105 goes Di2
Quoted: 18883 Post(s)
Liked 10,646 Times
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
Distracted by some crazy emailing me about the NSA tacking cats.
Likes For Polaris OBark:
Liked 3,445 Times
The pricing is said to be competitive, but I think that is only with respect to 12-speed.
I just impulse-bought a Ti frame, and am looking at Di2 11-speed parts. These prices are comparable to 11-speed Ultegra.
Quoted: 3241 Post(s)
Liked 2,512 Times
Likes For seypat:
Quoted: 1461 Post(s)
Liked 1,486 Times
Disc brake only. I'm surprised by that, considering Shimano still makes rim brake versions of Ultegra and Dura Ace Di2.
Also, this makes me wonder how much longer 11sp mechanical Ultegra will be around. Seems like this 105 Di2 version would basically replace that in terms of build tiers for OEM.
EDIT: Also noteworthy are those new carbon wheels.Tubless and 32mm rim profile, 21mm internal rim width, and claimed weight of 1,502g. 46mm rim depth, 21mm internal rim width, and a claimed weight of 1,610g. A bit narrow considering the trend direction, but $1050 seems like bargain.
Likes For msu2001la:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 926 Times
So, what will be the "best" gruppo that you can get without software then?
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1952 Post(s)
Liked 1,475 Times
Since Di2 shift lever only sends a signal to shift, I am quite sure something can be hacked together to do that and pull a brake cable.
Likes For SoSmellyAir:
Liked 3,445 Times
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
The electronic systems don't really shift better than a good mechanical system (been riding Ultegra Di2) but I assume they will stay consistent over time. Actually surprised at how unremarkable Di2 shifting is....
Likes For vespasianus:
Quoted: 6974 Post(s)
Liked 10,975 Times
Campag. Centaur is actually pretty good and Chorus with disc brakes is fantastic.
One of the nicest things about Di2 is getting the gear readout on my computer...And no broken cables.
Likes For Koyote:
Quoted: 406 Post(s)
Liked 389 Times
For my road bike, I can get away with running the same cable for 15-25K miles (3-4 years) without even thinking about it. However, on my MTB, I change them out every other year. That is where I would like to see Di2 used (but not at $280 for a rear derailleur!).
Liked 3,445 Times
My Ultegra Di2 >> my Campy Athena shifting.
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
The groupset of the people just turned electriccccc! Everyone was expecting it and it should be ''the'' product of the year IMO.
I just hope Shimano is also investing $ to resolve its supply issues.
Liked 1,486 Times
Ultegra Di2 shifters/brakes on an otherwise 105 Di2 groupset probably makes the most sense for a budget rim brake Di2 build, but I was thinking more about OEM spec builds. From that perspective, there doesn't seem to be a lot of mixing/matching from different groupset tiers these days, so I'm wondering if any would even offer a rim brake Di2 build (Ultegra?) - noting that this setup was already a bit of a rare bird these days.
Liked 2,512 Times
Sweet, the other groups prices will drop. The C & V guys like me can jump a group or 2.
Liked 1,475 Times
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,923 Times
Likes For genejockey:
Liked 11,923 Times
Quoted: 696 Post(s)
Liked 910 Times
I’ve broken shift cables on bikes (2015 Roubaix, 2017 Boone) with poorly designed internal routing with relatively sharp radii around the BB with cable exits that act as a funnel to allow water and road crud to enter along with the cable ensuring shifting is nearly impossible well before 1000 miles. My bikes with exposed externally routed cables have lasted for thousands of miles.
Likes For Ghazmh:
Quoted: 406 Post(s)
Liked 389 Times
Quoted: 406 Post(s)
Liked 389 Times
I agree and view that as a good thing. Shifting performance is excellent (as is mechanical) and it will stay that way. But shifting is shifting and I view electronic systems as another way to skin a cat, not another cat.
Liked 11,923 Times
Agreed. I just put mechanical R8000 on my dream bike that I was building up, and it is fabulously unremarkable!
Liked 10,646 Times
My experience with mechanical and Di2 Ultegra is that the shift quality is pretty close to the same. The electronic one just never needs to be adjusted, which is nice, but not a huge deal. I prefer the tactile feel of mech, it's more satisfying and I feel more connected to the bike.
Honestly the best thing about Di2 is auto trim.
Maybe it's just me but I like to tell myself everybody lets the battery die once while riding. You learn your lesson and never do it again. You try to move into the other chainring and nothing happens. You try it again, and again nothing, then it hits you. Now you've got two or three dozen (?) rear shifts so use them wisely. It's not a big deal to charge, but it only needs to happen every few months so it's easy to lose track. I hate the flashing light thing, very glad my Garmin can tell me what's in the Di2 battery.
Like almost everybody else, I would want electronic on any future bike. The perfect shifting every time and auto trim converted me.
The ability to shift up and down infinitely with the chainring vs cassette switch handled in software is what's appealing if anything - I find myself staring back at my cassette to check what cog I'm in so I can plan to downshift at the fight time.
If you want to update a rim brake frame, SRAM still has you covered with Force AXS shifters. Most 11 speed cranks work with 12 speed chains and the sprocket spacing on all three brands is so close that any of the cassettes that fit your wheels can work. I've already read reports from people using shimano 12 cassettes with sram. Some think the axs chain works best. Force shifters are about $460. I got a rival FD for $175 and a RD for $255. Both were easy to set up. Two batteries and a charger run about $150. I use shimano grx cranks for more range and better shifting.
