deserves it!
Fun, Fun, Fun...
Fun, Fun, Fun...
Clark W. Griswold
Liked 4,234 Times
Yes I would always remove someone else's tape and throw it directly in the trash. It is garbage pure and simple. It is soaked in someone else's corrosive nasty sweat. Get new tape, tape is cheap if you want cheap tape or you can get some nicer tape and enjoy it more.
Bars should really be inspected with some regularity, yearly or or every two years is a good idea. It doesn't hurt to do and doesn't cost much but a corroded bar can cost quite a lot.
I bought a used bike recently with carbon bars. They were too wide so I replaced them with narrower bars. Glad I did because after removing the tape I discovered the brake levers were way overtightened and caused indentations and a minor crack in the carbon fiber.
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Liked 179 Times
I'd replace for the simple reason that they are wrapped wrong. The secondary brake levers... I agree with base2 . Ditch them.
Replacing fasteners because of surface rust is throwing money away, however fasteners cost pennies, well they cost me pennies when I buy in boxes of 100 from an industrial supply house. Your local ACE or Turue Valuse might have them for a bit more than pennies, being metric cap screws and all.
Sir Mark, Knight of Sufferlandria
Sunshine
Liked 7,726 Times
It's a cyclocross racing thing. Generally they're never used outside of CX racing because nobody rides with their hands in that position unless they are climbing a steep grade and are positioning their body for best respiration and core muscle engagement. Going uphill slowly at very high effort rarely generates a need for emergent brake use unless you are in a very dense pack of people. Even then, hands on the hoods/shifters would result in more control. They are also a secondary to a crash broke brake lever.
Yes, some remove them. No, they arent inherently redundant wastes of space.
